Tire Rotation/Balance
I don't have my manual in front of me (car is in for service), but I had my tires rotated and balanced at 4500 miles a while ago (at 6800 now), but I keep getting flagged through On-star montly reports that it's due for tire maintanence.
I called On-star to find out how to update the information so it reflects that I already had my tires rotated at the dealer and on-star told me that the dealer should have performed some procedure to reset the computer. Is this true? I knew about the tire pressure sensor procedure, but didn't know about the anything else. WHats the story on this? |
#2 (permalink) |
The dealer should have reassigned the sensors.
The TPMS knows where a tire is located through the TPMS sensor in each tire. If you move the front right to the back right and don't re-assign the sensor, the TPMS will continue to report that tire pressure as front right even though it's now sitting on the back right. The dealer has a very simply method to re-assign the TPMS and should have done it on rotation. There is a more involved method you can use to do it (see the owner's manual), but I've yet to get it to work for me. You can check to see if they did the reassignment by bleeding some air from one of your tires and then checking the DIC for pressure. If the pressure drop diplayed on the DIC doesn't match the tire position of the tire you bled, then dealer didn't do the TPMS re-assign. It will be interesting if this the case, as I didn't think Onstar tracked the TPMS reset...but maybe they do. And it's a good check.
#5 (permalink) |
Well, if you don't think the job is getting done, or don't trust whom ever rotates your tires, simple method to confirm is to mark 2 of them, or a rim, if dirty, a finger smudge would do.. and check them when you pick the car up..
TODAY IS ANOTHER GOOD DAY, I WOKE UP ON THIS SIDE OF THE DIRT.. |
#6 (permalink) | |
We try to have the car clean when it goes in, one as a courtesy, two they now know not to wash it. You could just go with a chalk mark. We like to rotate them back at the house. –J
Drill Here - Drill Now I am offended by people who are too easily offended! |
