Sky/Sol convertible top problem
I've had my Red Line less than a year and recently dicovered a serious flaw in the top. At the hinge point on both sides just above the window, the edge of the roof frame is cutting through the cloth padding that's supposed to protect the top from the frame. On the drivers side it's bad enough that the rubber strip at the outside edge of the pad protrudes when I raise the top and catches on the frame. If not for this exposure the problem would probably have gone undetected until it cut clear through the top. If GM hasn't discovered the problem and fixed it on later units, they're going to be seeing an avalanche of complaints. If they know about it and aren't issuing a bulletin, buyer be ware!
CHECK YOUR TOP! And if you're about to buy a Sky/Sol, GET THE EXTENDED WARRANTEE! Last edited by California Skyway : 10-17-2007 at 12:53 PM. Reason: Add pix |
#2 (permalink) |
My top just had this problem. It's caused by the cables inside snapping and tearing the inside of the top. Mine was covered under warranty. I had to wait about 6 weeks for the top to come in, but the Sky was only in the shop for two days. My question is this: I read somewhere that when you get your top replaced, you cant put it down for 7 days. The dealer didn't say anything about it, but does anyone know if there is any truth to this?
#4 (permalink) |
Silvereyes
The only reason I can see why they do not want the top down is to streach the fabric. Now far beknowest to me but as long as the top is up when you tant driving it, I would not be worrying about top down driving...Skip...
Be kinder than necessary, for everyone you meet is fighting some kind of battle. Resident Redneck of the forum and Birthday Greeter Gator skin is good as boots... |
#5 (permalink) |
I got my new top
After raising the issue to the General Manager level the dealer agreed to replace the top. The new one seems to be improved in several ways, inclluding slightly heavier fabric and different protective pads where the wear occurred. They subbed out the installation to a local upholstery place, who did a good job. I think they've already done quite a few. As far as not putting the top down, I was told it would be better if it sat in the sun for a day to let the fabric relax. They also replaced the screws that attach the latch bar to the clamshell with low-profile ones. If you have a Lexan windscreen you should have this done regardless so there's no chance of the rubber rain gutter being cut. I don't care what anyone says, you shouldn't have to remove the thing every time you put the top up!
#6 (permalink) |
Sky top replaced
I just got my top replaced last week due to wear and fraying on the driver's side trim/seam where the window was rubbing every time I closed the door with the window and the top UP (where the glass curves from vertical to horizontal). It took the dealership 2 weeks for the top to come in and 2 days to get it installed (outsourced). I also had to have the hood vents(?) replaced becaused the had 'bowed' and were coming unglued at the center. How odd is that? Hood too hot? I dunno...but I have noticed a significantly tighter top. I can even hear the springs stretching as I put the top up or down. It also seems that the new top has a lower profile than previously...that is cool for me..I like it! Saturn said to bring the receipt for that and they'll cut me a check to cover the costs. Overall...I've taken the car in twice for warrantied service and I always have resevations beforehand. They did an excellent job with the new top BTW...neither side rubs w/the doors' glass anymore...but I'm always left with a feeling of waiting for the other shoe to drop. ![]()
Bloody Cool in Tx. ChiliPepperRed/Black Int.,Top Splash Guards Wheel Locks Tinted Windows Black Shorter Antenna Red Calipers (nice touch) |
#7 (permalink) |
flippers on each side
what ever they are called, on each side of the back trim where the top folds into when you put it up. I had those replaced, they are spring mounted and has a steel cable attached. someone let me know, are these things suppose to go up automatic when you raise the top from the trunk by being pulled with the little steel cables or what? since I have had them replaced, I have to flip them up manually in order to get the top to seat in the rubber gasket. Maybe they forgot to adjust the cables.
someone PM me with an answer if you know. |
#8 (permalink) | |
#11 (permalink) | |
#14 (permalink) |
GM Parts Pricing
I was only able to find the part listed under under Pontiac Solstice (apparently GM doesn't actually consider Saturn to be one of its offspring). The retail is about $2G. and you can go shopping for someone to install it. Barring any miracles, I think the current design is as good as it's going to get.
