Go Back   Saturn Sky Forum > Saturn Sky Discussion > Sky FAQ, Specifications, Performance Data
Sky FAQ, Specifications, Performance Data Up to date specification, option, equipment and pricing info. Moderator/Admin posting only. CHECK HERE FIRST if you are new. You may find your answers!
Closed Thread
Old 02-03-2005, 06:30 PM   #1 (permalink)
KappaMan's Avatar
My Photos: (17)
News Sky Specification Estimates/Sky FAQ
This thread is an attempt to have a one stop shopping place to come and get frequently asked information. Think of this thread as a distilled information spot of knowlege accumulated by members of solsticeforum.com over the last year or so, and now Skyroadster.com.
Some of the information is based on information given out by GM, some of the information is speculative, but all of it is reasonably good guesses at frequent questions. Hope everyone finds it useful. Sources are identified where possible. Almost none of the information is based on "inside information" or "security leaks" - just good detective work, combined with intuition and collective cooperation of the members of this forum and Solsticeforum, using information available to anyone in public domain and primarily on the internet.
MESSAGE DIRECTED TO GM: THIS MEANS THAT THE INFORMATION CONTAINED IN THIS THREAD IS NOT THE RESULT OF CORPORATE ESPIONAGE OR INFORMATION LEAKS OR INSIDE INFORMATION. IT IS THE RESULT OF THE LARGE AMOUNT OF INFORMATION THAT GM HAS MADE AVAILABLE OVER THE LAST THREE YEARS REGARDING THE SOLSTICE AND THE KAPPA PLATFORM, AND RECENT INFORMATION MADE AVAILABLE WITH THE ANNOUNCEMENT OF THE SATURN SKY AT THE 2005 NAIAS.
Though it looks like I'm the one creating this information, I am merely collecting it in one spot for easy access to new and seasoned members alike. Please do not think that I'm this smart - this thread (which we suspect will be accessed by many who are not forum members) is the interesting result of a collaborative effort of many, many forum members.
Hope you find the information on the Sky for which you are looking, and we hope this helps.
The information in here is periodically updated as becomes available. If you see something that might need correction or have an idea of an FAQ to add, you'll find out this thread is closed for discussion to improve information clarity. Feel free to post on this thread:
Suggestions for FAQ inclusion
or send me a Private Message.
In principio creavit Bob Caelum...
Magister Caelum Sum!!!
No, I'm NOT Bob Lutz...
Link to Forum Rules/Guidelines/Etiquette
Link to Sky Specification Estimates/Sky FAQ
KappaMan is offline
Old 02-25-2005, 05:41 PM   #2 (permalink)
KappaMan's Avatar
My Photos: (17)
Technical Summary/Specification Sheet Compiled with available information
Something like this (FORMAT IS REALLY ROUGH, but I think it captures almost everything): (Conversions: 25.4mm per inch, 2.2 pounds per kilogram)
[Sky spec sheet PDF added, thanks to brentil]
Base Price: | $23,000(estimated)
Max MSRP: | $26,000(estimated)
Vehicle Type: | 2 Passenger, 2 Door, Convertible Roadster
Drive Config: | Rear Wheel Drive
Standard Accessories: | CD Player
Optional Accessories: | Power wdo/locks/mirrors, cruise, remote locking, ABS, A/C, rear defrost, AM/FM/CD, XM, Accessory jack radio, Premium sound, leather trim, automatic trans?
