Miles Per Gallon = Amazing
Hello-
I did a very informal test on my Red Line today driving into work. Using the fancy "instant MPG" meter (which I realize isn't ENTIRELY accurate) I took down some observations. @ 55 MPH = 49 MPG @ 65 MPH = 44 MPG @ 75 MPH = 36 MPG Test Case: Use the pedal to get the car to speed. Engage Cruise Control at designates speed. Wait 1 minute for the MPG to stabilize out. Repeat process coming the other way on the freeway. Average and round the 2 numbers. I was using the stretch of I - 15 in Utah from Centre street to University Ave. in Provo for my test case (as it is pretty flat) I realize these aren't perfectly accurate numbers, but I was still BLOWN away with the results. Everyone else see similar results? |
#7 (permalink) |
Out at the NASSM in Las Vegas I got closer to 99.9 for a pretty good stretch leaving the cabin where we had lunch on Sunday. Could have been the downhill, clutch in and at idle for like 6 miles. But it was fun while it lasted.
Pulling in the other direction going to lunch was a much different number. Under load and on the hills these engines don't do nearly as well as on a flat road with no wind. However, the average of all of the miles I have driven show that mine does better than the EPA estimate, especially when I don't stomp the pedal all the time. |
#8 (permalink) |
Remembers Stephen's comment:
"Gas Tank Reading #%%$: All I can say is probably the usual spiel that you get from Saturn. I had to test drive with a customer for 45 minutes once. He said his MPG's never got over 22 in his Aura...I told him "I bet I can make it say 30" I won the bet by getting it up to 31.4 MPG's. This is directly related to your gas gauge question. The gauge on the dash gets it's info from the logic on the cluster...the cluster logic gets it's info from the PCM/EBCM. The info it's mainly tracking is RPM's, accelerator pedal position, and throttle position (and obviously the fuel level sensor). I've been told by the engineers that there is an equation that calculates the fluctuation of your fuel gauge based on the before mentioned inputs. If you top off your tank...then floor it for 2 minutes on the highway...your fuel gauge will drop about 1/4 to 1/8 of a tank. You didn't lose a 1/4 tank...but the computer is telling you that will if you keep this sustained speed. When you slow down...magic...your fuel tank will fill itself and the gauge will rise. I've seen it, I've demonstrated it for customers, and they have literally told me they glad to see how it works. I don't have an actual MPH that is optimum for all the computers in your car, but 55 to 60 seems to be about right. Any acceleration or deceleration deviation from that will send the fuel gauge moving in the +/- range more quickly." I believe the instant MPG reading is based on your driving style since you last started your car!
Silver/RL 2007 - Black Top - Red/Black Leather 5th Break Light, DeJon CAI, IC Pipes Magnaflow, Opel Badges, tail lights. Hahn Intercooler, Westers Tune |
#9 (permalink) | |
Then I'd pull off the highway and within minutes, the estimated remaining miles would drop to like 30 or so and the gas gauge would dramatically drop to less than 1/8th and sometimes the low fuel indicator light would even come on when not more than a minute or two ago it had shown 1/4 tank. |
#11 (permalink) |
Personally, I think tying the GAUGE to fuel rate was a DESIGN mistake. The gauge should show HOW MUCH fuel is in the tank. If I have half a tank, it should read half a tank.
I understand what the designers were trying to accomplish, but they failed to realize a very important concept in human processing. Humans already know how to integrate (in the Calculus definition) a gauge. [Aside: I'm getting technical, but even if you only finished the 3rd grade, believe it or not, you can do differential and integral calculus...humans do it all the time and don't even know it. We go to four years of college to learn how to express it and communicate it, but we already know how to do it....whether you realize it or not]. Differential calculus is the ability to understand and compute rates of change in something. How fast am I driving? Or, how fast is the fuel gauge changing? Integral calculus is sort of an undo of differential calculus (or a summation of the differential effects). "If I'm doing 60 mph, I will go 60 miles in one hour...120 miles in two hours, etc.". Or, in terms of the gauge, if it falls a quarter of a tank in thirty minutes I know I've burnt a quarter of my fuel in thirty minutes. I've got two hours of fuel. Of course, if you drive easier or harder, the gauge will change accordingly. But here's the kicker. We humans CAN DO THE MATH without even thinking about it. We automatically integrate the gauge to figure out what we have left or how far we can go. By electronically integrating the gauge, the designers have screwed with our own internal subconscious integration algorithm. This causes far more confusion than it solves. All I want to know, with a GAUGE, is how much fuel is left in the tank. Not some virtual quantity based on my most recent driving habits. DESIGN mistake...for a GAUGE! Now, the DIC. No problem. If you want to show me miles left....or whatever with a number....no problem. But don't do it with a GAUGE. Bad design. Stop it. Too much electronic wizardry...not needed.
