Old 07-30-2008, 10:27 PM   #1 (permalink)
SKY888's Avatar
My Photos: (4)
tpms from tirerack.com compatible with sky?
Hi,
when I ordered my new wheels and tires from tirerack.com, I also purchased tpms on each.
I was just wondering if these tpms from tirerack.com are compatible with our sky?
or should I remove the tpms from oem wheels and install them on my aftermarket wheel?
I am just getting sick of getting the SVC tire pressure alert on my DIC
thanks!
Next: Cry02 IC Spray
CAR SPECS & PHOTOS:
www.carsponsors.com/420576
SPONSORED BY:
aempower.com
autometer.com
killerglass.com
brailleauto.com
SKY888 is online now   Reply With Quote
Old 10-28-2008, 06:43 PM   #2 (permalink)
Hello,
What did you eventually do about this? I'm thinking of getting wheels for my Sky and have to figure out what to do regarding the TPMS. I'd really like to have the sensors on my new wheels.
Thanks,
Carlin
CDogg is offline   Reply With Quote
Old 10-29-2008, 09:11 AM   #3 (permalink)
Don't you just have to go through the calibration process in the manual when you swap to a new set of rims with the TPMS installed? From what i saw they are not complicated cost about $40 at napa for the 4 sensors and they just screw on the valve stem. And I thought you could just reuse the original ones on the car, or am I completely wrong on this?
Mrbeanca is offline   Reply With Quote
Old 10-29-2008, 11:48 AM   #4 (permalink)
Elff's Avatar
My Photos: (5)
The sensors attach to the back of the valve stem. In order to swap them to new rims, you would need to break the bead on the outside of the rim on both the old and new tire/rim combo, then transfer them over.
If you buy rims with tires and TPMS already installed, they will also be balanced, so all you need to do is install the rims and calibrate the sky
It's much easier. My co-worker just did this on his Mini Clubman.
Cool thing is, if you are going to be swapping rims and tires depending on the season or for autoX, moving forward you can calibrate or not for both sets.
Nugget 2003 Mini Cooper
Jack 2006 Buell XB12R
Old 10-29-2008, 11:54 AM   #5 (permalink)
Luv2BGrrl's Avatar
Send a message via AIM to Luv2BGrrl Send a message via Yahoo to Luv2BGrrl
Can these be retrofitted to a base sky? Does the 2.4 have the receiver for the TPMS?
Linda Ann
North Beach, MD
07 Silver Graphite with red/black
plate "SKYGRRL"
Mods:
VectorSports ECM
Third brake light, sequential rear and sidemarker turn signals
DMV Solstice and Sky Meetup Group
IMSaturn
MySpace
Luv2BGrrl is offline   Reply With Quote
Old 10-29-2008, 12:11 PM   #6 (permalink)
Elff's Avatar
My Photos: (5)
I do not know.
