Transmission question - Saturn Sky Forums: Saturn Sky Forum
post #1 of 9 (permalink) Old 03-07-2019, 09:22 PM Thread Starter
Quoted: 25 Post(s)
I have a 2008 NA auto and was wondering if it is normal for it to shift quickly through gears at fast acceleration? Shouldn't it rev to redline before it shifts?
tporter is offline
post #2 of 9 (permalink) Old 03-08-2019, 10:27 AM
Quoted: 1772 Post(s)
Good question and I believe it should get close if you're at WOT. Someone with an auto who can chime in?
post #3 of 9 (permalink) Old 03-08-2019, 01:37 PM
DaveOC's Avatar
Quoted: 9 Post(s)
It should be shifting near to redline on full throttle runups, but I would suggest that there is some lag in our instruments so that it looks like it's shifting earlier.
YMMV
Dave -
2006 Solstice NA #000741
DaveOC is online now
post #4 of 9 (permalink) Old 03-31-2019, 04:30 PM Thread Starter
Quoted: 25 Post(s)
After 40 mph, it tends to "drop" to the next 3 gears fast, wonder if i get a scan tool , can i program the shift points? Just annoying that's all.
tporter is offline
post #5 of 9 (permalink) Old 03-31-2019, 08:45 PM
Quoted: 123 Post(s)
A scan tool won't do it. I would suspect that there is something wrong with the car, not that the shift points need to be reprogrammed honestly. How long have you had the car and has it always done that?
Amorget is offline
post #6 of 9 (permalink) Old 03-31-2019, 10:36 PM
What a scan tool will be able to tell you is if you are actually at full throttle.
JohnWR is online now
post #7 of 9 (permalink) Old 04-03-2019, 11:23 AM Thread Starter
Quoted: 25 Post(s)
I've only had it a few months, and it has always done that, doesnt shift awkward, just fast 3-5
tporter is offline
post #8 of 9 (permalink) Old 04-03-2019, 05:52 PM
idle-mind's Avatar
Quoted: 35 Post(s)
Maybe the previous owner did some programming to change the shift points?
idle-mind is offline
post #9 of 9 (permalink) Old 04-04-2019, 11:28 AM
Even on the auto the factory shift points at WOT take the engine to near redline. Should have 2nd gear shifting around 50 MPH. Make sure your really WOT. No floor mats behind the gas pedal or anything. Don't let off, people have a tendency to let off slightly as the speeds climb and that will be enough to have the ecu tell the car to shift up.
Scan tool will let you know what max throttle position is if you are sure the gas pedal is to the floor and you think it's still not WOT. That's a good place to start.
I doubt anyone with an NA would have messed with the shift points via a tune. There's really nothing to be gained.
RedSky19 is offline
