LS3 416CI stroker Build and swap - Saturn Sky Forums: Saturn Sky Forum
 2Likes
  • 1 Post By RickyD
  • 1 Post By Ag_Sky
post #1 of 15 (permalink) Old 05-20-2018, 07:55 PM Thread Starter
RickyD's Avatar
Quoted: 69 Post(s)
I guys.
After building and messing with the 4 cylinder for a few years now then having the block crack on me. I've decided to bite the bullet and drop in a LS3. I already have the T56 and dual core cross flow radiator so instead of spending another 12K on it I'm just going to drop in a V8.
The LS3 we're building would be about the same as the factory GM LS376 525hp not just a 400hp LS. Im running a Callie crank, custom cam, The highest flowing CNC ported Dart cylinder heads with big valves and better pistons so it will end up around 416-418 cubic inch. By the specs it should be around 550-600 at the crank but I think it will make a little more then that. Well see once its done and I get it on the dyno. I got the new block from GM last week and are getting everything else together. I'm tired of sensors so its going to be like a NASCAR motor. Distributer with MSD programmable controller, a carburetor probably from Dan Vanderley owner of VDL fuel systems, headers but not sure which ones yet. Below is the new block. I'll post on my Quest for 200MPH thread as well if your watching that.
ID:	101386   Click image for larger version
ID:	101394   Click image for larger version
Yogi likes this.
Soon to be a LS3 but:
Lysholm 1.6 supercharger
T56 6 speed transmission
2.4 with L61 cyl head
Non VVT comp cams
DDM long tune header.
RK hood & Grnd Effects
DDMWorks suspension mods
AEM Meth Injection kit.
Elect exhaust cutout
VDI Doors
RickyD is offline
post #2 of 15 (permalink) Old 05-20-2018, 09:05 PM
Elff's Avatar
Quoted: 254 Post(s)
Good luck with this build.
LUSIFER is Sold!
say hello to
RYUK
Elff is offline
post #3 of 15 (permalink) Old 05-20-2018, 09:34 PM Thread Starter
RickyD's Avatar
Quoted: 69 Post(s)
Thanks Buddy
My Engine builder builds racing engines and knows everything about building a bullet proof LS motor. I hope!! lol
Lot of good reviews on him and his Moms my accountant and he's a very honest guy.
Non VVT comp cams
VDI Doors
RickyD is offline
post #4 of 15 (permalink) Old 05-21-2018, 05:39 AM
Ag_Sky's Avatar
That'll be one bad as Sky!
RickyD likes this.
2008 Saturn Sky LE5 Automatic
Custom Hypercoil Coilovers
425 # Front 550 # Rear
Koni SA shocks
Yokohama ADVAN Neova AD08 245/45 R18
Solo Performance Exhaust
DDM Stage II Super Charger
HPTuners Calibration (working)
Ag_Sky is offline
post #5 of 15 (permalink) Old 05-21-2018, 12:15 PM
Quoted: 178 Post(s)
What is your plan for the carburetor clearing the hood?
Rob the Elder is offline
post #6 of 15 (permalink) Old 05-21-2018, 03:38 PM Thread Starter
RickyD's Avatar
Quoted: 69 Post(s)
Have to wait and see.
I have the RK hood so I'll have to see which manifold is the lowest and check out much room I have.
Non VVT comp cams
VDI Doors
RickyD is offline
post #7 of 15 (permalink) Old 06-05-2018, 08:59 PM Thread Starter
RickyD's Avatar
Quoted: 69 Post(s)
Coop had a 383 carburated in his car
And it cleared the hood. Looking at the dimensions with front assy mounts, intake W carb and exhaust the LS3 is 2 inches shorter then a 383 so it should fit but we'll see.
Non VVT comp cams
VDI Doors
RickyD is offline
post #8 of 15 (permalink) Old 06-05-2018, 09:02 PM Thread Starter
RickyD's Avatar
Quoted: 69 Post(s)
Update.
The LS build is coming along costly,,,, I mean nicely.
HP calculations by machine shop counting for bore, stroke, cylinder head CFM flow, cam lift and duration, comp ratio and RPMs (capable of 7400) electric water pump and vacuum pump it comes out to around 650+HP at the crank on pump gas.
Non VVT comp cams
VDI Doors
RickyD is offline
post #9 of 15 (permalink) Old 06-06-2018, 04:08 PM
Quoted: 1621 Post(s)
Can't wait...but why stop at 650? LOL
post #10 of 15 (permalink) Old 02-21-2019, 09:46 AM Thread Starter
RickyD's Avatar
Quoted: 69 Post(s)
Engines done except for intake and carb.
Now to just run it on the engine dyno to tweak and see what she makes before putting it in the car
Non VVT comp cams
VDI Doors
RickyD is offline
post #11 of 15 (permalink) Old 02-21-2019, 12:42 PM
It looks a bit...
...naked. LOL
post #12 of 15 (permalink) Old 03-25-2019, 09:03 PM Thread Starter
RickyD's Avatar
Quoted: 69 Post(s)
Now to just run it on the engine dyno to tweak and see what she makes before putting it in the car [IMG class=inlineimg]/forums/images/smilies/smile5.gif[/IMG]
It looks a bit...
...naked. LOL [IMG class=inlineimg]/forums/images/smilies/biggrin2.gif[/IMG]
Does this look better 😊
Non VVT comp cams
VDI Doors
RickyD is offline
post #13 of 15 (permalink) Old 03-26-2019, 12:07 PM
Quoted: 128 Post(s)
Will it be going in soon?
MattM is offline
post #14 of 15 (permalink) Old 03-26-2019, 12:59 PM Thread Starter
RickyD's Avatar
Quoted: 69 Post(s)
hopefully. We’re going to run it on the engine dyno first for any final tweaking then in the car. Kind of depends on if we can get in quick. The shop said he knows it’s been a long project so he’d work on squeezing us in.
Non VVT comp cams
VDI Doors
RickyD is offline
post #15 of 15 (permalink) Old 05-23-2019, 06:53 PM
Quoted: 65 Post(s)
For some unknown reason, the Forum quit sending me notifications on your "Quest for 200 MPH" Thread, and I missed out on most of the updates that you posted last year. Then suddenly today, I got a new update notification!(?)
So sorry to hear that the old 4 banger didn't work out like you had hoped. It sure wasn't for a lack of effort nor $$$$!
Have you finished the Dyno work on the new LS yet?
The LS swap sounds like a lot of fun! Best of luck with your new project, Rick!
Yogi
"Black Bart"
5 Speed Stick
Single Disk Monsoon Sound
Yogi is offline
