How Do You Reset Psi After Dead Battery - Saturn Sky Forums: Saturn Sky Forum
post #1 of 6 (permalink) Old 03-17-2009, 10:24 AM Thread Starter
Junior Member
My saturn sky redline wouldnt start after the weekend of sitting in the garage. After jumpstarting it, the Warning light is on that my PSI is low for the tires. When I press info to look at them, they are all reset to 0. I figured after driving a little while it would reconfigure but it never did. How do I reset my PSI and get the warning lights off????
skyrn is offline
post #2 of 6 (permalink) Old 03-17-2009, 02:43 PM
snaponbob's Avatar
NOT being rude, but is this not covered in the owners manual? The reason I ask is that I do noy know since I have a 2007 Redline.
owner installed lock buttons,
painted calipers, SP Catless DP
MagnaFlow 3" single cat-back,
Koni S/A's, Kurt hitch,
18x11 CW's, 315/30 Hoosiers for Solo
other "stuff"
snaponbob is offline
post #3 of 6 (permalink) Old 03-17-2009, 03:00 PM
stealthsky's Avatar
it is in the manual. Youll find what youre looking for there.
2008 Sky Redline
Mods:
RPi Gt exhaust
RPi Race Downpipe
Werks Street I/C
DDM I/C Piping
GMPP Intake
GMPP Performance Upgrade Kit
DDM Race Backbone
18x9 OZs W/ NITTO INVOS
Best 1/4 mile time
13.688 @104mph (altitude of over 3000')
stealthsky is offline
post #4 of 6 (permalink) Old 03-17-2009, 03:00 PM
GS Stage 1's Avatar
Quoted: 4 Post(s)
There is a relearn process that you can initiate with the key fob. Instructions are in the manual. You have to put the car into learn mode, then go around from tire to tire letting a little air out, so the system can figure out which sensor is which. Follow the instructions carefully, it is very exact. But Be AWARE: What it does not tell you is that it will also relearn the key fob and any other key fob within transmit range. So if you have another car with a key fob system, get it that one the heck out of range.
The really easy answer is to just stop by your dealerships and have service reset with the tech II tool. They usually won't even charge you to do it, especially if are having an oil change done or something else.
GS Stage 1 is offline
post #5 of 6 (permalink) Old 03-29-2009, 11:28 AM
Send a message via AIM to Mandi
You should just be able to drive the car for a bit....usually less than a mile but over 30 mph will do it. If that doesnt work....
Then you can relearn them.....which is done by putting it into relarn mode then starting at the LF and letting air out until the horn honks....then going around counter clockwise doing the samething.
This will NOT relearn your fobs (The TPM does use the same module [RCDLR] as the keyless entry.).....nor will it relearn anyone elses fobs....in fact, when you relearn fobs you have to hold lock and unlock together during relearn mode for a few seconds.
-2007 Saturn Sky Redline M/T Chilli Pepper Red
Mandi is offline
post #6 of 6 (permalink) Old 03-29-2009, 11:39 AM
Elff's Avatar
Quoted: 138 Post(s)
It's a 2 minute process.
I recently rotated my tires and was looking into this as my fronts were at the rear and the rear was at the front.
LUSIFER
Elff is online now
Human Verification
