Heat shields - Saturn Sky Forums: Saturn Sky Forum
post #1 of 3 (permalink) Old 06-30-2019, 06:34 AM Thread Starter
Quoted: 10 Post(s)
Heat shields
Can you put the exhaust heat shield on after the turbo is installed?
Wallacelindsey is offline
post #2 of 3 (permalink) Old 06-30-2019, 07:01 AM
Quoted: 12 Post(s)
Are you talking about the 2.0 stock turbo, a aftermarket turbo, or a custom turbo for the 2.4?
If you are talking about the stock turbo I believe right after the turbo exhaust manifold is a spot on the frame to have a curved heat sheild right above the Cat converter. The Sky has a Cat as part of the downpipe for the exhaust system. It is the first I have ever seen where the cat is so close to the engine.
If you are refering to exhaust sheilding I believe the factory had some at the connect flange for the cat-back all the way to the channel bend for the exhaust.
2008 Saturn Sky Redline
Paint: Silver Pearl
SkyLine08 is offline
post #3 of 3 (permalink) Old 07-02-2019, 12:33 PM Thread Starter
Quoted: 10 Post(s)
Do I need to remove the turbo again before I put the exhaust manifold heat shield on not sure I mechanic put on the turbo without the heat shield.