Sound System: | TBD, but assumed to be Monsoon AM/FM/CD
Engine: | Ecotec 2.4L DOHC I-4 (LE5) [from 04 NAIAS]
Ecotec 2.4L DOHC Information (downloadable PDF)
Type: | Hydraulic Variable Cam Phasing[VVT], 2.4 L inline 4-cylinder, aluminum block and head with balance shafts
BoreXStroke | 88mmX98mm (2.2L=86mm X 94.6mm)
Displacement | 2384cc (2.4 liter)
Compression Ratio | 10.6:1 (Estimated)
Fuel-Delivery System | electronic sequential port injection (inferred from internet info)
Auxiliary Systems | None (Future forced induction TBD)
Valve Gear | Chain driven double overhead cams, 4 valves per cylinder, Hydraulic roller finger followers,
Power (SAE net) | 170 bhp @ 6400 RPM (05NAIAS Handout)
----------177 bhp @ 6600 RPM (05NAIAS Solstice Display)
Torque (SAE net) | 170 ft-lb @ 4400 RPM (05NAIAS Handout)
----------166 ft-lb @ 4800 RPM (05NAIAS Solstice Display)
Redline | 6500 (estimated, not documented or announced, pics indicate 7000 redline on gauge, likely inaccurate)
----------Revised to 7000 RPM, based on 05 NAIAS Display info
Fuel | Assumed to be 91 octane recommended
Variable Valve Timing helps deliver 90 percent of the peak torque at as low as 2400 rpm (so in essence 153 ft-lbs at 2400 rpm)
Drivetrain: |
Transmission | MW5 Aisin 5-speed manual (from NAIAS Handout)
Final-Drive Ratio | 3.73:1 (estimated as CTS differential), Limited slip expected optional
Gear [Ratios from Chev Colorado Aisin Trans] | Ratio/Overall Ratio/MPH per 1000RPM/Max test speed
I | 3.75 / 13.99 /TBD/TBD
II | 2.26 / 8.43 /TBD/TBD
III | 1.37 / 5.11 /TBD/TBD
IV | 1.00 / 3.73 /TBD/TBD
V | 0.73 / 2.72 /TBD/TBD
R | 3.67 /NA/TBD/TBD
Engine RPM @60 MPH in top gear | TBD
Dimensions:
Wheelbase | 2415mm
Track front/rear | 1537mm/1555mm
Length/Width/Height | 3994mm/1819mm/1274mm
Ground Clearance | TBD
Curb Weight | 2860 lbs (1298kg)
Weight Distribution | Near 50%, 52% front per MotorTrend (assumed with driver?)
Curb weight per horsepower | 16.8 lbs
Chassis/Body
Type | "Lower-Dominant Tube Structure with Hydroformed Rails" (from NAIAS Handout) assume classified as unit body or similar to Corvette.
Body Material | welded steel stampings, "Sheet Hydroformed" outer body panels
Interior:
SAE volume, front seat | 46 cu ft (estimated based on Miata/S2000)
Front Legroom | 42.7" (Satch's Pont. Dealer)
Front Headroom | 38.5" (Satch's Pont. Dealer)
Front Hiproom | 50" estimated
Front Shoulder Room | 52.4" (Satch's Pont. Dealer)
Cargo Volume | 4 cu. ft. top up/ 2 cu. Ft, top down (MotorTrend)
Seatback Adjustment | TBD degrees
Seat F/A Adjustment | TBD inches
Gauges | 140 MPH speedometer, 8000 RPM tachometer, fuel level only. Assume digital readout of information system, odo, idiot lights for oil temp, water temp, etc.
