Old 09-09-2008, 09:25 PM   #1 (permalink)
3xHounds's Avatar
Whining Noise
I have a whine that sounds like it is coming from the rear of the car. The noise starts around 42 MPH and ceases as reach about 50 MPH. 08 RL automatic with around 9K. I have not noticed any problems with shifting. Does this sound like a wheel cylinder?
2008 Suburst Yellow RL
3xHounds is offline   Reply With Quote
Old 09-09-2008, 10:21 PM   #2 (permalink)
SKY888's Avatar
My Photos: (4)
are you in full throttle?
if so, it might be your turbo spooling?
Next: Cry02 IC Spray
CAR SPECS & PHOTOS:
www.carsponsors.com/420576
SPONSORED BY:
aempower.com
autometer.com
killerglass.com
brailleauto.com
SKY888 is online now   Reply With Quote
Old 09-10-2008, 07:38 AM   #3 (permalink)
Probably some gear whine. Within that speed range, does it change depending on load? Like if you're cruising in that range and you either lift off the throttle or accelerate does the noise get louder or quieter? Can't be a wheel cylinder since the car has rear discs. It can't be a wheel bearing since those may a rumble sound at half wheel speed.
If the whine changes pitch or presence with load, you are probably looking at a pinion bearing preload crush sleeve that is improperly set. If the pinion is allowed to move, it changes both the gear backlash and the engagement pattern, which causes the whine.
Three pedals
Red leather
Monsoon
Chrome rims
Old 09-10-2008, 08:39 AM   #4 (permalink)
3xHounds's Avatar
Yes, I meant wheel bearing. The whine occurs during casual driving through the band of about 42ish to 50 mph and then subsides. As far as increasing or decreasing in loudness with acceleration and deceleration I will have to pay closer attention and evaluate.
I normally have the music up and had not noticed before, so I do not know if it is new or I have been missing it.
Old 09-10-2008, 08:55 AM   #5 (permalink)
Ahnuld's Avatar
mine whistled... thought it was the rear deck adjustment being off and catching the wind
sounds odd.. but i think it was the stubby antennae I put onthe car previously... as soon as the antennae snapped off, the whistling stopped!
just a thought...
Photos below taken at Dover Airforce Base
Ahnuld is offline   Reply With Quote
Old 09-10-2008, 06:59 PM   #6 (permalink)
JRinKY's Avatar
3xHounds : I have a whine that sounds like it is coming from the rear of the car. The noise starts around 42 MPH and ceases as reach about 50 MPH. 08 RL automatic with around 9K. I have not noticed any problems with shifting. Does this sound like a wheel cylinder?
Some level of noise, especially if it comes and goes, can be considered normal. Obviously all noises are not normal, and some can be indications of problems, but the one you describe sounds like it is among the normal ones.
VIN 00252
2.4 Manual
Midnight Blue
