Sky horn now sounds like tootsie toy
Maybe that high water I hit the other day flooded out the horn but now my Sky's horn is about 50 dB and sounds something Little Tykes would put on one of the plastic tootsie toys. Would I be better off replacing the puppy with one of the Fiamm horns or try to nick a replacement from another Sky? Or maybe just drop a pair of air horns in?
Für Elise – Support the Heart & Breast Cancer Foundations |
#2 (permalink) |
The Sky horn is already a Fiamm Low Note - what many of us have done is just add the Fiamm High Note to it. They are only about $15 each.
"Saffyre" 2008 Midnight Blue RL/Black/Black Leather / 5-spd w/Spoiler Magnaflow 3" Quad tip / Chrome Wheels / On Star / 6 CD XM Monsoon / Splash Guards / GT Antenna / WindRestrictor V2 www.imsaturn.com/profile/Celt |
#3 (permalink) | |
"He's dead, Jim" comes to mind. Air horns on a Sky? It's your ride, do what makes you happy. I'd hate to be the tech working in the stall next to your car. We techs have a habit of honking the horns before we pull out of the stall to alert people in the area. An air horn would give me a heart attack for sure! It's a standard GM horn. Go to the junk yard and yank one out of an Ion or Vue. Bring a 9 volt battery with you, cut the harness a few inches from the connector, hook it up to the battery and check its blow. $5.00 fix.
Stephen Saturn Certified Technician GM-ASEP Graduate, FCCJ class of 2003 Maria (139794) - 07, Auto, Monsoon, Stubbie |
#6 (permalink) |
Dark Shadows Horn
Well, my horn died. It then came back to life for about two weeks. The I must have driven a wood stake into it because it's dead now.
SO, is the FIAMM the best horn or would a WOLO do as well? Since I dive on the Xway every day to & from work I'd really like something that can be heard over that K-Whopper's jake brakes.
#7 (permalink) | |
My Horn Mod |
#9 (permalink) |
It seems one little thing was overlooked. GM uses a proprietary connector between the horn and wiring. Instead of spade connectors it uses post & hole connectors. So crack out your wire cutters and heat shrink tubing.
#10 (permalink) |
have both the fiamm and the Wolo badboy. I like the fiamm horns the best for the sky because it takes the Wolo a second to get started up. I put the Wolo on my old truck. and the high and low fiamm horns on the Sky.
You can unplug the connector from the stock horn and solder wires to the contacts so that you can connect any horn.
'07 2.4 Liter Polar White With Tan Trim L.S. Differential B&G Springs and Dampers,Eibach Stabilizers Dual Filter Fugita CAI SMS BBTB, Vector tune Monsoon Stereo,Six disk changer PDA and 350GB hardrive space for audio Last edited by gadget : 08-19-2008 at 10:05 PM. |
#11 (permalink) |
Well, I got a pair of hi-low blasters installed with no soldering or damaging of the original connectors. Sorry I didn't take any pix, but here's what I did. Some of the parts and pieces were leftovers from installing car radios. The electrical parts can be found at Radio Shack or a car parts store.
Parts used: 4 x 1/4" blade connectors (most kits come w/2) 2 x 14 - 16 gauge crimp connectors (mine came with blade connectors) radio mounting bracket or similar 18" - 24" 14 gauge wire 1/2" washers or like to use as spacers. black heat shrink tubing Electrical tape (NOT friction tape) Cut 14 gauge wire into 4 pieces, around 4" - 5" long. Strip wires on both ends far enough back so copper wire fits into blade connectors. On one end twist the exposed copper of two wires together. Slip a black heat shrink tubing over the wires and insert into the blade connector that came with the crimp connectors. Slide the tubing over the end of the connector after crimping the connector tight. Use a match, light, hair dryer, whatever to shrink the tubing. Set aside. Using a razor knife, cut open the protective tube over the car horn wiring harness, exposing about 2" of the wires. (Do NOT strip insulation.) Attach the crimp connectors to the exposed wires at an angle to each other. This makes it easier to attach the blade connectors. Open the underhood fuse box on the passenger side and remove fuse 60 (Horn). Disconnect the power connector from the OEM horn. You'll need a small blade screwdriver to unlock the connector. Remove the OEM horn and mounting bracket. Take the radio bracket and place onto the two screws where the horn bracket was. The radio bracket I used had an adjusting hole in one end. Measure the length so the bracket does NOT touch the air intake. Remove the bracket and cut it to length. I just used a pair of pliers and repeatedly bent it. Wrap the cut end with several layers of tape. This is to protect the air intake and for sound deadening. Place the bracket over the two screws and secure it to the left-hand screw. Attach one horn to the other end of the bracket. Before securing it with a nut, wrap several layers of electrical tape. This is again for sound deadening and to prevent any shorts from the next step. Tighten down the horn to the bracket. Using the bracket that came with the horn kit, loosely attach the second horn. Place bracket onto right hand screw and determine how many washers or spacers are needed. Remove the bracket, place the washers / spacers onto the right-hand screw. Attach the second horn to this bracket loosely tightening the nut and place the bracket onto right hand screw. Adjust the horn trumpet position. I placed both of mine to point down. Remove the bracket and tighten the horn to the bracket. Attach the bracket to the right hand screw and tighten down the nut. I included a locking washer next to the nut. Take the wires previously attached to the blade connectors and connect them to the crimp connectors on the wiring harness. Attach the other ends to the horns, making sure the wires go to the same terminals on the horns. Check all connections and then reinsert the 10 amp fuse into socket 60. Test the horn. If it works, wrap the original OEM connector in electrical tape for moisture protection. I taped it to the air intake to keep it out of the way. It's a good idea to also tape the crimp connectors. Close the hood and hit the highway. Hope I didn't forget anything. This method allows you to replace the OEM horns if you like.
Für Elise – Support the Heart & Breast Cancer Foundations Last edited by RealGomer : 08-20-2008 at 08:19 PM. |
#12 (permalink) |
That'll work. I didn't cut into the stock harness though. The socket that is on the stock horn will unsnap off of the horn on the back side there is two contacts, I just soldered some wire onto the socket contacts and hooked my horns up to them. then I plugged it back into the harness.
'07 2.4 Liter Polar White With Tan Trim L.S. Differential B&G Springs and Dampers,Eibach Stabilizers Dual Filter Fugita CAI SMS BBTB, Vector tune Monsoon Stereo,Six disk changer PDA and 350GB hardrive space for audio |
#13 (permalink) |
I just added a set of Hella Super tones. Their dual horns, with 500 & 300 mgz frequencies. THey sound way better and louder that stock. They do require a relay kit. Its sort of like installing wiring for fog lights. It also makes the car faster.
09 Sky R/L % Financing!! Built 6/25/08 Bought 7/7/08 Red Leather Auto Chrome 6-Disc Monsoon Spoiler |
#15 (permalink) | |
Put one of those musical tune horns in, like la cuaracha. That would be pimp!
2005 Storm Titanium Lotus Elise Fort Lewis IT Specialist National Guard Member 1-161 AR Quote:
