Will The Sky Have A Limiter(?)
I have a question in regards to Limits (for lack of better terminalogy) on the SKYs topend performance. I have 04 L300.3/V6 and at about 115mph it falls off drastically, and I still have gas pedal left. RPMs are not a red line, but noses over. The same thing happens on my 04VUE/V6 at 100mph, is this some kind of safety thing that factory has programmed into vehicle? It is frustrating because I know can go faster than this. I can feel the anxiety in L300 as it still has power but is restrained. Will the SKY have this problem?
Is this some governor? installed by them? Inquiring minds want to know! ERNEST ![]() |
#2 (permalink) | |
Tim Johnson City, Tenessee Nitesky 2 2008 Automatic, premimum trim Chilipepper red Black leather, black top. painted wheels. Last edited by SkyMan 08 : 01-26-2006 at 01:18 PM. |
#3 (permalink) |
I have read that the Solstice has an electronic limiter to top out at
123MPH. That was in one of the auto magazines. My personal top was 105 and no lag was detected but on my trip to the races in Daytona tonight I will see about increasing my test results and update the info next week. Hopefully the local gendarmes are not on this forum. |
#4 (permalink) |
Man does it ever, thanks a whole bunch because I was debating whether to post this thread, thought it might be my imagination. I am not too crazy after all!!!!! Does replacing power void factory warranty? My family roots are in Tennessee, way back there, but there still the same.
ERNEST |
#5 (permalink) |
As with most cars electronicly limited you can get software to unlock that setting. I'd defintely recommend getting much better summer only tires and only doing it at the track if you plan to reach speeds exceeding 123mph. Along with a helmet, roll bar, and 5-point harness.
2006 Solstice, Mysterious [sold] - Born Sept 8th, 2005 2007 Solstice GXP, Mean - Born Nov 17th, 2006 |
#6 (permalink) |
The solstice, (and presumably the sky) is electronically limited, but the top speed is limited to like, 150 MPH or something like that. The top speed for the N/A Solstice (and presumably the sky) is DRAG limited - meaning there is insufficient power to exceed about 123 mph or so.
In principio creavit Bob Caelum... Magister Caelum Sum!!! No, I'm NOT Bob Lutz... Link to Forum Rules/Guidelines/Etiquette Link to Sky Specification Estimates/Sky FAQ |
#8 (permalink) |
The manufacturers generally install speed limiters for a number of reasons: they don't think the car has the stability or aero to be controllable at high speeds, etc.
But the biggest reason is often the tire rating. A good example is the 98-02 Camaro convertible. The coupe and the convertible both had sufficient power to exceed 155 mph. the couple came with Z rated tires and no speed limiter: it would top out, drag limited, at around 155-160. The convertible, for some reason, came with different tires, speed rated to only something like 122 mph (200 kph). Gm set the speed limiter on it at around that speed. You can re-program these, but in the sky and Solstice it won't be an issue stock because the cars hit a drag limit at around 125-130 anyway. The trubo version with 260 Hp will probably be drag limited at around 145.
04 Porsche Carrera Tiptronic dialy driver 02 ZO6 with C5R 427 w. Procharger, 640 HP - did 150 in 13.6 seconds with 2 on on 02/19/06 98 Camaro with 408 LS6 + NOS, with even more |
#11 (permalink) |
2 words
As the title suggests I can sum this up in 2 words....James Dean
Please dont take this car to those extremes! Life is to short anyway and we would hate to lose you =)
Black on Black , Monsoon sound , ordered 3/17/06 delivered 4/26/06 |
#12 (permalink) | |
RE: 2 words
Poor driving skills kill. Don't get me wrong there are definitly times when it is dangerous to drive fast: traffic congestion, weather, etc., etc. However if it is a sunny day and you are on an open road with no other cars you will not automaticly explode at speeds over 100 mph. My personal fastest is 145 mph on my Suzuki GSX-R 750 motorcycle. When I can finally get my hands on a sky redline and boosting the power above stock causes the car to be electronically speed limited, that limiter software will be the first to go. ![]() |
#13 (permalink) | |
Tim Johnson City, Tenessee Nitesky 2 2008 Automatic, premimum trim Chilipepper red Black leather, black top. painted wheels. Last edited by SkyMan 08 : 02-04-2006 at 10:07 PM. |
#15 (permalink) | |
RE: Cul-de-sac racing
First off, I would never blast through a neighborhood or any place where there is driveways, including streets with old age homes on them. When I decide to open it up, it is always on a limited access highway in an area where there are not even on-ramps (because that is how the cops nail you) and it is always when there is very sparse traffic so that no weeving through lanes is required. Is there a chance that a squirrel could become a greasy spot under my tire, a small chance I guess, but I am looking farther and farther ahead as my speed increases so that I can pick up these things. Anything goes ary and I am off the gas and lightly on the brakes, and can make a slight turn to avoid if necessary. Everyone should know where all of the cars around them are at any time, no matter what the speed. As speed increases, this circle of awareness has to grow in size to allow you time to react. Now you might say what about a deer jumping out in front of you? Extremely remote, as the highways I chose to do this on have walls on both sides to keep noise down for the houses that ajoin the freeway. I am not endorsing standing on the go pedal everywhere you drive, but merely saying that there are times when accelerating hard and traveling at speed can be done safely and that it is a great way to live life to the fullest. |
#16 (permalink) | |
Macho behind the wheel, that's what we need!
2.4L Sky Midnight Blue Automatic VIN 0278 del 4/6/2006 CAI "A person, who is nice to you, but rude to a waiter, is not a nice person." |
#17 (permalink) |
Come on Eldeeko, if the man wreaks his car it gives everybody else spare parts, auto as well as body parts. BTW what is your blood type,Sky-flyer. I'm looking for an A- lung. Will it to me pleaseee. Skip....
#18 (permalink) |
I guess the real limiter is behind the steering wheel.
2.4L Midnight Blue, Premium Interior, MP3/Stereo, LSD MODS-Magnaflow 2.5" Quad Tips C/B Exhaust, Redline Rear Valance, KS Windscreen, SMS Header,PCMforless tune, Saturn Sky Floor Mats, KS M1 Wheels, Falken 452 tires........Looking to get BOOSTED |
#19 (permalink) | |
you keep doing it like this and it will jump up and bite you in the rear one day... it is just a matter of time... and someone will be putting you in baggies...
Tim Johnson City, Tenessee Nitesky 2 2008 Automatic, premimum trim Chilipepper red Black leather, black top. painted wheels. |
#20 (permalink) | |
#21 (permalink) |
How much speed do people really need???
At the Philly Auto Show's SKY display, many guys seemed (1) disappointed that it was a 4cyl under the hood, (2) that it *only* made 177hp, and (3) it didn't have dual exhaust outlets (which I agree with - all performance cars should have dual exhaust outlets). What's wrong with these people? 177hp from a proven (aka reliable) ECOTEC 4cyl is more than enough to get the SKY moving. Of course the presenter stated that within a year's time a TURBOCHARGED model will be available in the 250hp range, and that seemed to make them happy. But how much power do people really need, especially in crowded city & suburb areas with highways always clogged with accidents? People crack me up!
*IMAGED 2/27/06, ORDER #GFR328, DELIVERED 4/27/06 - VIN 1366 - MSRP: $27,170.00 - COLORS: Silver Graphite (42U), Black (192), Black (19T) - OPTIONS: 6-disc/MP3 (US9), Premium Trim Pkg (PCH), 18" Chrome Rims (PD5), AUTO trans (MX0), LSD (G80) |
