Old 04-27-2008, 02:55 PM   #1 (permalink)
SCVanguard's Avatar
Lil' Chromies problem
I installed the lil' chromies last weekend...quick and easy. The drivers side seemed to slip right on and locks/unlocks quite easy. The passenger side was VERY hard to get on and now it takes about 5-6 clicks on the fob to get it fully unlocked. When pulling it up manually, it definitely takes more force to pull up than the driver side.
Seeing as how it's not removable, the only thing I can think of is that the rod it goes on to is bent or some of that red goop got on a part and is making it not work as smoothly as it should. Has anyone pulled the plastic off the inside of the door? I didn't find any instructions here but maybe someone has done it...
Brad
2008 Sky Redline
Chili Pepper Red
18" chrome
Monsoon
Stubby
Old 04-27-2008, 04:54 PM   #2 (permalink)
jel
jel's Avatar
Start at post #11 on the following thread. Good luck.
Ultimate SKY Stereo Thread
Old 04-27-2008, 06:54 PM   #3 (permalink)
SCVanguard's Avatar
Thanks! I'll report back after I check it out.
Brad
2008 Sky Redline
Chili Pepper Red
18" chrome
Monsoon
Stubby
Old 04-27-2008, 10:13 PM   #4 (permalink)
SCVanguard's Avatar
That thread helped a bunch. When I pulled the plastic off, I could see where the lock was rubbing up against a square piece of foam. On top of that foam was a piece of felt. I'm assuming this block was to cut down on vibration.
Anyways, what I could see happening was that when I put the chromie on, some of the red glue that came with it had dripped down to this piece and began to stick. The felt was just about worn through and the lower part of the rod had some of the felt glued to it. So I got some sand paper and sanded off the felt from the rod and peeled off the remaining felt. Works just like new!!
So to those who are going to get lil' chromies, just remember to not use too much adhesive.
Brad
2008 Sky Redline
Chili Pepper Red
18" chrome
Monsoon
Stubby
Old 04-28-2008, 01:21 AM   #5 (permalink)
xmicro_Redline's Avatar
Good advice, and by the way it is called "Thread Lcok" . You need about 2 drops into the chromie and you are done!
xmicro_Redline is online now   Reply With Quote
Old 04-28-2008, 11:01 AM   #6 (permalink)
SkyBaby's Avatar
My Photos: (13)
Thanks.. I was wondering why I had to open my drivers door with my hand from the passenger door... Gotta have that fixed..... SkyBaby
Whats NOT to Love???
I would much rather stand out in a crowd and be noticed than life just pass me by while I am bitter!
www.kappascoasttocoast.com
www.kustomkaps.com
www.flameball.com
