Old 03-17-2007, 05:46 PM   #1 (permalink)
videoguy's Avatar
My Photos: (12)
Windrestrictor Wire Plan
I have a diagram of my windrestrictor wire plan. Consists of an on/off switch,
brake light and running light power suppy control find diagram at this hot link.... http://www.esnips.com/doc/04ecc112-e...WIRING-DIAGRAM
Vin#133770
Polished, Spoiler, Chrome Domes, Chromies
Windrestrictor w/ logo in Red
G2 Paint/Calipers
"260" Turbo" Decals Engine Cover Painted Red
10" WIDE RED RALLY STRIPES
Last edited by Crimson Avenger : 03-18-2007 at 07:12 PM. Reason: direction to diagram
videoguy is offline   Reply With Quote
Old 03-17-2007, 06:57 PM   #2 (permalink)
Crimson Avenger's Avatar
Welcome to the forum!
I'm sure this information will interest many. You can post your instructions and diagrams here if you want. Right now, we're having some technical difficulties with the image attachment feature, but you can use image shack or photobucket and link the images into your posts.
Thanks for working out the details on this modification.
President, West Coast Kappa Car Club http://wckcc.org
Crimson Avenger is offline   Reply With Quote
Old 03-18-2007, 07:22 AM   #3 (permalink)
videoguy's Avatar
My Photos: (12)
Thanks for the image shack site...it works well!
Vin#133770
G2 Paint/Calipers
Old 03-18-2007, 11:29 PM   #4 (permalink)
R1chy's Avatar
Thanks...
Appreciate the wiring diagram. As soon as the warm weather returns I plan to install our WR and install the dimmer controls.
R1chy
----RedLine----
Chili Pepper Red : Tan Top/Leather
Auto Trans
MP3 Monsoon Stereo
VIN - 10294
8 SEP 2006 - In the drivers seat with a ...
“Permanent Big Grin” : Confessions of a Sky owner
R1chy is offline   Reply With Quote
Old 03-18-2007, 11:44 PM   #5 (permalink)
videoguy's Avatar
My Photos: (12)
R1chy
I submitted the wire plan to Steven and he emailed me to say they have been looking for a simple way to explain this installation. Anyhow, since
tig welding is my main work, prints and plans are a way of life. I find we
do best with pictures since they reach our brain more directly than words.
Most of our members will be able to see that the dimmer, being connected
to both brake and running power supplys, gives one an ability to set the
intensity for both sources, and the on off switch; it allows you to turn it all
off when backing up in the dark.......how cool is that?.......Paul
Vin#133770
G2 Paint/Calipers
Old 04-25-2007, 12:45 PM   #6 (permalink)
Help! Which wires out of the bundle?
After reading all the instructions I could find regarding the windrestrictor for my Saturn Sky I became confused over which brown wire to splice into. Instructions from Windrestrictor are misleading. It indicates to find the main thick harness (found), slice the tape (done), locate the dark brown and the light blue wires (found), and then this is where I got lost. It talks about locating a very thick wire usually 10-12 inches carefully slice into the tape and find the thick rubber covered brown wires. I cannot find this wire. Any help would be greatly appreciated.
sgarza.
Below is the instruction that have confused me:
B: Once bolt is removed you will be able to pull the carpet back to expose the main thick wire harness. Then slice the tape back about 2-3 inches and locate the dark brown and the light blue wires. You will need to feel with your fingers along the wiring harness to locate what feels like a very thick wire (usually about 10-12 inches) Carefully slice into the tape and find the thick black rubber covered brown wires. This is usually located back by the white tape.
sgarza is offline   Reply With Quote
Old 04-25-2007, 11:36 PM   #7 (permalink)
fkeillor's Avatar
sgarza when I wired in my WR I used the light blue wire ( it goes to the third brake light). Used a circut tester to find the right wire. BTW the brake light only come on with the egnition turnd on. Hope the pic below helps.
The red wire is from the WR. Also used the bolt in the background for the ground.
Fred & Jane
NO BAD DAYS
Sunburst Yellow RedLine
First 1000 Redline
Roberts Etched Wind Restricter
Pics of past WCKCC events.
http://flickr.com/photos/18280974@N0...7606423653909/
fkeillor is offline   Reply With Quote
