Which wire harness is correct?
I have been reading here, and on the Solstice forum, and I am unsure which harness I should be getting when I swap out my OEM headunit for an aftermarket. I have read the Metra GMOS-LAN-03 is the correct to use if you have a non-monsoon system (which I do)... but you lose OnStar and/or chimes. I heard that the Metra GMOS-LAN-04 enables you to retain the chimes and OnStar... but then I read it only works for the Monsoon systems... what is the deal here?
I would like to maintain the chimes, but I dont worry about OnStar... I have tried finding the info out, but I get too much conflicting info... has anyone put in a stereo in a Sky that did not come with the Monsoon, using the LAN-04? |
#2 (permalink) |
This is how it works. The GMOS-LAN-03 harness will retain your chimes, and onstar and hook up to your radio. It will not retain the blinker clicks on its own. You need to hook up a relay (sold seperately and quite easy to hook up) in order to retain this function.
GMOS-Lan-04 will retain onstar and all chimes as well as blinker clicks (without a relay needed) for systems with teh Monsoon system. This will also hook up directly to your radio. I have a non Monsoon system as you do and have full chimes, alarms and blinker clicks. Onstar would work as well (if I had it) See my sig for full instructions and pictures.
Mean GXP Delivered 1/30/2007 $MSRP +$2K My Stereo Install--> Ultimate Pioneer Avic D3 Install Thread Mods: Solo-Performance Street Race exhaust Debadged JPM interior & shifter O.Z. Ultraleggera DDM Works Big Brake Kit Dunlop DZ 101 |
#4 (permalink) | |
The instructions for the GMOS-LAN-03 explain how to wire up the relay. Once connected it will wire up to the gmos harness. Parts list for the entire project below. Parts List: Pioneer - AVIC D3 (Head unit) PAC SWI-PS (Used to retain factory Steering Wheel controls) Metra - 95-3302 (Double din dash install kit for Sky/Solstice) Metra - 40-cr10 (Antenna adapter) METRA - GMOS-LAN-03 (Onstar / chime harness) For NON monsoon system NAPA auto parts- AR201 (12v 30 amp SPDT (Single pole double throw) relay (Needed with GMOS-Lan-03 for blinker "click") That is the relay that I used and one with similar specs should work just fine. Add on extras to teh ststem that are not necessary, but make for a nice install. Pioneer - CD-I200 (High Speed iPod Cable) Pioneer - SIR-PNR2 (Sirius Satellite Radio adapter) Pioneer - ND-BC2 (Rear view camera) Pioneer - CD-BTB200 (Bluetooth adapter)
Mean GXP Delivered 1/30/2007 $MSRP +$2K My Stereo Install--> Ultimate Pioneer Avic D3 Install Thread Mods: Solo-Performance Street Race exhaust Debadged JPM interior & shifter O.Z. Ultraleggera DDM Works Big Brake Kit Dunlop DZ 101 Last edited by Morfious : 08-16-2007 at 06:51 PM. |
