Torque Sensing Limited Slip Differential
I was wondering if someone could make sense of the torque sensing limited slip differential option.
I don't really know what the slip differential does. Can someone clarify the need or necessity of this option. Thanks JFig |
#2 (permalink) |
A limited slip diff keeps one tire from spinning while the other remains motionless by tying each end of the axle together. It's called a limited slip becasue one tire can spin faster/slower then the other, but ony to a point. It's a lot better for traction than when you have completly independent rear axle.
#3 (permalink) |
Just to add to the previous very acurate description, you gain the most from limited slip traction through a turn. A non-locking differential (most) will allow the inside wheel to spin as weight is being transferred onto the outside wheels. When you have a limited slip differential you get power shifted away for the inside wheel and more power on the wheel with traction (outside). This gives the car better control and speed through a turn making it a lot more fun to drive!
#5 (permalink) | |
Of course if you are really into drag racing (and you don't drive the car in the winter) you'd get a locking diff. |
#6 (permalink) | |
Moderator Emeritus
#7 (permalink) | |
Tim Johnson City, Tenessee Nitesky 2 2008 Automatic, premimum trim Chilipepper red Black leather, black top. painted wheels. |
#8 (permalink) | |
#9 (permalink) | |
What you won't notice (as I did not feel it nor have I seen it written) is scrubbing of the tires during sharp turns on dry pavement as did Posi on a solid rear axle from 1978,
The Sky's the limit! |
#11 (permalink) | |
Regards, S.D. ![]()
2nd SKY: 2008 RED on Red/Black Lthr RedLine Delivered - 7/14/08 Loaded Auto 3" Magnaflow, Lil Chromies & CAI 1st SKY: (Traded) 2007 Silver Graphite RedLine Loaded (-6CD) Deposit - 4/11/06 Order # KFDHH7 - 5/27/06 Delivered - 2/21/07 |
#12 (permalink) | |
2006 Solstice, Mysterious [sold] - Born Sept 8th, 2005 2007 Solstice GXP, Mean - Born Nov 17th, 2006 |
