Stereo Head Unit Replacement - RasPi OpenAuto - Page 3 - Saturn Sky Forums: Saturn Sky Forum
 6Likes
post #31 of 46 (permalink) Old 06-28-2019, 01:14 PM
Quoted: 468 Post(s)
Originally Posted by Bpm009 View Post
No monsoon system in my car. I pulled it all out and retested on the bench, which worked. I plan on rewiring it tonight because mismatched +/- was all I could think of too but it looked like I had everything correct. Thanks for the clarification on the impedance mismatch I was pretty sure but not positive. I am using the GM LAN wire harness and followed the wire labeling on the instructions. Will update tonight.
+/- Doesn't matter for producing sound (just need correct phase for correct stereo separation).
I would get a 9V battery and push short wires into each of the speaker wire pairs at the radio connector, then touch the other ends to the battery. If you get clicking/thumping/fritzing, then you know the speaker wires are connected through and that you have the correct ones identified.
The HifiBerry *is* a class-D amp, so it's possible that it has an issue with really low impedance (although I would think it unlikely). Have you checked the amp specs?
UPDATE: Hmm. Just looked on their web site and it states:
The Amp2 is designed to work with all speakers or 4-8 Ohm impedance. It supports sample rates from 44.1-192kHz (16-32bit).
TomatoSoup is offline
post #32 of 46 (permalink) Old 06-28-2019, 02:48 PM Thread Starter
Quoted: 8 Post(s)
I like th 9V battery test idea, I'll give that a go also. Yeah the specs mention 4-8ohm impedance I would still think I should get something out of the 4ohm rears even if it has an issue with the 2ohm sides? After the 9V battery test I'll connect just the L/R rear speaker cables and see what happens before trying the full setup.
UPDATE:
Tried the 9V battery test and got no static or sounds from the speakers... now I'm stuck again. The only thing I can think of is the wire harness is either wired wrong or bad.
I have the LC-GMRC-LAN-03 harness
Bpm009 is offline
post #33 of 46 (permalink) Old 06-30-2019, 12:35 PM Thread Starter
Quoted: 8 Post(s)
Does anyone have a wiring schematic for the harness plugs that go into the stock radio? I've been looking around online but keep getting shady website links. I want to do a pin to pin check and compare the corresponding aftermarket harness to the radio plugs.
So far I've tested with a 9V battery, the intended setup and I tried my 3.5mm phone output through a mini amp. All nothing. The speakers should work even with the car off right, independent of car power? This is baffling me...
Bpm009 is offline
post #34 of 46 (permalink) Old 06-30-2019, 12:55 PM
Notice that the same pins do double duty for Monsoon/non-Monsoon, and since you do not have a Monsoon system the speaker connections go straight to the speakers.
Notice also that each speaker has its own (+) and (-) connection.
Name:	08-11-234-5 Radio Connectors.jpg
JohnWR is offline
post #35 of 46 (permalink) Old 06-30-2019, 05:16 PM Thread Starter
Quoted: 8 Post(s)
You're awesome John, much appreciated. Fortunately/unfortunately everything lines up correctly. As a test I disregarded the harness and put Dupont jumpers from the +/- pins on the car plugs directly to my mini amp. Still no sound. Plugged the old radio back in for sanity purposes and it works... I have no idea how to troubleshoot further...
Bpm009 is offline
post #36 of 46 (permalink) Old 06-30-2019, 10:44 PM
Quoted: 898 Post(s)
John has a skill set that is amazing. I need him to return to Florida to install a backup camera in my mirror. No installer is capable of this. Come on down John.
marlboromike is offline
post #37 of 46 (permalink) Old 06-30-2019, 11:56 PM
You're welcome, sorry it hasn't helped yet.
I can only think of two possibilities here:
1) You are mixing up the speaker wires and using the (+) from one with the (-) of another.
2) You do actually have a Monsoon system, and aren't getting anything because the amp is not powered.
Two things to do:
1) Double-check the RPO codes in the glove box for a UW5 or a UQ3
2) Connect an ohm meter across the (+) and (-) terminals you are using to measure the impedance.
TomatoSoup likes this.