Suspension:
Front Suspension | Short-long arm, Aluminum control arms (From NAIAS photo)
Front Anti-Roll Bar | TBD diameter, Ball joint links (from tech-chassis photos)
Front Springs | Coil
Front Shocks | Bilstein Monotube Coil-over
Rear Suspension | Short-long arm, Aluminum control arms (From NAIAS photo)
Rear Anti-Roll Bar | TBD diameter, Ball joint links (from tech-chassis photos)
Rear Springs | Coil
Rear Shocks | Bilstein Monotube Coil-over
Steering | Rack & Pinion, Hydraulic Assist
Steering Ratio | TBD
Turns lock-to-lock | TBD
Turning circle curb-to-curb | TBD
Brakes
Type | 4 whl disc, hydraulic with vacuum power assist, (estimate: antilock optional)
Front | 11.65" x 1.02" / 296mm x 26mm; vented discs (cars.com/Malibu Maxx suspected reuse-GM info)
Rear | 10.63" x 0.55" / 270mm x 14mm; solid discs (cars.com/Malibu Maxx suspected reuse-GM info)
Total Swept Area | TBD
Swept Area/Ton | TBD
Wheels | 18.0" X 8.0" (Saturn Website)
Front Tires | P245/45SR18 Goodyear Eagle RS-A
Rear Tires (if different from Front) | Same
Inflation pressure | TBD PSI
Spare Tire and Wheel | Consensus: None, Inflator Kit similar to Corvette
Performance:
Acceleration
0-30 | TBD
0-40 | TBD
0-50 | TBD
0-60 | 7.2-7.5 seconds estimated by magazines
0-70 | TBD
0-80 | TBD
0-90 | TBD
0-100 | TBD
0-110 | TBD
0-120 | TBD
Street Start, 5-60 | TBD
Top-gear acceleration, 30-50 mph | TBD
Top-gear acceleration, 50-70 mph | TBD
1/4 Mile | TBD sec @ TBD mph
Top Speed | 120-130 MPH estimated, based on Miata/S2000
Braking:
From 60 MPH (R&T) | TBD
70-0 MPH @ impending lockup | TBD
From 80 MPH (R&T) | TBD
From 100 MPH (MT) | TBD
Handling:
Roadholding, 300 ft skidpad | 0.90g (Pontiac Website - Solstice)
Lateral accel, 200 ft skidpad | 0.90g (Pontiac Website - Solstice)
Understeer | Minimal (expected)
700 ft slalom speed (R&T) | 65-70 mph (based on S2000/Miata capability)
600 ft slalom speed (MT) | 65-70 mph (based on S2000 capability)
7 cone 490 ft slalom (AW) | 47.0 mph (based on S2000 capability)
Figure 8 test (MT) time @ avg. g | 26 sec @ 0.70 g (estimate from S2000)
Lateral Seat Support | estimated as "good" from seat photos
Fuel Economy:
EPA City | 22 mpg (C&D Estimate)
EPA Highway | 28 mpg (C&D Estimate)
Observed | Est 250 miles (85% of fuel capacity at average econ.)
Cruise Range | Est 315 miles (85% of fuel capacity at highway econ.)
Fuel Capacity | 13.3 gal (Satch's Pont. Dealer)
Interior Noise/Sound
Idle | 47 dba (Estimate based on Miata)
Full-throttle Acceleration | 79 dba (Estimate based on Miata)
70-mph cruising | 75 dba (Estimate based on Miata)
Maximum 1st gear | TBD dba
Constant 50-mph | TBD dba
KappaMan is offline
Old 02-25-2005, 05:48 PM   #3 (permalink)
KappaMan's Avatar
My Photos: (17)
Question: I noticed you have decibels listed for interior noise and sound. What are decibels, and how loud is 75 Db?
Answer:
Originally Posted by brentil
If you're into computers a 6000rpm to 7000rpm CPU heatsink is about 55db.
Problem is with db the value increases by factors of 10 as you go up. A race car with a very open exhaust without a catylitc converter is usually around 105db which is extremely loud.
Originally Posted by dls6774
Here's a site that gives sound levels for various things and also a list of various noise levels and how long you can listen before doing damage to your hearing.
http://www.freehearingtest.com/noiselimits.shtml
An amplified rock band is listed at 120dB
a jackhammer at 130dB
and a 12ga shotgun with an 18" barrel at 161.5 dB
75dB is compared to kitchen appliances. Although they didn't say which ones...
Originally Posted by padgett
Decibels (db) are an expression of sound *pressure* and is really meaningful when coulpled with a distance (xxx db at xxx feet). One of the old government "emissions" requirements was 50 db at 50 feet for a WOT drive-by.
db is measured on a log scale - it doubles for every 3 db so 87 db is half the sound pressure of 90 db.
