The two check valves for the cooling system..?? - Saturn Sky Forums: Saturn Sky Forum
 3Likes
post #1 of 26 (permalink) Old 06-05-2019, 09:57 PM Thread Starter
Need4Speed2's Avatar
Quoted: 38 Post(s)
I stumbled upon this today...
"The two valves are there to remove air bubbles from interrupting the flow of coolant in the engine. When they fail, the car will run hot while driving, but will decrease in temperature when stopped. Also the heater will blow only cold air. These are both telltale signs to replace the check valves. As I understand it they are cheap and easy to fix."
Where are these two two check valves for the cooling system? (Photos?)
Need4Speed2
SF, CA
2008 Redline, 89k miles
Need4Speed2 is offline
post #2 of 26 (permalink) Old 06-05-2019, 11:10 PM
Junior Member
a280z's Avatar
Quoted: 17 Post(s)
I don't think they are there from the factory, but might be there if the TSB was followed after previous owner complaint.
Here is a good description, and I saved the picture of the two locations from the link:
https://gm.oemdtc.com/356/engine-ove...rn-opel-daewoo
a280z is offline
post #3 of 26 (permalink) Old 06-06-2019, 12:08 AM
DaveOC's Avatar
Quoted: 9 Post(s)
Here's the TSB which describes the symptoms and how to install the check valves. They are not installed by the factory.
See attachment:
File Type: pdf TSB_10-06-02-001-coolingcheckvalves.pdf (264.1 KB, 65 views)
RedOne07 likes this.
Dave -
2006 Solstice NA #000741
DaveOC is offline
post #4 of 26 (permalink) Old 06-06-2019, 12:46 AM Thread Starter
Quoted: 38 Post(s)
Thanks guys!
Need4Speed2
SF, CA
post #5 of 26 (permalink) Old 06-07-2019, 02:15 PM
Junior Member
wspohn's Avatar
Quoted: 353 Post(s)
They are just one way valves that look like thimbles. Just make sure you lube them up and insert them the right way (I guess that advice applies to a lot of things...). There is a picture in the TSB that Dave posted.
Available for under $20 on Ebay, they once listed at $800 a pair in Canada ('only $400 in the US)!
1957 Jamaican MGA
1958 MGA Twincam
1962 MGA Coupe
1971 Jensen Interceptor
2007 BMW Z4M coupe
departed
1965 Jensen CV8
1969 MGC roadster,
1969 Lamborghini Islero S
1988 Pontiac Fiero GT
Bill in BC
wspohn is offline
post #6 of 26 (permalink) Old 06-07-2019, 02:55 PM
Quoted: 124 Post(s)
They are even cheaper on RockAuto. Just about $25 for the pair shipped.
Amorget is offline
post #7 of 26 (permalink) Old 06-07-2019, 02:57 PM
Junior Member
wspohn's Avatar
Quoted: 353 Post(s)
Yeah - I have always wondered how GM could possibly justify the original prices.....
1957 Jamaican MGA
1958 MGA Twincam
1962 MGA Coupe
2007 BMW Z4M coupe
departed
1965 Jensen CV8
1969 MGC roadster,
Bill in BC
wspohn is offline
post #8 of 26 (permalink) Old 06-07-2019, 05:00 PM
Did the original price include anything else? Installation, coolant replacement, etc? The price would still be high, but not a ridiculously as if it was just parts.
JohnWR is offline
post #9 of 26 (permalink) Old 06-07-2019, 05:11 PM
Junior Member
wspohn's Avatar
Quoted: 353 Post(s)
No, just the valves. I recall the parts man looking them up and guffawing when he saw the price, and saying that it was a good thing it was under warranty. The identical part number dropped to a very low figure with no change in the parts. I saw them when they came in - a bag with the two valves in it.
Have always wondered what the story was. Maybe a supplier ripped GM off, or GM didn't try and source the parts elsewhere? If anyone has the parts books and can see when the parts first came out and what the application was, it would be interesting. The part number is in the TSB that was posted.
It would have been much less funny for anyone that bought a first year turbo car and whose warranty had expired, so they had the option of paying exorbitant amounts or living with the overheating.
I also recall the dealer not being aware of the problem - I had to show them a copy of the bulletin before they agreed to deal with it and that was only after trying a coolant replacement and using their special filler etc. (which didn't solve the problem).
1957 Jamaican MGA
1958 MGA Twincam
1962 MGA Coupe
2007 BMW Z4M coupe
departed
1965 Jensen CV8
1969 MGC roadster,
Bill in BC
wspohn is offline
post #10 of 26 (permalink) Old 06-07-2019, 05:19 PM Thread Starter
Quoted: 38 Post(s)
$9.93 ea at Rockauto "Coolant Air Bleeder"
https://www.rockauto.com/en/parts/ac...ir+bleeder,304
Need4Speed2
SF, CA
post #11 of 26 (permalink) Old 06-07-2019, 10:16 PM
DaveOC's Avatar
Quoted: 9 Post(s)
I suspect that the culprit was the guy/gal that did the original data entry for those check valves, and who typed "$800" instead of "$8.00" on the computer, and then never double-checked his/her entry after it was in the system, or maybe the data terminal the person was using had a broken or sticky "." key.
I have seen and fixed similar oopsies on other parts in similar systems, and GM's parts system is more complicated that most others, just due to the number of parts entered into GM's systems.
Dave -
DaveOC is offline
post #12 of 26 (permalink) Old 06-08-2019, 11:25 AM
Quoted: 115 Post(s)
My Sky seems to run hot at times. Am in AZ where its 100-110F. Car runs 200-210 on flat ground, 215-220 climbing hills. During winter here when it's 50-70F car runs 195-200 on flat but will still be 210-215+ on hills.
Heater blows hot air. A/C blows cold. When climbing hills I tend to back off the throttle or am afraid it will climb past 220. Had WP replaced (was leaking) and coolant flush at dealer. No change. With heater working fine is it still possible air is in system?
2007 Silver/Red Sky Redline
Huff is offline
post #13 of 26 (permalink) Old 06-08-2019, 03:33 PM
lorennerol's Avatar
Quoted: 93 Post(s)
That's normal, in my experience, with the 2.0 cars.
Owned mine since 2007 and never had an overheat problem except when I had issues with the fan (a couple blown fuses and two failed controllers). If you get the air out of the system and don't open it when hot, there shouldn't be any need for check valves.
2008 Red Line
D30 Override red on red
Three pedals
Monsoon stereo w/ USB input
Custom lighted Windrestrictor
K04 Big Wheel Turbo
Solo Street Race exhaust
Norm's custom rear facia
Ordered: 6/23/07
Born: 7/16/07
Del: 8/24/07
lorennerol is offline
post #14 of 26 (permalink) Old 06-08-2019, 03:50 PM
Junior Member
wspohn's Avatar
Quoted: 353 Post(s)
It should be remembered that the light doesn't come on until the temp is way past where you'd want it to be, so unless you drive with the setting on the DIC set for coolant temp, you could have been overheating frequently and not know it. (I don't recall when the warning light comes on and it isn't in the driver's handbook, but recall it being pretty high - 230+ - anyone know for sure?)
My default DIC setting ever since has been engine temp!
1957 Jamaican MGA
1958 MGA Twincam
1962 MGA Coupe
2007 BMW Z4M coupe
departed
1965 Jensen CV8
1969 MGC roadster,
Bill in BC
wspohn is offline
post #15 of 26 (permalink) Old 06-09-2019, 01:34 AM
Quoted: 124 Post(s)
The dash warning light comes on at 250.
Amorget is offline
