Old 04-16-2008, 08:42 PM   #1 (permalink)
Sky 2.0L Big-Bore Throttle Body
I am interested in getting the Big Bore Throttle Body from SMS. I have read a lot on the use and installation on the Sky 2.4 but have not noted on the RL use. Has anyone installed it on their RL? Has anyone did on their own if so was it difficult? I would appreciate any advise on the installation of the Throttle body on the RL.
Benedetto is offline   Reply With Quote
Old 04-16-2008, 08:47 PM   #2 (permalink)
Bruce's Avatar
Had one on my 2.4
I liked what the big bore throttle body did with my 2.4 so I had one installed on my RL. I don't know much about the installation though.
Midnight Blue RL
Tan Top/ Black Tan Seats
3 pedals
6-Disc/XM
Fikse Wheels
Fujita CAI
SMS intercooler pipes
BBTB
RPI GT Exhaust
RPI stage 2 intercooler
Bruce is offline   Reply With Quote
Old 04-16-2008, 11:41 PM   #3 (permalink)
What is the point of a bigger throttle body if no one is port matching the intake manifold?
Its not worth it imo, unless you have a sheet metal intake manifold and pushing 500hp or more i dont see the point. Spend your money elsewhere like on an exhaust/hiflow cat/intercooler.
2007 Solstice gxp
shabby is online now   Reply With Quote
Old 04-17-2008, 03:10 AM   #4 (permalink)
SSGTBARCLAY's Avatar
My Photos: (14)
Send a message via Yahoo to SSGTBARCLAY
As far as the Redline goes is it a big increase in HP and if you wouldn't ,ind posting what you have found about this because I am interested in this also.
2007 Red Sky Redline (Doing It Topless!!!)
-Eibach Sportline Lowering Springs
-Pioneer AVIC-D3 DVD/GPS/Bluetooth/IPOD
-RPi GT Series Exhaust, RPi Intercooler Stage 2, RPi Down Pipe
http://www.imsaturn.com/profile/William
SSGTBARCLAY is offline   Reply With Quote
Old 04-17-2008, 02:53 PM   #5 (permalink)
compdoc777's Avatar
I would not think one would see a big increase because of the boost maybe a little crisper throttle response.
I guess it would be the CFM that would be affected. So might help through out the power band. But, yes unless it is port matched then what is the gain. I would think there would be more turbulance from the unmatched ports.
I know a guy that will take the stock and bore it out and port match the TB to the Intake.
compdoc777 is online now   Reply With Quote
Old 11-11-2008, 04:24 PM   #6 (permalink)
I know this is a old topic but i just asked this question to SMS. They told me 3-5whp.
I plan on changing out the intercooler and all on mine so im sure by the end of everything it would have adding 10-12whp over stock.
radzer0 is online now   Reply With Quote
Old 11-11-2008, 05:43 PM   #7 (permalink)
JonyMac's Avatar
I did mine. I bought it from SMS, but made the mistake of cleaning the orange paint off the inside of the throttle body before installing. If you do buy it, the orange paint is there for a reason - to perfectly seal the butterfly valve to the sides of the bored out TB. Otherwise you end up with a high RPM idle and CELs. I pulled it back off, re-sealed it with nail polish, reinstalled, cleared my CEL and RPMs at idle returned to normal. Have been running it now for 4 weeks without problems.
I cannot vouch for how many WHP it increases, but the theory is sound. When you look at the larger bored out TB next to the stock, there is a big difference between the two in how much air can make it through. My understanding is more air is more better.
It is not that difficult to remove an replace - get yourself a short multi-angle socket driver - it will make life considerably easier. Also, getting the data/electrical connector off the TB can be tricky - unbolt the TB first, and then you can spin it to get to the harness - undo the harness clip and then squeeze the harness near the base and it will slide off.
JonyMac is offline   Reply With Quote
Old 11-11-2008, 07:22 PM   #8 (permalink)
Chris@HPTuners says...
They(ecm) actually use the pressure drop across the throttle body (as an orifice) to estimate the airflow.
Again i wouldn't touch the throttle body until there's full control of the ecm, currently majority is unlocked but not everything.
2007 Solstice gxp
Old 11-11-2008, 09:20 PM   #9 (permalink)
ggccg's Avatar
It's not that you get more air into the engine. On the 2.4L you suck in 2.4L of air each cycle regardless of the size of the throttle aperture. What you get is the same amount of air delivered with less friction due to the bigger diameter. Any increase in HP is really just a savings in the energy needed to suck in the air.
