Taillight/turn signal out. How do I change the bulb? - Saturn Sky Forums: Saturn Sky Forum
 2Likes
  • 1 Post By SkyVue2
  • 1 Post By marlboromike
post #1 of 14 (permalink) Old 11-21-2008, 09:16 AM Thread Starter
Does anyone know how to access the rear turn signal bulbs? One of mine went out and I can't figure out how to get to it to change it.
lostcause is offline
post #2 of 14 (permalink) Old 11-21-2008, 10:01 AM
Quoted: 871 Post(s)
Not an easy task...but with some perserverance, it is feasible. To explain it on this post is nearly impossible. There r 2 hexnuts when u open the trunk on each side....on top of the tail light...u must take them out...now is the hard part..get a chisel...get some electrical tape around the tip of it..this is done so u do not mess your paint on the bumper...put it uder your tail light and with a wiggle (push up just slightly) and pull your tail light toward you...it has much resistance...u will think u r breaking it off...it is a snap on type of attachment...eventually it will give...and then u have access to that bulb...this is not the best of instructions...maybe someone else can handle it better than me...but the most important thing to remember is the chisel or screw driver with tape around it..this way u will not mess up the paint on your bumper...u definitely will need something to pry the tail light off...Good Luck
marlboromike is online now
post #3 of 14 (permalink) Old 11-21-2008, 02:19 PM
ceeker's Avatar
Someone suggested using a paint stirring stick like you get when you buy paint. The lower pin is the hardest to get undone.
Their are two pins holding the tail light in once you remove the top two screws. The two pins are top right, bottom left on the right tail light and top left, bottom right on the left tail light.
Usually the top pins come out easy, it's the bottom ones that can give you trouble.
I have removed mine probably 15 times over the last year working on mods and it's still not an easy task.
You can usually get the top pin out by pulling just a little, the bottom pin will take some prying so this is where the paint stirring stick comes in.
Once the bottom pin comes loose you need to remove the tail light by sliding it out away from the car as it kind of tucks in on the trunk side.
Be carefull as many have cracked the lower corner of their tail lights by trying to pull the lower pin out.
Silver/RL 2007 - Red/Black Leather
DeJon CAI, IC Pipes
Magnaflow, Opel Badges, Tail Lights, Back Up Light.
Hahn Intercooler, Westers Race Tune.
http://www.discounttiredirect.com
ceeker is offline
post #4 of 14 (permalink) Old 11-21-2008, 10:51 PM
Bogie's Avatar
It's a royal PITA. Lot of things can go wrong. From cracking the fixture, scratching the car, breaking the weather strips.
Perhaps the worst user serviceable access design on the entire car. Worse than the battery access.
I changed many a bulbs in my day. Some cars have been easy and obvious. Others have been not-so-obvious, but once you knew the trick, they were easy. With the SKY, even if you know the trick, and have done it before, it's still PITA.
If you do try it yourself, I would recommend having a thick micro towel at the ready once you free the fixture. The pins on the bottom of the fixture are pointed and can easily scratch the bumper, and it's nigh impossible to avoid the fixture moving about as you replace the bulb. So, as soon as you free the fixture, slip that towel between the fixture and the bumper.
2008 Redline Auto
Born 7/20/07
Snagged 8/31/07
Released 8/8/15
Bogie is offline
post #5 of 14 (permalink) Old 11-21-2008, 11:04 PM Thread Starter
in other words...I should take it to the dealer.....
I'm still just under my 36K bumper to bumper.
Dealer it is!!
post #6 of 14 (permalink) Old 11-22-2008, 02:10 PM
Bogie's Avatar
...ask 'em if they've done it before. If not, make sure they know about the scratch potential once the fixture is loose.
2008 Redline Auto
Born 7/20/07
Snagged 8/31/07
Released 8/8/15
Bogie is offline
post #7 of 14 (permalink) Old 05-29-2019, 06:40 AM
Quoted: 5 Post(s)
slsmag is offline
post #8 of 14 (permalink) Old 05-30-2019, 08:32 AM
SkyVue2's Avatar
Quoted: 84 Post(s)
Why revive a decade old thread with a link to Fakebook?
SkyVue2 is offline
post #9 of 14 (permalink) Old 06-09-2019, 12:50 AM
Quoted: 5 Post(s)
Because the TOPIC is searchable (which is how I fond it) and the replies above did not match up with my own experience - which I documented with instructions and photos - on FB. While you may not find that useful, others may. But thanks for your criticism.
slsmag is offline
post #10 of 14 (permalink) Old 06-09-2019, 08:56 AM
SkyVue2's Avatar
Quoted: 84 Post(s)
No need to turn changing a lightbulb into a federal project
OK, got it. Could have started a new thread here and described your How To; maybe with a few pics and a link to a Utube video instead of a direct line away from this site? Otherwise the subject has been discussed here quite thoroughly over the past 12 years.
Previous relevant thread -> Tail Lamp Replacement
a280z likes this.
SkyVue2 is offline
post #11 of 14 (permalink) Old 06-09-2019, 11:04 AM
Black Sheep's Avatar
Quoted: 9 Post(s)
Check out Mike Martins youtube. His latest is changing out the tail lights.https://youtu.be/59aDhVhRetE
Dwaine
2007 American Redline
Vin 1G8MG35X27Y120974
Black Sheep is offline
post #12 of 14 (permalink) Old 06-09-2019, 04:23 PM
Quoted: 871 Post(s)
Forget that web site...he makes something simple difficult....if u want just plug and play...go here. This is what we used. And if anyone is interested, I will ship my tail lights with these sequential lights included for 400 dollars and that would include shipping. If u live in Florida, 350 and I will install them if u bring your car here...
WebElectric Products - Sequential Turn Signals, Sequential Taillights, Sequential Tail Lights, Dynamite Stick Sequential, Pulsing Brake Light Pulser Flasher, One Touch Convertible Top, Dynamite Stick, One Touch Turn Signals, Daytime Running Lights, L
mtdjohn2018 likes this.
post #13 of 14 (permalink) Old 06-10-2019, 10:41 AM
mtdjohn2018's Avatar
Quoted: 29 Post(s)
I have to agree with marlboromike here. I admire the passion that Mike Martin has for his Sky but, some of his videos and the mods he makes are pretty cheesy.
When I first got my Sky I saw his video on putting on the Red & Black seat covers. So I went out and purchased a set of them and did my seats. Guess what? They look like cheap, ill fitting seat covers! I ended up after a week removing them and having a professional upholstery shop do my seats. In most of Mike's videos, he does make things look harder than they actually are to accomplish. He has a bit of the "bull in a china shop" approach to working on his car. But again, I do appreciate his passion and his willingness to pass on information.
mtdjohn2018 is offline
post #14 of 14 (permalink) Old 06-10-2019, 02:22 PM
Quoted: 9 Post(s)
Mostly I was just pointing to the tail light removal part for lostcause. There's always something to take away on this learning curve that we are on!😀
Dwaine
