coolant low every 1000 miles - Saturn Sky Forums: Saturn Sky Forum
post #1 of 6 (permalink) Old 11-22-2019, 01:50 AM Thread Starter
Emmett's Avatar
Quoted: 84 Post(s)
I get a coolant low alert - because the coolant level really is low - about every 1000 miles.
When I take off the cap there's a solid vapor lock.
Any suggestions on what I can do to get it back to very rarely?
Thanks
Emmett is offline
post #2 of 6 (permalink) Old 11-22-2019, 06:20 AM
Quoted: 983 Post(s)
Look at your water pump for a leak
marlboromike is offline
post #3 of 6 (permalink) Old 11-22-2019, 09:43 AM
Quoted: 510 Post(s)
Seconded ^
TomatoSoup is offline
post #4 of 6 (permalink) Old 11-22-2019, 09:47 AM
Draike13's Avatar
Quoted: 76 Post(s)
^Third
9 times out of 10, that issue in these cars is the water pump. Already went through this myself.
Draike13 is offline
post #5 of 6 (permalink) Old 11-22-2019, 03:06 PM
Quoted: 1772 Post(s)
^ In for the forth...
I'll also add you may want to look at the area of your block right under the water pump. You may see some redish colored stains there which would also be indicative of a leaking water pump. This is more common on the Turbo cars but I had the one on my 2.4 start to go bad too.
If you don't know where your water pump is, see the attached picture. While this is the 2.0 Turbo engine, the 2.4 has it in the same spot. Note that in this picture, the turbo would be on the passenger side of the engine bay.
post #6 of 6 (permalink) Old 11-22-2019, 11:34 PM
skersfan's Avatar
Quoted: 832 Post(s)
This a normal problem with these cars, be it NA or Redline. But you need to get it fixed before it becomes a big problem.
skersfan is offline
