Saturn called me today with their diagnoses. It's the passenger pressance control module. Part is 377.82. With labor it's 626.67. I am currentyl waiting on the district support guy to call me back about getting this paid for. My reasoning is that it's a passenger sensor. 80% of the time there isn't a passenger! So out of the 34k miles that sensor saw usage about 6.8k miles.
That's insane. I feel Saturn should replace this free of charge. If not I would like to know what signal the mod sends to the ecu and just bypass the sensor and have the air bag on all the time. I can rig any voltage to go to the ecu with simple resistors. Bah! This is crap.
Today I will be removng the sensor from the seat and trying to fix it myself. Maybe just a loose connector or grounded wire. I'm sure all they did was hook up the tech 2 and it said "mod bad, replace and rape customer"
You might be able to get a used one - there have been a few threads regarding cars which have been totaled - or I would think the part is the same as used on other models so get one from another car even used or from a scrap yard etc.
'09 RL Ruby Red Manual
HID low beam & fogs
3" Magnaflow
Yeah! Send a PM to DirkDaddy! He's prolly got one layin around!
__________________ 2008 Black Onyx Red Line with Black Top 5 Speed Stick Single Disk Monsoon Sound and Black Leather Snowflake Wheels
RickyD jumpered the black and brown wires(I think). That turned the passenger air bag light from off to on. However, it did not turn off the red air bag warning light on the dash. So, he was not sure if the air bag was really on and working or not.
07Silver Pearl
Black/Black leather
CD/MP3 XM satellite
5 speed manual
VIN#1745
Fiamm horn
Magnaflow Quad Tip Exhaust
GMPP CAI Kazera KZ-J rims
The Sensing and Diagnostic Module asks the Passenger Presence System (that's the thing in the seat) how it is doing, and, if it doesn't like the answer it gets, it turns on the Fault Lamp. The PPS weighs the passenger and, if the weight is below the threshhold, turns on the Airbag Suppress output to turn off thePassenger Side Airbag. and Seatbelt Tensioner.
The PPS cannot be replaced by itself, the system has to be calibrated afterwards using a Scan Tool.
By the Way: The section on Supplemental Inflatable Restraints has more warnings in it than instructions. Everything is explosive, and sending a voltage surge to the wrong thing could blow something up in your face. Tread lightly.
VIN 00252
2.4 NA Manual
Midnight Blue
Thank you John. I was afraid it wasn't going to be simple. I'll wait to hear from the Saturn customer service department. And about airbags being under warranty forever? I need to know more about that.
Monadzback : Thank you John. I was afraid it wasn't going to be simple. I'll wait to hear from the Saturn customer service department. And about airbags being under warranty forever? I need to know more about that.
As far as I can learn, the SIR system is covered under the bumper-to-bumper warranty. Not forever.
VIN 00252
2.4 NA Manual
Midnight Blue
hit up the junk yards for a seat bottom, visit junk yards in person and maybe you can find one with a damaged/torn leather seat, and get a discount since all you need is the cushion with the sensor in it...get a receipt because after you get the scan tool on it at the dealer to program it and if it doesn't work, you can return it..
I have found complete seats for 150 at junk yards..
Similar issue failure with my young daughter G6 GT, thankfully it was covered under warranty, and yes, it outrageously expensive for a simple module...
"No man is good enough to govern another man without that others consent." ~ Abraham Lincoln
"The trouble with our liberal friends is not that they're ignorant; it's just that they know so much that isn't so." ~ Ronald Reagan
Sensor is easy to replace. They shouldn't be charging 200 bucks for labor.
I know... But they go by their little book of hours. They say it's 9 hours to change a clutch. But I talked with one of the mechanics there and told him it took me over 20. He said yeah we get screwed on some jobs and make extra $$ on others. The clutch, per their book, says to remove the turbo and a bunch of other crap that isn't figures into their 9 hours of labor and so they don't charge for it, but they still have to so they still have to do the work.
I have been told that "the book" is a guideline for how long a given job should take a qualified tech to perform and is used to help avoid cases where one shop charges two or three times another or even from getting radically different prices at the same shop for the same job on different days.
An inexperienced tech may take longer than "book" while an experienced tech may not take as long as "book" but the customer gets charged the same regardless. This also means that an experienced tech can do more than 8 hours work in a day and get "overtime" pay.
I have seen some dealers (Mercedes I think was one of them) where they have posted rates for various experience levels - if memory serves there were three levels - not sure what they were called - Tech 1 - Tech 2 and Master Tech or Tech - Senior Tech - Master Tech - something along those lines - and it was something like $35/hour for Tech 1, $55/hour for Tech 2, and $75 for Master Tech - or something along those lines - with the idea being that a master tech might only take half as long to get a job done - but that you would not pay for a Master tech to do an oil change for instance since the time involved there is not going to vary much based on the skill of the tech - but something like replacing a clutch might be done in half the time by a master tech that the latest technical school graduate.
BP Procare had a 24 month or 2 year - whichever came last - policy under which they would fix a problem - they also had a policy of not exceeding their initial estimate. My wife's Fiero caused them to rethink both of those policies - or at least how they interpret those policies. In the case of warranty - I had an "oil leak" fixed -which took them a few tries to get right and which in the end must have cost them 2 or 3 times what they billed me on the initial repair. in that example "oil leak" was likely too loose a definition of the problem they repaired. In the case of estimate vs billed amount - they must not have realized that in order to take certain parts off the engine you had to drop the engine from the car - or rather lift the car up off the power train - meaning that the length of time it takes to say completely remove the valve cover gasket on that car is far longer than any other car I have ever worked on. I also had a clutch replaced there - I think that was also a case where "the book" was not very accurate - on the flip side - my wife's Fiero may have been the only one they ever did such extensive work on meaning that even if the techs were experienced - they were not as familiar with that car as say the Pontiac dealer might have been.
HID low beam & fogs
3" Magnaflow
