Water Pump Replacement - Saturn Sky Forums: Saturn Sky Forum
post #1 of 41 (permalink) Old 08-04-2013, 09:12 AM Thread Starter
Ag_Sky's Avatar
I'm in the process of changing out my leaky water pump and have experienced some difficulties. I spent two hours getting the big hose off the thermostat housing. This was a pain!
When they installed the hose clap they positioned the tabs towards bottom of the hose. It took forever to work it around where I could get to it and move it back so I could get the hose off. I had to remove my exhaust manifold and undo a bunch of electrical connectors to move the wiring harness.
The good news is I was able to inspect my hi-flow cat. The bad news is the coils are melting and it looks nearly plugged.
How do you gut a cat?
Gutted!
And to top it off the thermostat is bad!
I'll see if I can get'er back on the road today.
2008 Saturn Sky LE5 Automatic
Custom Hypercoil Coilovers
425 # Front 550 # Rear
Koni SA shocks
Bridgestone Potenza RE760 Sport 255/45 R18
Solo Performance Exhaust
DDM Stage II Super Charger
HPTuners Calibration (working)
Ag_Sky is offline
post #2 of 41 (permalink) Old 08-04-2013, 10:26 AM
Quoted: 157 Post(s)
You are now scaring me...I see u have a 2008 2.4 engine and automatic. I have a 2006 build sky with 34K...so far I have absolutely no problems. You have me wondering WHEN (not laughing).
To give you some positive news...your Cat is under warranty for 10 yrs/100,000 miles. Mine went bad at 27K and of course it was replaced.
marlboromike is offline
post #3 of 41 (permalink) Old 08-04-2013, 01:30 PM
MidniteBlues's Avatar
Quoted: 9 Post(s)
His CAT was under warranty you mean..
MidniteBlues is offline
post #4 of 41 (permalink) Old 08-04-2013, 03:29 PM
L-N-F'n's Avatar
Hi-flow cats, don't have a 10 yrs/100,000 miles warranty.
Coupe 993 5mt. GMPP CAI, GMPP tune+ HPT, 3 inch catlles ext. Dejon Ic and Piping, AME w-m, Garrett Manifold, EFR 6758, Werks springs, 5th injector E42, CCW Werks rims 285 front-305 rear PScup's. Zok cross member, sway bars, back bone, LVFB. 407 WHP.
L-N-F'n is offline
post #5 of 41 (permalink) Old 08-04-2013, 03:38 PM
Quoted: 157 Post(s)
are we talking about the factory catalytic converter? If we r... we do have a 10yr/100,000 warranty on certain early model Kappas
post #6 of 41 (permalink) Old 08-04-2013, 05:02 PM
in the first picture it looks like you removed the cowl. my question is how did you remove the wiper arms after removing the nut?
RedRacer95 is offline
post #7 of 41 (permalink) Old 08-04-2013, 09:59 PM Thread Starter
Ag_Sky's Avatar
are we talking about the factory catalytic converter? ...
unfortunately not
Koni SA shocks
Ag_Sky is offline
post #8 of 41 (permalink) Old 08-04-2013, 10:08 PM Thread Starter
Ag_Sky's Avatar
Originally Posted by RedRacer95 View Post
...how did you remove the wiper arms after removing the nut?
I used a C clamp and a big slot screw driver. I positioned the fixed end of the c clamp under the wiper arm and adjusted the other end so the flat of the screw driver rested against it and the wiper stud. Then I slowly applied pressure to the handle to lift the wiper arm.
Koni SA shocks
Ag_Sky is offline
post #9 of 41 (permalink) Old 08-05-2013, 07:06 AM
christopher_2's Avatar
Quoted: 46 Post(s)
What is the brand of the CAT? How many miles are on it?
2007 (2.4L)
Solo Cat
Magnaflo Redline dual exhaust
Werks Turbo @ 10 PSI
FE2 shocks
ZOK anti-sway bars
christopher_2 is offline
post #10 of 41 (permalink) Old 08-05-2013, 08:13 AM
thanks. so it is pressed on basicly. and you pressed it off
post #11 of 41 (permalink) Old 08-05-2013, 01:38 PM Thread Starter
Ag_Sky's Avatar
It's a Performance Autowerks (PA), ~10,000 miles. This is the second one from PA. The first PA didn't last 3 months. I was using a octane booster, but I stopped because I thought it was causing the failure of the CATs.
The first one I tried was a Solo Performance Cat. I ran on it for couple of months before the coils in it started melting. All three have the same issue. the coil melts and collaspe.
The stock works no problem.
I'm giving up on trying to use a high flow cat.
Koni SA shocks
Ag_Sky is offline
post #12 of 41 (permalink) Old 08-05-2013, 01:44 PM Thread Starter
Ag_Sky's Avatar
I got a quote from a local Chevy dealer for a water pump replacement on a 2008 Saturn Sky 2.4L.
$969
Koni SA shocks
Ag_Sky is offline
post #13 of 41 (permalink) Old 08-05-2013, 02:37 PM
Quoted: 157 Post(s)
$969
Did u ever think of going to e bay...they go for anywhere from 40 dollars to 199 dollars brand new GM Delco.
post #14 of 41 (permalink) Old 08-05-2013, 03:35 PM
Quoted: 46 Post(s)
Great, I was thinking of gutting my old converter and putting a straight pipe inside. Now I think that is what I should have done, especially if that is all the longer the metal cats last.
2007 (2.4L)
Solo Cat
FE2 shocks
ZOK anti-sway bars
post #15 of 41 (permalink) Old 08-05-2013, 10:24 PM Thread Starter
Ag_Sky's Avatar
Mike:
The one I bought is from GMPartsCenter.net for $167.39 delivered to my door. The $969 price from the GM dealer includes labor, pump, and gaskets. I made $802 in 8 hours. Not bad for a shade tree mechanic.
Koni SA shocks
Ag_Sky is offline
Human Verification
