this question is for a lady at my work that put some new rims on her stock tires. she said that the shop took off the wheel speed sensors because they couldn't get the new rims on with them on? now the DIC is going nuts without them beeping all the time. im really not sure what to tell her? any input is appreciated! thanks
Impossible. Virtually NO reason to remove them. I am assuming that the shop would not reinstall the TIRE PRESSURE MONITORS. This, of course, assumes she has an 08 or 09 Sky. A lot of tire shops refuse to deal with them out of fear of damage/liability. Also, some aftermarket wheels might not be TPM ready. Ask her WHAT warning light is coming on.
__________________ Redline (pre-halt), Pearl, Black/Red,
owner installed lock buttons,
painted calipers, SP Catless DP
MagnaFlow 3" single cat-back,
Koni S/A's, Kurt hitch,
18x11 CW's, 315/30 Hoosiers for Solo
other "stuff"
Are we talking wheel speed sensor or tire pressure monitor sensors?
__________________ 2008 Redline
Black
Black/Red Leather
Monsoon 6 Spoiler
RHF Transmission
Born 7/20/07
Snagged 8/31/07
Belle? My car
Alizée? On Avatar vacation
Permagrin DENIED
-Longitudinally challenged since 8/20/10
OOPS.... sorry.. wasn't thinking... not the wheel speed sensors... the tpms sensors....
Refer back to my first post. Now, go ask the tire shop WHY they did not mount the TPMs on your new rims. If they say that the wheels are the problem, speak with the vendor that sold them if that is correct. If the tire shop was just "scared", demand your labor charges to be refunded, take that money to a REAL tire shop, and have the work corrected.
At this point, your only real concern is just seeing the warning light on the dashboard. Your car should otherwise function just fine.
OOPS. Just saw your signature. I can not imagine why Gravana would be selling wheels that are not TPM ready. Time to go have a "discussion" with the shop. In this day and age, there is NO excuse for what they did.
other "stuff"
I am trying to buy a set of wheels for my wifes 4x4 Xterra, and every one of the wheels I have looked into actually have warnings saying they are not able to accept the factory Tire Pressure Monitor Sensor. If you goto the Tire Rack and select rims, some of them have that warning there also. SO, if the lady purchased rims that are not designed to accept the TPMS module, then the shop is correct. Go check yourself and you will see I am correct. I have not tried to buy wheels for the Kappas I've owned yet, so I have no experience with this particular car with TPMS issues.
2006 Deep Solstice NA...Traded in for:
2009 Sky Redline Ruby Red Limited Edition
5 speed manual/rear spoiler added/6 disc/Monsoon
GMPP Tune/MBRP Charge Pipes/DDM Backbone & Probeam/K&N Drop in/HIDs
*Thank You Bob Lutz* And Wilmington UAW 435
It's a sensor that monitors wheel spin, usually providing input to the ABS or ESC system. I don't know if kappa uses this technique or not.
Black
Black/Red Leather
Monsoon 6 Spoiler
RHF Transmission
Born 7/20/07
Snagged 8/31/07
Belle? My car
Permagrin DENIED
The wheel speed sensors are critical to making any and all the traction nannies function. On the Kappas they are incorporated into the wheel bearing assemblies at each wheel.
other "stuff"
To avoid confusion, I want to clarify that we are talking about two different things within this thread. The wheel speed sensor is just that. It monitors the speed that the wheel is turning, and each wheel has one. That way the car knows if one wheel is turning slower. This is how your cars Anti Lock Brake system and stability control work.
The Tire Pressure Monitor system also has a sensor at each wheel. THAT sensor monitors the pressure of air inside the tire. These used to be a large band that strapped around the inside of the wheel, but more modern designs are built into the valve stem.
The point of this thread was someone asking if it was true that some aftermarket wheels do not allow you to use the OEM Tire Pressure Monitor system. The wheel has to be designed in a way that allows the TPMS module to fit at the valve stem. I do not know specifically what the problem is with the wheels I have looked into for my wifes Xterra, but so far the wheels manufacturers have all stated that the OEM TPMS monitors would NOT be able to be installed on their wheels if I bought them.
I just spoke with Tire Rack. The agent I spoke with stated that for a specific wheel to be TPMS compliant there needs to be a recess machined into the wheel to properly accept the sensor. Further, he said he could check the specifics of any wheel they sell if I told them what I wanted. So, the OP needs to speak with the vendor she bought her wheels from. Jeff, Discount Tire or Tire Rack can probably solve your problem.
other "stuff"
The Tire Rack is where I have been trying to buy wheels for my wifes Xterra. I enter her truck online, select different wheels, and each one I have selected (that she liked) has popped up a message saying "Warning! This wheel will not accept the factory TMPS Sensor and the system will not function.".
Bob, thanks for taking time to actually call them and get detailed information. Now I know what the problem is, and how it is solved.
