I've got the same problem so I'd love to do this, but I have a few questions for clarification:
Was the engine hot or cold?
Which hose were you squeezing? Could you take a picture of it with you pointing at it or circle it in Paint or something to make it dummy-proof for future forum dwellers?
Was the coolant cap on or off during this squeezing?
Brad
2008 Sky Redline
Chili Pepper Red
Kazera KZ-K w/ Dunlop *Specs
Dragging this thread up because I came up with a modified version of this process. I have published a write up complete with video on the Solstice Side because they had a couple folks asking about this recently. Here is a link: Overheating problems - Page 3 - Pontiac Solstice Forum
I tried the fix that you described here and it worked great... But...when the air temperature is below freezing, the condition arises again.
I had a thought today about this and was wondering...
On the overflow reservoir... If I remove the compression fitting and rubber hose on the overflow inlet , insert a tight fitting, smaller diameter tube down into the liquid, and reattach the rubber hose and compression fitting, would this eliminate the condition? I think it would, as it would block air from being sucked back into the engine block. You all seem to have experienced the issue more than I.
My Sky was reaching 240 at lunch today so I went home and Googled temp problems on Sky and Sol.
I found this thread and I watched the videos, man I have to say it worked right away like a charm.
Thank you so much for your help!!!
2008 silver pearl redline
red leather
GM passenger cab tonneau
Remote licenseplate
Lil chromies
kappawindscreen
kappasprings
Opel GT taillights
Opel GT wheel caps
Opel GT foormats
Opel GT grill
Opel GT waterfall
NO ANTENNAS
I'm keeping this thread semi new. Today I had to use GSs videos to get an air bubble out. Normally I don't see over 199, and hit 237 at Braums last night. So this morning i did the squeeze lock method as I'm calling it, and it worked fantastic. I had to WORK to get the car up to 199, even idling it would ony briefly touch it and go back to 192-196. This is a very simple method for getting little air bubbles out until such time the valves are installed. My 5 years is almost up on the coolant so I will be installing the valves when changing the coolant. Using the tomatosoup method with the pump for filling, and finishing off with this method to fine tune the bubbles out.
Show chrome SE rims, Vogues
I'm glad someone brotched this subject for me because as someone who is not super mechanically inclined (yes I've changed a radiator and do oil changes myself sometimes). I was wondering when I was driving before what the temp should be. I'm used to a gauge telling me its hot or cold... not a temp readout. So I'm guessing the 220ish I've seen is high from what I'm reading here and I need to try this method of getting the air out...
Glad to see my particular skill set is still helping others.
I am planning on having the check valves installed on both of our Skys when we do our first coolant changes. We haven't had any issue with either car since I purged the air out of both. But I am thinking it would still be a good preventative measure to take, and the time to do it is during a coolant flush.
Sent from my DALEK MOBILE DEVICE using Exterminate.Com Free App