#12 (permalink) |
![]() I have 1/2 tank of gas in the sky, I remember that it is a 16 gal tank, sounds about right so that is 8 gal of gas or approximately 200 miles since I get average 27 miles to gallon on the DIC, so I agree that miles left to my tank of gas on the DIC is useless, I never use it. Maybe if I was heading across the desert and the last sign before the last station said 350 miles and I only had 3/4 of a tank, heck just pull in and top off the gas why even look at the DIC gage easier just to fill it up and hope for the best crossing the desert. I for one keep the gas tank or fill the cars up once I get to a 1/4 tank of gas why chance running out of gas, besides the get a way car needs to gassed up and ready to go! ![]() Now my spouse likes to take chances live on the edge drives his pickup till the orange idiot light comes on saying LOW FUEL, he pulled that stunt on the trip to Florida once in the impala, gas is cheaper in Georgia so were not stopping for gas till we cross the state line. As we pulled into the station the idiot light came on, low fuel told him I would make the call to his Mom and explain why we were late sitting out in the middle of nowhere waiting for OnStar to show up with gas because he wanted to save 3 cents a gallon on gas, darn if we made it ![]() TulsaSky ![]()
06 Daytona Sunset Orange Corvette Coupe 06 White Impala FlexFuel LS2-Daily Driver 00 White Silverado Pickup-Daily Driver 64 Sapphire Blue Sunbeam Alpine – restored 07 Midnight Blue Red Line Sky Born 10/9-13 Delivered 11/14/2006 |
#13 (permalink) | |
Example
Which is not to say that the level of precision we achieve is anywhere near what is mathematically possible - but for real world situations - in front of the truck rather than under it is sufficient. |
#14 (permalink) |
...and to think my calc teacher told me i couldn't do cal in my head and still get a good answer...
to bad a fix for the gas gauge isn't as simple as slapping a differentiating circuit on the guage.
Black 2009 Saturn Sky Redline Manual transmission Black leather Monsoon stereo 6-disk CD/MP3 changer Stubby Antenna "Redline" Wind Restrictor Next Mod: JPM Shifter assemlby |
#15 (permalink) |
You might want to review the specs.
#16 (permalink) |
Something close?
Lets see the Corvette has 2 9-gal saddle bag tanks, 18 gallons, my Alpine has 2 5-gallon saddle bag tanks 10 gallons of fuel, not sure what the big Impala has closer to 20 gallons I think, and not sure what the Sky is but it is more then the Alpine less then the Corvette, so bogie what is it?
TulsaSky ![]() OK had to look it up its on the specs for the car on-line, 13 gallons! no wonder I seem to be stopping for gas all the time! Calculator in hand so if I get on average 27 mpg then the most I get out of a tank of gas in 351 miles, now I know! Guess if I had to cross the desert and it's 400 miles I better take some gasoline with me, I won't make it!
06 Daytona Sunset Orange Corvette Coupe 06 White Impala FlexFuel LS2-Daily Driver 00 White Silverado Pickup-Daily Driver 64 Sapphire Blue Sunbeam Alpine – restored 07 Midnight Blue Red Line Sky Born 10/9-13 Delivered 11/14/2006 Last edited by TulsaSky : 07-08-2008 at 02:24 PM. |
#19 (permalink) | |
#21 (permalink) |
Page 333 of my owner manual says 13.6 gal. I don't know about all the guages/DIC/etc. All I know is miles driven divided by gallons used = miles per gallon. Just simple math for my simple mind.
Silver Pearl Black/Black leather LSD CD/MP3 XM satellite 5 speed manual VIN#1745 Fiamm horn Magnaflow Quad Tip Exhaust |