For some reason people find very high pressure vibrations pleasurable hence the rise of automotive boom-boxes. I suspect my Beltone stock is going to continue to go up.
KappaMan is offline
Old 02-25-2005, 05:52 PM   #4 (permalink)
KappaMan's Avatar
My Photos: (17)
Question: I've heard the Solstice is using parts-bin strategy. What type of parts are being re-used on the Solstice. How much of this carries over to the Saturn Sky?
Answer:
Most of the re-utilized parts appear to be items that won't significantly affect or will benefit the characteristice of this car, such as performance, ride, handling, or braking. Critical systems, like the suspension and body structure, are new and appear to be optimized to deliver a good, solid car.
Some re-used parts that have been noted so far are:
Front fog lamps: Grand Prix
Rear Back-up Lamps: Envoy/Trailblazer
Seats: Shared with Opel (maybe just the frame?)
Outside Rear View Mirrors: Fiat Barchetta?
Interior AC vents: Lotus Elise or Alfa 156/Fiat
Brakes/Rotors: ION Redline or Malibu Maxx? (suspect, but specs look very close)
Engine: Chevy Cobalt (2.4l), Uplevel F/I unknown, Cobalt S/C possible
Transmission: Aisin 5 spd manual, suspect adapted from Chevy Colorado
Differential: Cadillac CTS (from cars.com overview)
Door Handles: Unknown but mentioned as shared
Gage Cluster: Chevy Cobalt
Additional thread info on parts re-use here:
http://www.solsticeforum.com/forum/showthread.php?t=437
As for what parts are re-used for the Sky, we honestly don't know. It is generally thought that the Sky will share engine, transmisssion, electrical architecture, suspension, wheels/tires, steering, and most of the underpinnings with the Solstice. The Sky may or may not be tuned to a different ride/handling balance - some of the indications from the 2005 NAIAS suggest a slightly softer ride. Obviously, the interior and exterior styling is very different from the Solstice - so other than things like seat frames or instrument panel structure, it's not likely much of the "appearance" items will be reused.
We will all learn more, so stay tuned.
KappaMan is offline
Old 02-25-2005, 05:57 PM   #5 (permalink)
KappaMan's Avatar
My Photos: (17)
Options List, Anticipated Colors, Availability
Question:When will the Sky be available, for sale, at dealerships? What options will be available? What Colors will be available?
Answer
We don't know when the Sky will be orderable, available, or for sale at dealerships, but indications from Saturn (website and 2005 NAIAS handouts) indicate availability sometime early 2006.
Question: What about heated seats? Height adjustable seats?
Answer: At this time, it doesn't look like they are available.
KappaMan is offline
Old 02-25-2005, 06:03 PM   #6 (permalink)
KappaMan's Avatar
My Photos: (17)
Top Questions
Question: Will there be a retractable hardtop, or a coupe version? What about a vehicle like the Curve or Nomad shown at the 04 North American International Auto Show?
Answer: Based on information from recent (2005) news articles, there are no plans for anything at this time past the three variations of the "Kappa" platform (Solstice, Saturn Sky, and an European Exported Version).
Question: Will a powered soft top or a power top or power roof be available?
Answer: Based on all available information, only a soft top manually-operated (manual operation) convertible top will be available.
Question: Will the soft top be made of vinyl?
Answer: Based on available information, No. It appears to be a cloth manual top.
Question: What about the rear window? Vinyl or Glass?
Answer: Glass. An article in AutoWeek mentions a glass rear window in the cloth manual top. We also know rear window defogger/defroster is available (from interior pictures and suspected options) - which cannot be used on a vinyl window. Recently, from the Lutz blog, it states clealy the rear is Glass.
Question: Will the top come in optional colors?
Answer: At this time, the only known color is black. This is not completely certain.
