Old 05-06-2006, 10:13 PM   #1 (permalink)
SkyMan 08's Avatar
My Photos: (16)
Water Leaks?
Friday it rained all day a few times very hard, I noticed there was water dripping off the bottom of the speaker housing on the passenger door, I opened the door and there was water in that little tray in the door sill plate, has anyone else had this problem? also I noticed today that the trunk mat was damp in one place, on the driver side in the back i don;t know if it may have been because they put the top down the other day while it was wet, I will keep an eye on that though...
Tim
Johnson City, Tenessee
Nitesky 2
2008 Automatic, premimum trim Chilipepper red Black leather, black top. painted wheels.
SkyMan 08 is offline   Reply With Quote
Old 05-07-2006, 08:17 AM   #2 (permalink)
Take it to your dealer and get new deck and window seals on it.
deluke is offline   Reply With Quote
Old 05-07-2006, 02:46 PM   #3 (permalink)
SkyMan 08's Avatar
My Photos: (16)
i noticed this morning after the rain last night the trunk was dry, but when i opened the passenger side door water ran out the bottom of the door for a little while... sounds like something is blocking the door drain when the door is closed
Tim
Nitesky 2
Old 05-07-2006, 03:48 PM   #4 (permalink)
skyfan's Avatar
No leaks in mine
I ran my Sky thru a commercial car wash twice with the pressure rinse to check for leaks. I found none in the trunk or inside. I say mine is pretty tight.
skyfan is offline   Reply With Quote
Old 05-07-2006, 05:25 PM   #5 (permalink)
SkyMan 08's Avatar
My Photos: (16)
Mine has been washed many times, it seems like this happens whenever it rains hard for several hours... next time it rains notice when you open the doors if water runs out the bottom... i have no leaks arounf the top and window seals fot the top, It is when the door fills up with water and it runs out the speaker hole, I am sure it can hold alot of water in there
Tim
Nitesky 2
Old 05-07-2006, 06:01 PM   #6 (permalink)
Skip's Avatar
More than likely the water you see in the door is what has run down the window and under the window seal where it is rolled up. In other words where the window goes up and down in the channel. To prove this duct tape the seal area where the window goes up and down and hose massive amounts of water on the window. After, open door and see if it has any water coming out the bottom weep holes of the door. Skip...tryin to be a long distance mechanic...
Old 05-07-2006, 06:42 PM   #7 (permalink)
HotSky's Avatar
Mine hasnt got wet yet but I think I will leave it out in the rain to test it.
HotSky is offline   Reply With Quote
Old 05-07-2006, 09:02 PM   #8 (permalink)
SkyMan 08's Avatar
My Photos: (16)
No car seals completely there, that is normal for any car though they all have waterdrains in the door but they are designed to let the water out as it gets in... for some reason the water does not come out until you open the door....
Tim
Nitesky 2
Old 05-07-2006, 09:44 PM   #9 (permalink)
Skip's Avatar
Tim for the water to get into the door it has to be the door to window seal leaking. I've taken off plenty of door covers and very very seldom do I detect any water leakage. As I said duct tape that seal and see if that keeps the water out. Iffen it does than Saturn owes you a new window to door seal. Now as to drainage of said door, there should be what they call weep holes on the bottom of the door. Iffen there is a little bit of crap from making the door than it might plug the holes. Either way you stand to lose the speaker and the electrical to that door unless it is fixed to your satisfaction. Skip...Tell me what happens.....
Old 05-07-2006, 10:26 PM   #10 (permalink)
SkyMan 08's Avatar
My Photos: (16)
I will have them look at it
Tim
Nitesky 2
Old 05-09-2006, 04:27 PM   #11 (permalink)
SkyMan 08's Avatar
My Photos: (16)
They wanted to keep my car for a couple days and i decided before I let them do that to see if I could find the leak myself..., I went to the local car wash and spent about 10 minutes spraying the passengers door with high pressure water.
Well even with all that water, no leaks, I don't understand, Was it my imagination or what? I guess now i will wait til I see it happen again before i jump to conclusions.... maybe it was something else, I did notice that sometimes I don't get the passenger window all the way up... maybe that is what it was ....
I guess with this car I am really being picky with it...
Tim
Nitesky 2
Old 05-09-2006, 04:48 PM   #12 (permalink)
Rick Tinley Park's Avatar
My Photos: (11)
I will be picky also.
This almost sounds like water from a certain angle... IE: side winds or only when driven through rain.... Try to duplicate what angle/conditions you were in before the last water you saw.
There are too many electronic goodies in the door to let it fill up!
Find out about my radio show
http://www.anj.westpm.net
Founder:
www.chicagolandroadsters.com
Rick Tinley Park
Delivered June 15, 2006
VIN - 3099
Sunburst Yellow
Name - Sunni1
IL License # - YLO SKY 1
Old 05-09-2006, 04:58 PM   #13 (permalink)
SkyMan 08's Avatar
My Photos: (16)
seems to have been both when it was parked and when I was driving, I tried it form about every angle I could aim it too....
Tim
Nitesky 2
Old 05-09-2006, 09:25 PM   #14 (permalink)
Luke Sky Watcher's Avatar
I just completed a 1800 mile trip with my SKY and on one day I drove at least 200 miles in rain. Some of it was so heavy you had to slow down to 45 on the interstate. Also, it rained while I was parked overnight. Not one drop of water anywhere. I felt pretty good.
It would be interesting to hear from others who have driven in a lot of rain.
Chili Pepper Red
Tan top/seats
Prem. trim
Audio System
Ordered 1/16/06-Del 4/19/ VIN # 1112
TAG- SKY 007
RL ordered - As above + XM
Deposit 8/9
11/30 3400 # KJJG5N
12/19 3800, 12/28 5000 VIN ..121981 Home 1/11/07 Thanks deluke
Luke Sky Watcher is offline   Reply With Quote
Old 05-09-2006, 10:01 PM   #15 (permalink)
virginiasky's Avatar
Just a thought about leak-testing....
Even though you tried the high-pressure hose, it may have been blasting the water across the leaky spot, and not allowing it to dribble in. Sorta like how the water goes up on the side of a waterslide when the slide has a bend in it. Maybe you should try filling buckets with water, and pouring them onto the roof where it meets the window. This deluge may better recreate a heavy, soaking rain. Pour the water at a good volume, taking like 10 seconds or so to empty the bucket rather than just an instantaneous dump.
Worth a shot, right?
I admit that right now my money says you didn't have the window shut tight. I have done this several times by accident with my car. My friend has a bimmer with the one-touch-up windows. I wish GM had that.
virginiasky is offline   Reply With Quote
Old 05-09-2006, 10:11 PM   #16 (permalink)
SunneySky's Avatar
Rain? What's that?
It hasn't rained here since I got my Sky... But it will rain plenty this summer - so I will look carefully for leaks
I LOVE MY SKY
Bluestone R/L with Tan roof
Manual
Billet Grille
HIDs
Race Precision GT exhaust
R/L CAI
Exhaust Depot Charge Pipes
In Dash GPS nav touchscreen XM radio & rear view camera
No more Black and Tan Base
SunneySky is offline   Reply With Quote
