Sky lift points - Saturn Sky Forums: Saturn Sky Forum
post #1 of 9 (permalink) Old 03-22-2007, 10:29 PM Thread Starter
Sky lift points
We just picked up our Sky Redline on Monday after waiting for almost 9 months. Driving it home on a wet messy road we realized that we need to install splash guards. Since I have to remove the wheels to install them, I would like to know if anyone knows where the lift points are located under the car? The owners manual says nothing about them since the car does not come with a jack. Thanks.
wrwhite is offline
post #2 of 9 (permalink) Old 03-22-2007, 11:39 PM
xmicro_Redline's Avatar
Location: Beautiful Las Vegas, Where everyday is a sunny one
You can do searches for this kind of stuff.
Here is a helping hand:
Beware of Missed Lifting Points
With pictures!
xmicro_Redline is offline
post #3 of 9 (permalink) Old 03-23-2007, 12:19 AM
joker70's Avatar
lift points
If you look under the car you will find 2 areas that are used to lift the car they have a hole in the center of them and look like this
joker70 is offline
post #4 of 9 (permalink) Old 03-23-2007, 02:12 AM
Quoted: 7 Post(s)
if u r skillful, u will not have to lift the car...it can be done without a jack.
marlboromike is offline
post #5 of 9 (permalink) Old 03-23-2007, 02:24 AM
JohnD's Avatar
Lots of photos...
The lift points here: Painted Calipers
Overall technique on the whole thread, which relates to painted calipers here: Painted Calipers
Check out My Photos!
JohnD is offline
post #6 of 9 (permalink) Old 03-23-2007, 09:55 AM
MidniteBlues's Avatar
Quoted: 8 Post(s)
Or no need to remove any wheels IF you have the proper tools. One being a what I would call a ratchet philips head screw driver for the rear wheels mainly--I did not remove any wheels when I installed my set--
MidniteBlues is offline
post #7 of 9 (permalink) Old 03-23-2007, 10:44 AM
navcop's Avatar
I agree, it took me less than a hour and no need to remove the wheels.
navcop is offline
post #8 of 9 (permalink) Old 03-23-2007, 01:10 PM
Rick Tinley Park's Avatar
Absolutely NO NEED to pull the wheels -- And you'll be done in an hour.
This will help immensly
Adding SKY Splash Guards
Rick Tinley Park
Delivered June 15, 2006
VIN - 3099
Sunburst Yellow
Painted Calipers
Brushed aluminum Interior panels
GM CAI
Yellow Engine cover and Fuse box
Custom Lighted Door Sills (WR)
Name - Sunni1
IL License # - YLO SKY 1
Rick Tinley Park is offline
post #9 of 9 (permalink) Old 03-30-2007, 09:37 AM
Retired from Active Duty Administrator ;-)
KappaMan's Avatar
I think there are special "lift pucks" now available for the Solstice/SKY so they have a pad to lift on the rear of the car (goes in the shipping hole). The front lift location is either CAREFULLY on the shipping hole area (WITHOUT CRUSHING THE ROCKER) or just inside the front wheel.
http://www.solsticeforum.com/forum/s...ad.php?t=19139
and
http://www.solsticeforum.com/forum/s...24&postcount=7
I'd recommend these three points for jacking - use a flat surface, and on the rails take care and do NOT crush the outer sheet metal.
You can prolly also safely jack on the front cross beam, but be very careful not to jack on the steering gear or stabilizer bars.
liftingpoint
jackingpoint
liftingpoints
jackingpoints
liftpoint
liftpoints
jackingpointinfo
jackingpointinformation
liftingpointinfo
liftingpointinformation
File Type: pdf Solstice Lifting and Jacking Page 1.pdf (354.5 KB, 189 views)
File Type: pdf Solstice Lifting and Jacking Page 2.pdf (613.1 KB, 162 views)
KappaMan is offline
Human Verification
