oh no....having problems
5 days ago while driving, my check engine light came on. Onstar said it was O2 sensor and a bunch of other sensors. Brought it in the next day and they said they replaced a fuse and everything was fine.
Driving home (after the dealer closed) the light came on again. Onstar says same problem. The onstar guy thought it was weird because my mass sensor, O2 sensor, exhaust sensor and another sensor was sending out error codes. He felt that since they were "unrelated " sensors that I could have blown a fuse again. Anyone have this problem and what did you do. Thanks in advance. Mike |
#2 (permalink) |
Curious if you have RL or 2.4 Sky? I have the Red Line and my Check Engine light has been going off a lot and they are looking into Turbo problems. It seems to be triggered by relatively quick acceleration. Not flooring it, but quick acceleration to 45mph or 55mph from zero and getting 20 to 24 lbs turbo boost. Do that about 5 times and Check Engine light goes off. They have worked on it 3 times now... thought it was fixed and it came back on within hours of the last fix. GM engineer is coming into dealer to try a shot at it next
#4 (permalink) |
I think replacement of the chip is on their list of things to try next. I've pushed the car some, but I'm really not pushing the engine that hard. I'm hoping the GM Engineer will have seen this before. I read in one of the other forums they had to replace the Turbo charger. All I want is a working car during prime convertible weather
#5 (permalink) |
Had it in today. They told me a wire cover that runs near the engine was melted and shorting. They replaced the wire. When they pulled it up for me to pick up, the check engine light was on again.
They take it back in and the mechanic said he forgot to wire the O2 sensor back on. Drove it home, so far so good. |
#6 (permalink) |
Did they check the ends of the other wire harnesses? when mine were checked , I was told most were not all the way connected and fraying/melting..... Worth a look! SkyBaby
Whats NOT to Love??? I would much rather stand out in a crowd and be noticed than life just pass me by while I am bitter!www.kappascoasttocoast.com www.kustomkaps.com www.flameball.com |
#7 (permalink) |
Every once in a while my 'check motor light' also comes on.
Allstar finds no codes and it normally goes off by itself after a few days. I believe it was on only once while at the dealers for a oil change. They found no reason and reset system. What seems to trigger a light is when I am going down an incline using the motor compression as my brake. Oh well ... ![]()
"Lucifer" is my name! Deposit:4-11-06 & Titled:11-28-06 SKY "Red Line" Silver Pearl, Black Wings on it's back, Bloody Red interior, Dejon intercooler/Solo Exhaust, Robert's screen. If you suddenly feel warm, it is just me passing through grinning! |
#10 (permalink) |
Sky Pilot, I get 24's and 25's no problem, and so perhaps that may help indicate the problem, perhaps the "boost" limiter isn't working and 20 psi is max??
I can get it to show 24 & 25 psi boost by accelerating in 2nd gear with gas pedal down about 3/4 to the floor, don't even have to floor it the whole way. Perhaps this might help the Techs. They haven't called me back so I'm still driving it. CEL is on, but still getting lots and lots of boost. Much better performance than before CEL the first time. |
