Old 04-20-2008, 01:52 PM   #1 (permalink)
First 2000
Sky Door Stuck
Passenger door won't open either with the inside or outside handle!
Cable problem?
Anyone out there know how to open door as I cannot get door panel off as door won't open at all!
rmyar is offline   Reply With Quote
Old 04-20-2008, 02:11 PM   #2 (permalink)
jel
jel's Avatar
This is a tough one. You'll need a good pen light. Make sure the window is up. The triangle piece behind the door pull comes off. It's held in place with snaps. Give it a forceful pull and it will come out. Behind this is two screws. If you remove those screws, you'll have more play in the door panel. If you can get some long needle nose pliers up there you may be able to reach the cable. You'll have to be basically laying across both seats to get into a good position.
Old 04-20-2008, 02:13 PM   #3 (permalink)
Skip's Avatar
It is under warrenty , take it to the dealership and let the tech pull his hair out....Skip....
Old 04-20-2008, 02:16 PM   #4 (permalink)
jel
jel's Avatar
Yeah, or that.
Old 04-20-2008, 07:27 PM   #5 (permalink)
First 2000
Unfortunately, it is not under warranty as I have >38,000 miles in under 2 years
Old 04-20-2008, 08:50 PM   #6 (permalink)
Skip's Avatar
Well now that makes a differance. I suggest that you try a slim-jim in the door. It would seem that you could get the rod to move and then the door would open...Skip....
Old 04-20-2008, 08:57 PM   #7 (permalink)
more than likely it's a clamp shell on one of the rods that popped loose.
this a common place thing that happens on line quite a bit.
we had it on the vue door line, the ion door line... and soon to be chevrolet traverse door line. it's a problem that follows all GM products. usually it's never and issue but it happens from time to time. a team member probably didn't double check to enusre it was clamped tightly but they tend to work themselves loose over time.
and no. there is no easy way to get to it with the door shut. take it to the dealer.
thejewcanoe is offline   Reply With Quote
Old 04-20-2008, 09:10 PM   #8 (permalink)
jel
jel's Avatar
If you can't do it by going up through the hole behind the piece I described, you can either take it to a dealer or take the door off yourself. It sounds difficult, but if you take your time, it's not that hard. Here's a couple pictures that may help you if you decide to do it yourself.
Old 04-30-2008, 01:07 PM   #9 (permalink)
First 2000
Thanks
This information did help. Was able to see the cable but not reach it. The top of the door panel gives enough with it closed to grab the cable and open the door.
Problem is the inside pull handle. Hole for the cable is streched. If it happens again, I will need a new handle.
Again, thank you for your help with this problem.
Old 04-30-2008, 01:12 PM   #10 (permalink)
jel
jel's Avatar
Glad it worked. You can remove the entire door panel and adjust the cable so it's tighter. Good luck.
