Engine Codes/DTC's - Page 2 - Saturn Sky Forums: Saturn Sky Forum
 1Likes
post #16 of 26 (permalink) Old 09-16-2011, 11:49 AM
MidniteBlues's Avatar
Quoted: 11 Post(s)
Originally Posted by GCS View Post
P2086 and P2096 engine codes confirmed at Saturn dealer this morning and added to above listing. Thanks and keep up the good work. P.S. If anyone knows of anyone who can produce PDF files, the engine code list would be an excellent candidate as a PDF file as it could be uploaded to smart phones and kept handy as an instant record. Next best thing to an app.
Attached is your PDF file as requested. Please check it and make sure it opens with your adobe..
MidniteBlues is offline
post #17 of 26 (permalink) Old 12-25-2011, 04:42 PM
EarthNTX's Avatar
This is fantastic...thanks!
EarthNTX is offline
post #18 of 26 (permalink) Old 05-02-2012, 11:14 AM Thread Starter
GCS
GCS's Avatar
Dtc
Midnite
Excellent ! Thanks. Now I can carry the list in my pocket for instant access. Great job.
GCS is offline
post #19 of 26 (permalink) Old 05-18-2012, 01:29 PM
i have only one code that keeps returnin on my turbo sky P2177 yet she runs fine and ideas of causes lean off idle bank 1 ??????
kwcuda70 is offline
post #20 of 26 (permalink) Old 04-03-2014, 01:00 PM
P0556 Don't see this one listed.
This is what I found. Brake Booster Pressure Sensor Performance.
Where would be a good place to start a thread on cause?
Rvn4me is offline
post #21 of 26 (permalink) Old 05-23-2014, 02:00 PM
I ran into a code that wasn't on your list, P0606 for my 2007 SKY.
Code P0606? - Fixed by TSB 08-06-04-037 - Pontiac Solstice Forum
This is the best info I could find on it, sounds like a Power Train:automatic Transmission:control Module (tcm, Pcm) or false code that just needs an update. I have a manual transmission though.
markzabin is offline
post #22 of 26 (permalink) Old 05-24-2014, 04:05 PM
P0087 Code
2009 Redline Sky...Got a P0087 (Low fuel rail pressure) that also derated the engine. Fuel pump runs to pressurize the system before start up. 1/2 tank of gas. Bad/weak fuel pump or clogged sock filter? If so, is there away to drain/pump out the gas before dropping the tank?
05/27/14 Edit: A little more research on my part reveals the problem is most likely the HPFP (High Pressure Fuel Pump) going out. HPFP is only found in the Red Line cars and makes that infernal "clicking" we hear at idle. In tank fuel pump is fine.
Munford Sky is offline
post #23 of 26 (permalink) Old 09-01-2015, 03:53 PM
Where are all the B,C codes at?
I have C0573, C0571
Rvn4me is offline
post #24 of 26 (permalink) Old 09-01-2015, 05:26 PM
Quoted: 1648 Post(s)
C codes are chassis codes but for the life of me I can't find those codes anywhere at the moment.
post #25 of 26 (permalink) Old 10-22-2018, 11:46 PM
Quoted: 13 Post(s)
Mine has shown 3 codes as of late...P0128. P0071, P000
All showed up within 15 minutes of leaving 6500' elevation and 45 degrees and dropping 800' in elevation and temps going up 15 degrees.
dbs1 is offline
post #26 of 26 (permalink) Old 10-23-2018, 02:02 PM
Interesting. I would start by seeing if the codes come back after clearing them. They shouldn't come on regardless of where you go or temperature changes. I'd also check and see what your coolant temps are running when that first one comes on.