Pictures are attached of the top up - various sources, none of which are "true production" models.
sky-specification-estimates-sky-faq-1073soltice.jpg  sky-specification-estimates-sky-faq-1073soltice2.jpg  sky-specification-estimates-sky-faq-1073all.jpg  sky-specification-estimates-sky-faq-0503solstice_drivers.jpg
KappaMan is offline
Old 02-25-2005, 06:03 PM   #7 (permalink)
KappaMan's Avatar
My Photos: (17)
Question: How does the Solstice/Sky stack up against other competitors?
Answer:
A comparison of roadsters and convertibles was compiled by brentil here:
ROADSTER/CONVERTIBLE COMPARISON
An excel version is available to download, courtesy of brentil,in the following attachment.
KappaMan is offline
Old 02-25-2005, 06:04 PM   #8 (permalink)
KappaMan's Avatar
My Photos: (17)
Buttress, AFBTS, Top Operation
Question:
What is an AFBTS? Is it an acronym? If so what does it stand for?
Answer:
It stands for Artsy-Fartsy Buttress Top Support. It's an inside joke reference for the non-functional wedge-shaped extensions that are part of the top. They extend from the flat plane of the back glass to points on the decklid. Reference a picture of the top up.
You may see them called "wings", "winglets", "thingies", or "buttresses".
At this time, it appears they release with some sort of actuation, either through a trunk release or a key fob, to allow access to the trunk. Reference top actuation for suspicions on how the top operates.
At this time, their only "function" appears to be styling-related only, hence the "artsy-fartsy" nomenclature, and may hinder smooth operation of the top. "Artsy-fartsy" is a reference to features that affect form only with no or detrimental effect on function.
Before anyone asks, AFBTS can be referred to through the letters of the acronym, but it's also acceptable to prounounce it as "Aff - butts".
KappaMan is offline
Old 02-25-2005, 06:10 PM   #9 (permalink)
KappaMan's Avatar
My Photos: (17)
Higher HP, Removable/Retractable Hardtop, Coupe, Trunk Capacity
Question: Will there be a higher horsepower engine available? If so, what form will it be and how much will it cost?
Answer: Officially, only subtle hints have been given by GM/Pontiac about a more powerful Solstice coming. Consensus from some magazine articles is around 240 HP, but no committment on whether it is a turbo or supercharged. Highest probability is some sort of forced induction. There is no information on when it might be available, but most certainly will not be available anytime during the first model year. It will likely cost whatever the market will bear, a question that will have to be answered at a future date. It is expected that whatever is available for the Solstice will be available for the Sky.
Question: Will there be a removable hardtop, retractable hardtop, or any type of roof other than the soft-top shown? What about a Coupe?
Answer: It does not currently look like there will be any type of replacement top available for the first year of production. There has been no word or information from GM that supports availability of anything other than a rag-top.
Question: How much can I fit in the trunk?
Answer: Estimates based on the Solstice are 4 cubic feet with the top up and 2 cubic feet with the top down, based on a magazine article written by someone who actually drove a Solstice in England. The Mazda Miata and the Honda S2000 have approximately 5 cubic feet of trunk space. The top and trunk for the Sky is expected to be similar to or shared with the Solstice.
Pictures taken by one of our members at an autoshow of the trunk in one of the show Solstices. There is no top present. Not everyone agrees, but the most likely function of the "hump" is the gas tank.
A picture of an early rendition of the top design (in clay) is also attached [from a no-longer-internet-available May 2002 Popular Science (TOC May 2002 PopSci) article on the rapid design of the Solstice http://www.popsci.com/popsci/auto/ar...3259-1,00.html entitled "Speed Record: How GM Supercharged the Solstice Launch"].
Also, a top and bottom picture of the Sky is provided, which gives further indication that the gas tank is where it is suspected. The Sky and Solstice are expected to share underbody/structure to a large extent.
sky-specification-estimates-sky-faq-pict0045_1.jpg  sky-specification-estimates-sky-faq-pict0069-1.jpg  sky-specification-estimates-sky-faq-claytop.jpg  sky-specification-estimates-sky-faq-skytopbottomjpg.jpg
KappaMan is offline
Old 02-25-2005, 06:11 PM   #10 (permalink)
KappaMan's Avatar
My Photos: (17)
Front License Plate Location?
