DIY: Saturn Sky Red Line Oil Change - Page 2 - Saturn Sky Forums: Saturn Sky Forum
post #16 of 65 (permalink) Old 08-29-2009, 12:34 PM Thread Starter
Are-Ex-Eight's Avatar
Originally Posted by e-sarge View Post
A few minor suggestions to add to your already fantastic write-up:
  • Raise your oil catch pan closer to the drain plug using cinder blocks, wood, etc. to avoid the mess on the driveway. The closer you get it to the drain plug, the less possibility for the oil to miss the catch pan. I learned this one the hard way too.
  • Ensure the area around the filter lid is clean before removing the filter. This is to avoid any dirt from falling into the open filter cavity (dirt in the engine) or the area where the o-ring seats (causing an oil leak).
  • Have a clean paper shop towel in your other hand when you remove the old filter from the engine to catch the last few drops of oil that always want to spill on the power brake components before you can safely stow the filter in a proper container (I usually use a zip-lock bag).
  • Change the o-ring on the filter lid if your filter comes with a new ring (my most recent Fram filter did).
  • Clean the oil filter cap and lubricate the o-ring with some of the new oil (just dip your finger in the new oil and wipe it on the o-ring). This will help it to condition the o-ring and help it seal better with the machined surface on the engine block.
  • Clean the oil drain plug and lubricate the rubber washer with a drop of new oil as well. This helps keep the rubber in good condition and forms a better seal with the engine oil pan.
Also, your question about filling the oil filter -- SkyVue2 has the right answer. That technique was sometimes recommended for engines with the old metal cannister style filters. I'm not sure of the exact rationale, but probably something like avoiding a possible air block, or maybe ensuring oil gets to the engine faster during the first start-up after the oil change. In any case, filling your Kappa filter with oil would make a big mess. Filling the filter cavity in the engine would just run down into the engine block.
Thank you. I have added your tips into the body of the guide.
2008 Black Onyx Red Line
Tan Interior/Black Top
Current Mods:
Custom Illuminated WindRestrictor
Smoked Clear Corners
Stubby Antenna
Future Mods:
Upgraded Sub Woofer
Rebadged with Opel GT
Custom 5 Gal Keg Holder with Stage 3 Intercoolers
Are-Ex-Eight is offline
post #17 of 65 (permalink) Old 08-29-2009, 05:28 PM
Skip's Avatar
Location: Somewhere in the bottom of a Gentleman Jack bottle
Originally Posted by Are-Ex-Eight View Post
Haha yes it is a wedding ring.
I have seen in my lifetime of 60 years four ring fingers being ripped off the bone cause someone left the ring on. The ring just says you are married. The thought behind the ringless is first I am still married and second my finger stays intact.. for twenty four years I was married and never wore my ring on my finger...Saw too many fingerless people.....Skip...read and heed....
The Official Resident Redneck
Originally Posted by GaryH View Post
"smart azz redneck that loves to drink that Jack and chase women".......My kind of guy.
Skip is offline
post #18 of 65 (permalink) Old 09-07-2009, 12:18 AM
GT!
GT!'s Avatar
Quoted: 23 Post(s)
Considering the fumoto. From the pics it seems clear that you installed the ADP-107 adapter. Is this really necessary? From the pics it does not really look like the drain hole is recessed.
-GT
GT! is offline
post #19 of 65 (permalink) Old 09-07-2009, 10:34 PM Thread Starter
-GT
It's up to you, personally I didn't want to chance it as the fitting starts to rub on the sump paneling before it's completely tight.
It's one of those "you're probably ok" but the adapter is 4 dollars and does not exactly stick out into anything in the way.
Current Mods:
Stubby Antenna
Future Mods:
Upgraded Sub Woofer
post #20 of 65 (permalink) Old 09-08-2009, 11:14 AM
GT!
GT!'s Avatar
Quoted: 23 Post(s)
Thanks. Ordered both to be safe.
-GT
GT! is offline
post #21 of 65 (permalink) Old 09-08-2009, 12:35 PM
Leather's Avatar
I enjoyed reading this post thanks for sharing, it will come in handy if I ever do my own oilchange. I am still baffeled that my dealer charged me for 6 Qts and insists our Redline takes just under 6 qts even when when our manuel says 5.
2007 Sky Redline Chilli Pepper Red
Opel Badging, Westers Hot Tune, Billet Grill, Side Vent Lights
Monsoon Audio, Illuminated Wind Restrictor, Sky Cooler Bag, Spoiler
3 Million Color Wireless LED Underbody Light Kit, Knight Rider Lights
Sky Pic's
Leather is offline
post #22 of 65 (permalink) Old 09-08-2009, 08:11 PM Thread Starter
Probably poured the first quart in without reinstalling the plug and charged you for it anyway.
I've seen people do this but not charge for it before.
Current Mods:
Stubby Antenna
Future Mods:
Upgraded Sub Woofer
post #23 of 65 (permalink) Old 09-08-2009, 09:52 PM
Skip's Avatar
The reason why the dealerships say 6 quarts is the engine in the other redline vehicle takes six with the sump pump installed. That engine is a side winder and the sump pump pan is like two parts. The redline engine in the Sky is a one pan engine...It only takes five quarts to fill it up. This has been mentioned at least ten times in as many threads....Skip.....
Skip is offline
post #24 of 65 (permalink) Old 04-03-2010, 11:20 AM Thread Starter
Almost 8 months later and it's that time again. She needs some new oil!
Current Mods:
Stubby Antenna
Future Mods:
Upgraded Sub Woofer
post #25 of 65 (permalink) Old 04-17-2010, 09:17 PM
Blue Sky's @ Night's Avatar
Just brought my Sky home today and couldn't find the filter, THANK YOU for this write up, change complete now, now time for some
Blue Sky's @ Night is offline
post #26 of 65 (permalink) Old 04-18-2010, 10:26 PM Thread Starter
Thanks
One question though - did you change the filter and oil right after you bought it?
Current Mods:
Stubby Antenna
Future Mods:
Upgraded Sub Woofer
post #27 of 65 (permalink) Old 09-09-2010, 12:23 AM
Can anyone tell me the type or brand of socket to use on the oil filter? I tried a craftsman (the smallest one I could find that will fit a 1/2" drive) but it won't fit...something going to the engine is blocking it from going on fully.
HELP!!!!
shanepratt is offline
post #28 of 65 (permalink) Old 09-09-2010, 11:46 PM
GT!
GT!'s Avatar
Quoted: 23 Post(s)
HELP!!!!
The oil filter needs a 32mm socket. This was listed in the first post.
32mm is pretty big, so I don't understand your comment about smallest one wouldn't fit.
-GT
GT! is offline
post #29 of 65 (permalink) Old 09-10-2010, 12:02 AM
I tried the 32 mm and it is the right size,it's just that something right above the oil filter is blocking me from fully putting the socket on the hex nut on top of the oil filter. looks like it is something going into the engine. I'm not too inclined on mechanics,but I have always changed my own oil. just wondering if there is a shallower socket and were can i buy it?
post #30 of 65 (permalink) Old 09-10-2010, 12:08 AM
o yeah and the pics that are posted, are they of a solstice or a sky? My sky is not a redline,does that make a difference? Thanks for the help!!!
