Low coolant msg - Saturn Sky Forums: Saturn Sky Forum
post #1 of 5 (permalink) Old 07-07-2019, 06:43 PM Thread Starter
Low coolant msg
Changed out coolant bottle with new one still same jumper connector msg goes away any ideas
ROADMASTER is offline
post #2 of 5 (permalink) Old 07-07-2019, 08:11 PM
Quoted: 493 Post(s)
I have no idea what you're saying. Could you add some words in there please?
TomatoSoup is offline
post #3 of 5 (permalink) Old 07-07-2019, 09:37 PM
DaveOC's Avatar
Quoted: 9 Post(s)
Same here!
Dave -
2006 Solstice NA #000741
DaveOC is offline
post #4 of 5 (permalink) Old 07-07-2019, 09:52 PM
Quoted: 493 Post(s)
OK, I got the following as a private message from Roadmaster... obviously a man of few words!
Coolant low on DIC replaced w/ new reservoir
Still get DIC message put a jumper across the connection and Dic goes away
SO, @ROADMASTER, from this I'm extrapolating that you were getting a 'low coolant' warning. and it went away after you jumpered across the connector to the coolant level switch on the coolant reservoir. Then you replaced the coolant bottle (presumably w/new switch) and still have the low coolant warning(?)
If this is correct, my immediate response would be: are you sure you have enough coolant? The level should be up to at least the molding join line on the bottle, or a bit above.
To confirm we are talking about the same thing, see the pic below. This shows a level that's maybe a bit overfull, but OK:
post #5 of 5 (permalink) Old 07-07-2019, 10:24 PM
DaveOC's Avatar
Quoted: 9 Post(s)
Thank you, Soup, for clearing that up. I would make the same assumptions as you. I think many of us have experienced a Low Coolant light when stopping hard on a hill with a nose down attitude.
The switch may be over-sensitive, or, there may be a fault in the wiring elsewhere between the switch and the device reading the switch.
YMMV
Dave -
DaveOC is offline