Question: I live in a state that requires a front plate. Where will it go on my Sky?
Answer: We don't know at this time. Stay tuned!
KappaMan is offline
Old 02-25-2005, 06:13 PM   #11 (permalink)
KappaMan's Avatar
My Photos: (17)
How does the top work? Top Operation? Convertible Top FAQ
Question:How does the top work? How long does it take? Do I have to get out of the car?
Answer: The Sky is expected to share top functionality with the Solstice. The answer is from Solsticeforum.com:
FIRST: right now, we don't exactly know. The most likely scenario is based on part information from someone who participated in a "customer review" of some sort, with other bits and parts of articles, such as this one:
Originally Posted by AutoWeek article on England "Test Mule" Drive
...Before letting us slip in behind the wheel, the GM engineers folded down the mechanical top. The process starts by twisting a latch on the inside that releases the top from the header, and then opening the trunk in reverse fashion. There are a couple of wings at the rear of the top that fold inward, and then you're ready to fold the top down into the trunk. After the top is stowed, the trunk lid can be closed and the finished look is clean with no need for a boot. There is very little cargo room in the car, even with the top up. There is no space behind the seats for any storage, so unless a cargo rack is added, judicious packing is required for even weekend trips. Don't even think of bringing your golf clubs.
Lots of discussion about top operation here: Convertible Top FAQ / Pictures
We do know or suspect this:
-The end result is a clean look with the top stowed in the trunk.
-It seems most likely you'll have to get out of the car some time to deal with th AFBTS's (see previous FAQ or search).
-It looks like it will take longer than a Miata to drop the top if you don't count the addition of the tonneau cover for the Miata. It looks like it would take less time to open the top on the Solstice than it would take to drop the top and install the tonneau snap-on cover on either the Honda S2000 or the Miata.
-The top takes up storage space in the trunk when stowed(about half - see previous questions)
-It seems highly likely that you will be able to access the trunk with the top remaining up. It is unknown how the AFBTS's are dealt with, but suspect a logical operation would couple the motion with the opening of the decklid.
-It looks like there is two guidepins of some sort (or at least there appear to be sockets for them in the header), with one central latch, the reciever for which is visible in most pictures taken at many different auto shows across the country.
Based on information available, looking at many, many photos taken at shows, and assessing the myriad information sources (some of which seem very dubious), it appears the top should operate something like this:
Originally Posted by top operation suspicion, several different threads
From Driver's Seat
1) Pop Decklid (unlatches AFBTS also), possibly from inside button, lever-cable release, or FOB
2) Unlatch ONE center latch (all pictures support only one central latch, not two).
3) Get out of car and stow the roof.
4) Close the Decklid
Or at least that's what seems to make the most sense. Maybe a minute?
To put it up, the most logical method would be:
1) Pop Decklid (? using button, lever-cable release or FOB)
2) Get out and raise decklid
3) Unstow the roof
Then either:
4a) Get in and latch the roof
5a) Get back out and close the decklid
6a) Walk to passenger side and latch the passenger side AFBTS (mechanism unknown)
7a) Walk back to the driver's side and latch the driver's side AFBTS (ibid)
8a) Get in driver's seat
or:
4b) Close Decklid
5b) Walk to passenger side and latch the passenger side AFBTS
6b) Walk back to the driver's side and latch the driver's side AFBTS
7b) Get in driver's seat
8b) Latch the central latch
KappaMan is offline
Old 02-25-2005, 06:17 PM   #12 (permalink)
KappaMan's Avatar
My Photos: (17)
Interior, Gages, Cupholders
Question: Are there any cupholders?