JohnWR is offline
post #38 of 46 (permalink) Old 07-01-2019, 07:30 PM Thread Starter
Quoted: 8 Post(s)
Well I learned something new today. I thought the Monsoon system was only paired with the 6 CD changer (which I knew I didn't have) but I did find a UQ3 on my glove box. I'm no audiophile but I would not have guessed I even had a sub in the car from the way the audio quality seems.
Once again, thanks John for the invaluable info and ideas. I'm mostly relieved that the problem is clear now. So, is the solution as simple as sending the battery's accessory power to the amp? Looking at the connector wiring diagram I see a "Radio On Signal" and "Remote Radio Control Signal". Pins 1&2 are also L/R audio signal + which I don't understand.
It's sad that I would have preferred to not have the Monsoon now haha.
Bpm009 is offline
post #39 of 46 (permalink) Old 07-01-2019, 09:24 PM
The head units are generally considered to be pretty weak, and changing it generally is considered to be the biggest step-change in sound improvement.
I too am glad that the mystery has been solved, and I think that ultimately you will be happier with the Monsoon than without it. You will have to reduce your output to prevent over-driving the amp.
Pins 1 & 2 are L & R XM audio (+), with pin 9 as the (-) for both channels.
Pin 3 is the 12-volt signal from the head unit to turn on the amp. Any time there is 12 V on that wire the amp will be on, and it gets its power straight from the fuse block, so control it carefully to avoid a dead battery.
Pin 15 Remote Radio Control mutes the amp when it sees 12 V. I left it un-connected.
JohnWR is offline
post #40 of 46 (permalink) Old 07-01-2019, 10:04 PM Thread Starter
Quoted: 8 Post(s)
I may have a question about over driving the amp when I get to that point, not sure what output needs to be reduced. I'm excited to test this out, I have an extra channel on my relay that I can use to control the signal to the amp so that will work perfectly. Will report back my findings. Thanks again for all the great explanations!
Bpm009 is offline
post #41 of 46 (permalink) Old 07-01-2019, 10:05 PM
Quoted: 468 Post(s)
Ah-HA! So what did I win?
post #42 of 46 (permalink) Old 07-01-2019, 10:07 PM Thread Starter
Quoted: 8 Post(s)
My endless embarrassment of such a simple solution to a problem I was so sure I didn't have
Bpm009 is offline
post #43 of 46 (permalink) Old 07-13-2019, 05:24 PM Thread Starter
Quoted: 8 Post(s)
Mid step update:
It's been a little while since I last updated and there has been an interesting "lessons learned" experience. I ended up having a battery that was at the end of its life and when I went for a trial run I must have drained the battery too much because I attempted to start the car and nothing. Wouldn't even charge on the charger after that and replaced the battery. Side note issue is I ended up bricking the Raspberry Pi due to under voltage (won't show SD card activity anymore) also corrupted the SD card...
Anyway, replacement battery, Raspberry Pi and Micro SD card.... plus redeveloping some of the scripts I had put together because I built them on the Pi and didn't save them and I'm back to where I was 2 weeks ago. Installed the setup in the car and.... it works!
Currently Remaining:
- Finalizing Mic position, I currently have it clipped to the left side of the center console near my right thigh but haven't settled on that yet. (I haven't went through the mic placement post I've seen on here yet)
- Have not started routing or mouting the backup camera
- Setting up the usb hub in the glove box cleanly which will possibly route to the "cigarette lighter" plug in a near future update for passenger phone connection
Below is a picture of the unit in place, the AC controls aren't full snapped back into place but you get the idea
***Anyone know why no matter what I do my picture attaches sideways?***
Bpm009 is offline
post #44 of 46 (permalink) Old 07-13-2019, 05:52 PM
Mid step update:...............
Looking good. Sorry about the setbacks.
Is there an under-volt protection circuit in your future?
I think what you have to do is put the picture on your computer, correct the rotation, and save it with a different name.
For some reason just saving it doesn't correct the orientation.
JohnWR is offline
post #45 of 46 (permalink) Old 07-13-2019, 10:02 PM
Quoted: 468 Post(s)
Hmm, I never realised you could brick an RPi by under voltage. Very strange.
As for Mic position, I posted about this years ago... I tried a number of places when I was using a Parrot Bluetooth setup. The best place I found was in the top left corner of the windshield, right where the factory put theirs. Go figure
Lastly, how did you end up clipping the screen in place - did you use speaker grill clips?
