Solution to Hard Starting and Limp Mode - Page 2 - Saturn Sky Forums: Saturn Sky Forum
 2Likes
post #16 of 34 (permalink) Old 09-24-2012, 07:15 PM
J SKY's Avatar
P2138 Solved.
Took the C100 connector apart and cleaned it. Also applied dielectric grease for good measure. In the 3 weeks since the code hasn't repeated- the longest yet. Glad I didn't have to solder anything.
07 Silver 2.4 #329
J SKY is offline
post #17 of 34 (permalink) Old 07-24-2014, 10:14 AM Thread Starter
RickyD's Avatar
Quoted: 70 Post(s)
Seems a couple people have had some problems so I'll bump this.
If you've had problems this may fix it. I'll try to post the exact pins that need to be soldered today.
Soon to be a LS3 but:
Lysholm 1.6 supercharger
T56 6 speed transmission
2.4 with L61 cyl head
Non VVT comp cams
DDM long tune header.
RK hood & Grnd Effects
DDMWorks suspension mods
AEM Meth Injection kit.
Elect exhaust cutout
VDI Doors
RickyD is offline
post #18 of 34 (permalink) Old 07-24-2014, 12:05 PM
ArikDahn's Avatar
Quoted: 15 Post(s)
I know I'm one of the folks with issues.
It is NOT a good idea to remove this connector completely in one fell swoop WITHOUT TAKING THOROUGH PICTURES OF THE CONNECTOR'S WIRING BEFOREHAND.
If you ARE having issues with this connector, it might disintegrate when you remove the gray plastic guards holding the pins in like mine did leaving you with a handfull of very similarly colored wires and no idea which ones connect to which other ones
Concurrently, depending on your vehicle trim level, transmission, and presence of LSD, the wires may or may not be the same color on both sides of the connector.
Gallifreyan likes this.
ArikDahn is offline
post #19 of 34 (permalink) Old 07-24-2014, 12:16 PM Thread Starter
RickyD's Avatar
Quoted: 70 Post(s)
That sucks Dude.
Good luck straightening it out .
Non VVT comp cams
VDI Doors
RickyD is offline
post #20 of 34 (permalink) Old 07-26-2014, 07:11 PM
ArikDahn's Avatar
Quoted: 15 Post(s)
... but if you STILL want to do this, here's the connector pinout/wire color guide.
All wires line up on all Skies (so it appears) except for the D-Row, which is different for every transmission/trim level.
On mine, I have the orange/green wire on one side. Because I have a manual redline model, I found out very... uhh... scientifically.. yeah (guessed), that this corresponds to the tan wire. So the gray wire corresponds to the blue/white. If anybody wants to do this. If I find out something's made poorly, I gotta rip the whole thing out. No 1/2-assin' it! Thanks again for this sticky.
Name:	C100 Harness Connector.jpg
ArikDahn is offline
post #21 of 34 (permalink) Old 07-27-2014, 10:57 AM
Quoted: 493 Post(s)
ArikDahn, the pic you posted seems to be a thumbnail. Way too small to be able to read anything, anyway.
Can you try again?
TomatoSoup is offline
post #22 of 34 (permalink) Old 07-27-2014, 02:24 PM
ArikDahn's Avatar
Quoted: 15 Post(s)
Can you try again?
Wow, you're right. How the heck did that happen? I will re-up when I get home. Working noon-midnight today.
EDIT: Okay I re-upped the image. It looks good now. Probably something about how vB deals with png's. Once I converted to jpg, seems we're good. Thanks for letting me know.
ArikDahn is offline
post #23 of 34 (permalink) Old 06-02-2015, 07:36 PM
In regards to the connector and the harness, would it be advisable to maybe use electrical tape to hold this together better? Or is there another way to prevent this issue?
markzabin is offline
post #24 of 34 (permalink) Old 10-23-2015, 10:29 PM Thread Starter
RickyD's Avatar
Quoted: 70 Post(s)
Just noticed your question Markzabin
There it really no other way to fix this problem. With the small wires and conne tier pins vibration alone causes the problem. You could try putting some thin foam rubber around it but eventually it's going to have a problem anyway.
Non VVT comp cams
VDI Doors
RickyD is offline
post #25 of 34 (permalink) Old 10-25-2015, 06:18 PM
Quoted: 68 Post(s)
Thanks for posting this very valuable info, Rick!
Re: the photos. You said that the first shows the location of the C-100 connector. Stupid me! I can't identify any components in the photo to tell where it is!
Could you please give a verbal description of the location? LH side of motor? near firewall? Or what?
Sorry for the silly question.
Thanks again!
Yogi
"Black Bart"
5 Speed Stick
Single Disk Monsoon Sound
Yogi is offline
post #26 of 34 (permalink) Old 10-25-2015, 08:21 PM Thread Starter
RickyD's Avatar
Quoted: 70 Post(s)
Hi Yoki
No question is silly :blush: The connector is under the bracket the holds the fuse box. The easiest way to get to it is take the inner wheel well out then it's right there.
RickyD is offline
post #27 of 34 (permalink) Old 10-26-2015, 10:20 AM
Quoted: 68 Post(s)
Hi Yoki
OK. Thanks, Rick!
Yogi
"Black Bart"
5 Speed Stick
Yogi is offline
post #28 of 34 (permalink) Old 03-13-2016, 03:22 AM
similar problems, but a question
I have been having similar problems, Limp mode, codes that are all over the place from fuel rail to throttle position sensor, cam shaft timing sensors...ect. My question is, how did you know which wires on the C100 harness to jump? I noticed you only jumped a few of the wires. I plan on working on rewiring this tomorrow.
Thanks
Aethelos is offline
post #29 of 34 (permalink) Old 03-13-2016, 03:51 AM
Quoted: 1707 Post(s)
Have you checked your battery already? Many times problems like these can be traced to a bad battery or charging system. Be sure to rule this out first before jumping pins in the harness.
Robotech is online now
post #30 of 34 (permalink) Old 03-13-2016, 08:09 PM
I had it in the shop with a mechanic for 2 1/2 weeks, before he said "I don't know, find someone better then me." I am sure he would have checked the charge system and battery... I hope.
Aethelos is offline
