Door panel top has faded. - Saturn Sky Forums: Saturn Sky Forum
 6Likes
post #1 of 30 (permalink) Old 04-21-2019, 04:28 PM Thread Starter
stungjoe's Avatar
Quoted: 191 Post(s)
Does anyone have a cure for the top of the door panel when it fades? I tried "Forever Black" but it didn't do much. It looked good when it was wet but once it dried it was back to the way it was.
I wouldn't mind replacing it if I could find a guaranteed non-faded one.
Joe
FLASHED
2008 Red Line Carbon Flash SE Naked!
stungjoe is offline
post #2 of 30 (permalink) Old 04-21-2019, 05:16 PM
mtdjohn2018's Avatar
Quoted: 40 Post(s)
I had the same problem with mine. The tops of my panels were almost white. I purchased a vinyl / leather dye and ended up recoating my entire interior. Be careful because it can be quite messy and two coats should do it letting a day in between to dry. Mine came out great and it doesn't rub off! the panels look like new. I did mine while i had the inserts off being recovered so it was a bit earier that way.
ID:	104875   Click image for larger version
idle-mind likes this.
mtdjohn2018 is offline
post #3 of 30 (permalink) Old 04-21-2019, 05:22 PM Thread Starter
stungjoe's Avatar
Quoted: 191 Post(s)
Awesome, I will try that. I have to replace the door speakers soon so I will have the panels off already.
Thanks!
Joe
FLASHED
stungjoe is offline
post #4 of 30 (permalink) Old 04-21-2019, 06:37 PM
Quoted: 40 Post(s)
Thanks!
Make sure you are wearing gloves and don't get it on anything that you don't want to be black. Also, give them a good scrubbing with alcohol to remove any oils or grime before you start. I think you will be impressed with the results!
stungjoe and a280z like this.
post #5 of 30 (permalink) Old 06-16-2019, 09:08 AM Thread Starter
stungjoe's Avatar
Quoted: 191 Post(s)
I had the door panels off and replaced the speakers. As I was masking off the door handle I got the notion that the leather inserts snapped into the door panel. I was wrong. Instead of hearing the snap of a clip dislodging I was hearing the crack of the plastic welds breaking! When you dyed your door panels did you remove the leather insert panels and if so how did you re-glue them back into place? I saw a Mike Martin video on youtube using superglue and backing soda (not sure what the baking soda was for). I was wondering if this is the way to go????
Joe
FLASHED
stungjoe is offline
post #6 of 30 (permalink) Old 06-16-2019, 09:21 AM
Quoted: 133 Post(s)
. . . . . I wouldn't mind replacing it if I could find a guaranteed non-faded one.
How about a brand new one ?
RedOne07 is offline
post #7 of 30 (permalink) Old 06-16-2019, 09:24 AM Thread Starter
stungjoe's Avatar
Quoted: 191 Post(s)
I would like that if they're still available especially now that I have broken mine...haha
Joe
FLASHED
stungjoe is offline
post #8 of 30 (permalink) Old 06-16-2019, 09:29 AM
Quoted: 133 Post(s)
I do not pay a lot of attention to Sky spare parts, but for the Solstice new door panels pop up for sale weekly.
RedOne07 is offline
post #9 of 30 (permalink) Old 06-16-2019, 09:36 AM Thread Starter
stungjoe's Avatar
Quoted: 191 Post(s)
I see a couple of RH's available brand new but no driver's side
Joe
FLASHED
stungjoe is offline
post #10 of 30 (permalink) Old 06-16-2019, 09:58 AM
Quoted: 133 Post(s)
Angry within 12 minutes ? LOL
Yes all LH side parts are way more rare than RH parts, but they are out there. Just set your bait , look beyond Ebay, and you will find one.
RedOne07 is offline
post #11 of 30 (permalink) Old 06-16-2019, 10:40 AM Thread Starter
stungjoe's Avatar
Quoted: 191 Post(s)
If you're referring to the emoji, that's a sad emoji not anger.
Found some left hand early year models but those don't have the PDL switch
Joe
FLASHED
stungjoe is offline
post #12 of 30 (permalink) Old 06-16-2019, 11:40 AM
Quoted: 498 Post(s)
The baking soda just thickens the glue and, more importantly, reacts and causes it to set far more quickly.
I would try to re-weld them back on with a soldering iron first. But if not, try the super glue.
stungjoe likes this.
TomatoSoup is offline
post #13 of 30 (permalink) Old 06-16-2019, 11:46 AM Thread Starter
stungjoe's Avatar
Quoted: 191 Post(s)
Thanks TS
I will give the soldering gun a try first. I tried some rubber type cement that I had and it's no bueno for sure.
Fleabay has some RH panels for only $150. I sure wish they had the LH!
Joe
FLASHED
stungjoe is offline
post #14 of 30 (permalink) Old 06-16-2019, 12:25 PM
I am fairly certain that those panels are ABS like every other piece of plastic in the car. I have had really good success using the solvent cement for ABS pipe the you can get at any home improvement or hardware store.
JohnWR is offline
post #15 of 30 (permalink) Old 06-16-2019, 12:49 PM Thread Starter
stungjoe's Avatar
Quoted: 191 Post(s)
This stuff?
Joe
FLASHED
stungjoe is offline
