Dual Problem - Saturn Sky Forums: Saturn Sky Forum
post #1 of 27 (permalink) Old 08-10-2018, 07:52 PM Thread Starter
Quoted: 63 Post(s)
Dual Problem
Ok guys here's the thing, last week after coming back home from a friends place i parked the car, waited 2 minutes and when i turned the key to turn the car off it did the same thing it would do if i started it in gear (hiccup).
Didn't pay much attention (although i was surprised when it made that sudden movement) until yesterday when i turned the key to start it up and all the gauges went to bellow zero, speed, RPM and even fuel.
It did turn on the 2nd time i tried but yes now i am worried.
Is this the infamous missfire or something else?
Thanks in advance.
NikK is offline
post #2 of 27 (permalink) Old 08-11-2018, 07:53 AM
Junior Member
Quoted: 40 Post(s)
No idea. Manual or auto?
Flashy is offline
post #3 of 27 (permalink) Old 08-11-2018, 08:43 AM Thread Starter
Quoted: 63 Post(s)
Manual (there was an auto redline?)
NikK is offline
post #4 of 27 (permalink) Old 08-11-2018, 08:48 AM
Junior Member
Quoted: 40 Post(s)
Yes.
Does the car do the same thing if you switch the engine off with the clutch pedal fully depressed?
Flashy is offline
post #5 of 27 (permalink) Old 08-11-2018, 09:05 AM Thread Starter
Quoted: 63 Post(s)
Yes.
Each thing happened once only to date so it's not like i can check.
NikK is offline
post #6 of 27 (permalink) Old 08-11-2018, 11:07 AM
Junior Member
Quoted: 148 Post(s)
As far as I know the automatic was never offered in Europe in the Opel GT.
mstrjon32 is offline
post #7 of 27 (permalink) Old 08-11-2018, 11:19 AM Thread Starter
Quoted: 63 Post(s)
I thought only the other type was available as an auto regardless of place.
Anyways these two have only happened to me? Find that strange to believe.
NikK is offline
post #8 of 27 (permalink) Old 08-11-2018, 12:13 PM
Quoted: 55 Post(s)
Never had that on the sky but have had the needle thing happen in my explorer...usually due to bad battery or loose major connection. Not much to go off here, unfortunately a worst case scenario not being able to replicate it, and (seemingly) two very different issues.
Curious question- do euro cars have a clutch/neutral safety switch? Having to start with the clutch depressed is a US thing I think?
Rockchops is online now
post #9 of 27 (permalink) Old 08-11-2018, 12:40 PM Thread Starter
Quoted: 63 Post(s)
The car is the same as the Redline so yes in order to start you need to press the clutch.
As for the first part if it was a battery error the lights wouldn't turn on, not the exterior nor the interior ones (plus the battery is like 4 months old). My lights all turned on and so did the gauges....They just fell straight down like the engine was unable to start or something like that.....Heard many times about a misfire and i thought this could be it.
NikK is offline
post #10 of 27 (permalink) Old 08-11-2018, 01:15 PM
lunaticfringe's Avatar
Quoted: 52 Post(s)
After reading stuff on this forum and from personal experience a bad or weak battery can make your car do strange things. How old is your battery? if it's old you may want to start there.
2007 base Sky
Purchased 5/12/18 with 37K-not a scratch
Live in N. NV
lunaticfringe is offline
post #11 of 27 (permalink) Old 08-11-2018, 04:04 PM Thread Starter
Quoted: 63 Post(s)
4-5 months old and it's of a higher capacity than the stock battery.
Besides even if it was the battery that would explain the car not turning on (but like i said all the lights did) and not the "hiccup" when i turned it off.
NikK is offline
post #12 of 27 (permalink) Old 08-11-2018, 06:06 PM
Rusty Boltz's Avatar
Quoted: 160 Post(s)
I vote for battery. It's possible for a new one to go bad quickly (happened to me on a different car).
07 Sky
2.4L NA
5 speed
Limited slip differential
Chrome wheels
Premium trim package
Monsoon audio
AM/FM/XM/CD changer
Rusty Boltz is offline
post #13 of 27 (permalink) Old 08-11-2018, 07:51 PM
mbeardsley's Avatar
Quoted: 160 Post(s)
Actually, there were more automatic Redlines than manuals (and also more automatic "base" cars than manuals).
For 2008, there were 4911 Auto redlines and 3252 manuals.
For 2008, there were 3454 Auto base and 1277 manuals.
For 2009, there were 1429 Auto redlines, and 838 manuals.
For 2009, there were 1478 Auto base, and 433 manuals.
I don't have full data for 2007, but am pretty sure that the split was similar.
2008 Red/Red/Redline
Ordered 06/08/07
Built 07/20/07
Delivered 08/07/07
Destroyed 03/02/17
Replaced 03/19/17
mbeardsley is offline
post #14 of 27 (permalink) Old 08-12-2018, 06:09 AM Thread Starter
Quoted: 63 Post(s)
Ok but how could the battery make the car behave that way when i turned it off? It was the same like when you turn it on and there's a gear in already (it makes a sudden move and stops).
Also if the battery was faulty wouldn't the lights and instruments stay dead?
Anyways if it's the battery no worries, i was afraid it was something else far more serious.
NikK is offline
post #15 of 27 (permalink) Old 08-12-2018, 10:11 AM
Junior Member
Quoted: 528 Post(s)
I would throw up a theory here... a poor ground strap contact. You started the engine and the starter moved a bit, caused the ground point to fail briefly, which effectively turned the car off. Needles moved as they would when turning car on/off.
If it starts happening again, go round checking all the engine/bay ground point contacts.
The above is just a theory - could also be the battery
TomatoSoup is offline
