Old 02-24-2008, 10:23 PM   #1 (permalink)
Junior Member
tire jack for lowered sky
I lowered my sky with the Gravana Eibach 38105.140 Solstice/Sky Pro Kit Sport Lowering Springs - 1"Front/1.3" Rear Drop. I cannot get my regular jack under the car. Does anyone know where I can get a low profile jack in case I ever need to change the tire???
superchargedboy is offline   Reply With Quote
Old 02-25-2008, 06:43 PM   #2 (permalink)
Make yourself a simple wooden ramp out of three or four 2 by 10s or 12s. Nail or screw them so as to make a pyramid like structure, begin with the longest on the bottom and gradually work your way up. Use it on the front or the rear, all you need is a few inches and your jack will fit! Drill a hole in it and then hang it on the garage wall.... easy in theory, (i never tried it)... Good Luck! Puggs
______________
________________________
___________________________________
__________________________________________________
puggsleyssky is offline   Reply With Quote
Old 02-25-2008, 06:47 PM   #3 (permalink)
BTW!! Make the top board long enough so that you don't run off of the ramp, or glue and screw a 2 X 2 on the end to trigger you to brake! Kind of like the old oil change ramps we all used , but much lower... Puggs
Old 02-25-2008, 09:51 PM   #4 (permalink)
I use a chev tracker scissor jack, they fold down to 2", I carry it in my sky all the time . Dave witman
Dave witman is offline   Reply With Quote
Old 02-25-2008, 10:44 PM   #5 (permalink)
gadget's Avatar
If there's a harbor freight around near you they have a pretty decent selection of floor jacks.I bought a #3000 alluminum jack for $130 3.54" minimum saddle height. Not something you would want to carry in the car though
'07 2.4 Liter
Polar White With Tan Trim
L.S. Differential
Dual Filter Fugita CAI
SMS BBTB, Vector tune
Old 02-25-2008, 11:06 PM   #6 (permalink)
BigSkyCountry's Avatar
Is it still ok to jack from the center of the differential? Ray
2008 R/L with no cute little name...
Stick, Midnight Blue, Black/Tan Leather
Tan Top, Monsoon 6 Disc, Spoiler, Fujita CAI, MagnaFlow 3" CatBack, El Rancho red poly swaybar bushings
...and a block heater, unfortunately
BigSkyCountry is offline   Reply With Quote
Old 02-25-2008, 11:22 PM   #7 (permalink)
gadget's Avatar
I don't know. I stick to where GM says to lift it from.
I suppose as long as it doesn't put a lot of stress on the drivetrain or mess up any drain plugs, tubing etc. I haven't ever looked that closely at the way the Diff is anchored to the chassis.
'07 2.4 Liter
L.S. Differential
Old 02-25-2008, 11:46 PM   #8 (permalink)
Supporting Member
JohnD's Avatar
My Photos: (73)
Or how strong the outer differential casing is. Isn't it made of aluminum? The casing is not meant to support the weight of the car! You have to consider the structure of the differential itself in addition to how it is mounted to the body!
Here are some pictures of the racing jack I use on SPIRIT (It is very low-profile) and where I put the jackstands. I lift from the factory recommended lift points.
tire-jack-lowered-sky-dscf0653.jpg  tire-jack-lowered-sky-dscf0655.jpg  tire-jack-lowered-sky-stand1.jpg  tire-jack-lowered-sky-stands2.jpg
Check out My Photos!
Old 02-25-2008, 11:50 PM   #9 (permalink)
gadget's Avatar
That's obviously the better way to lift and support it
That jack is pretty much the same thing I've got. Mine is not blue anodized and has a carry handle on both sides.
'07 2.4 Liter
L.S. Differential
Old 02-28-2008, 11:19 AM   #10 (permalink)
Supporting Member
RedHeaded RedLine's Avatar
My Photos: (9)
My dealership does.
JEGS 80034 - JEGS 2-Ton Aluminum Floor Jack - JEGS
-J