Answer: It appears there are three - one that comes out of a side panel on the passenger side of the console, and two that come out of a tray in the center of the back of the console, under the storage bin. See attached pics. These pictures are from a Solstice, but similar locations exist on pictures of the interior of the Saturn Sky.
Question: What about Gages (Gauges)?
Answer: Based on interior pictures, there appear to be only a Tachometer, speedometer, and fuel gage. There's also a "Driver Information Center" or DIC, that is expected to work like the DIC in a Trailblazer. There may be additional information (like temperature, mileage, etc.) but the actual DIC content is unknown at this time.
sky-specification-estimates-sky-faq-444dsc066221-med.jpg  sky-specification-estimates-sky-faq-pontiac_solstice_2006_023.jpg
KappaMan is offline
Old 02-25-2005, 06:17 PM   #13 (permalink)
KappaMan's Avatar
My Photos: (17)
Kappa Platform Solstice/Sky
Question: What is the Kappa Platform? What is the Kappa Architecture?
Answer: [summary compiled from various articles and discussions over the last two years]
The Kappa Platform, or architecture, is a new vehicle architecture developed by General Motors to enable the Pontiac Solstice to become reality as a production car.
A vehicle architecture or platform is the basic underlying, load-bearing structure in a vehicle. Analogous to the framing of a building, it also is the majority of expense in production, design, and validation of a new car. A typical strategy for an automotive company is to develop a new architecture or platform rarely - and use that platform for producing variants or improving successive generations of vehicles.
Regarding the Kappa Platform:
In 2002, the Pontiac Solstice Concept was shown, in two forms: a driveable roadster convertible, and a design study of a fastback coupe.
The Pontiac Solstice was recieved very well at the 2002 NAIAS. The driveable roadster concept car shown had been cobbled together from many different components, using a cobbled portion of the "Delta" architecture (a Front-Wheel-Drive small car architecture that supports the Saturn ION and the Chevy Cobalt). The thinking was that this architecture might be heavily modified and used to produce the Solstice.
We have speculated that when General Motors decided to try to produce the Solstice as a highly-styled, low-cost, low-volume niche vehicle for enthusiasts, it became apparent that there were no existing platforms that could be used to achieve the needs of a modern roadster.
Therefore, the Kappa Platform was developed to provide the necessary structure for a two-seat, Rear Wheel Drive convertible. It features hydroformed rails and a tunnel structure similar to the Corvette architecture, and is designed for a short-long-arm suspension for the front and rear. It features rear wheel drive, longitudinal-mounted transmission and front-mid engine.
At this time it appears the platform has only been designed to accomodate a single engine - the four-cylinder Ecotec family. It also appears this platform was only designed to be "left-hand drive".
Since the Solstice, GM has designed another roadster that looks radically different, but shares the same underlying Kappa Platform: The Saturn Sky. The Saturn Sky was styled after the pattern of the Vauxhall VX Lightning design (see below). It also appears that there will be a European version built off the same platform, the details of which have not been released at this time.
Three other concept vehicles were built off the initial Kappa Platform, and shown at the 2004 NAIAS: The Vauxhall VX Lightning, The Saturn Curve and Chevy Nomad. All three cars were recieved reasonably well, but were not nearly as embraced as the original Solstice Concept.
The Vauxhall VX Lightning is the same size as the original Solstice Concept, and pieced together in the same manner as the 2002 Solstice Concept, and had been shown in Europe several months earlier, before the "Kappa Platform" had apparently been finalized. The Vauxhall VX Lightning is the styling pattern after which the appearance of the Saturn Sky is based.
The Saturn Curve and the Chevy Nomad Concept Cars were built on "modified" versions of the Kappa Platform, and exhibited 12" longer wheelbases, and 2+2 seating.
See also A Look at GM's Kappa RWD Architecture
KappaMan is offline
Old 02-28-2005, 04:08 PM   #14 (permalink)
KappaMan's Avatar
My Photos: (17)
Sky Specifications Brochure Added
To the specs page. Thanks to Brentil.
KappaMan is offline
