RPM Stage 3 Order, What else needed? - Saturn Sky Forums: Saturn Sky Forum
 2Likes
  • 2 Post By KVandenh1
post #1 of 12 (permalink) Old 03-08-2019, 08:00 AM Thread Starter
KVandenh1's Avatar
Quoted: 5 Post(s)
I am about to order RPMs stage 3 kit for my 09 manual redline and wanted to ask if I am missing anything or should order anything else with it. Below is what I am planning on ordering.
  • SATURN SKY REDLINE STAGE 3 PERFORMANCE PACK
  • RPM 2.0T Stage 3 ECU Tune
  • RPM 2.0T Upgraded Charge Pipes
  • RPM 2.0T Hi-Flow catted Downpipe
  • RPM-K04 Upgraded Turbocharger
  • TURBO TO DOWNPIPE COPPER GASKET
  • GM 3BAR LNF SENSOR UPGRADE
  • ECOTEC SPECIFIC DOWN STREAM O2 EXTENDER
I don't currently have any performance upgrades. I don't plan on getting a CAI because everything I read is it is a visual upgrade and doesn't impact performance.
I am in MI and I drive the car every dry day from May-Oct.
Lastly if there are any tips or tricks to installing this kit or any tools that make install that much easier I want to hear about it!
2009 Sky Redline Black/Cashmere
RPM Stage3, Highflow cat, RPM Intercooler, DDM Braces, WindRestrictor, Short Shifter, Apline Halo9
I am a GM Employee within GCCX (OnStar) and my postings are my own personal opinions.
KVandenh1 is offline
post #2 of 12 (permalink) Old 03-08-2019, 09:48 AM
Quoted: 1608 Post(s)
I can't think of anything off the top of my head (which means it will pop in later...LOL)
Special tools? No, but look up Solo performance's video on swapping out the cat. Our cat is a special kind of puzzle to get in and out. The video makes it very easy.
post #3 of 12 (permalink) Old 03-08-2019, 12:47 PM
Quoted: 8 Post(s)
I did the RPM Stage 3 to my car this winter. Didn't need to disconnect the motor mounts and jack up the motor to get the stock cat out. Just be patient and twist till it comes out. I opted for the catless, but I'm really questioning that decision, I'm going to make a final decision after I am finally able to drive it around and smell the difference. I've been starting the car in my garage and it does smell like raw exhaust.
Alpine ILX-107 with Rearview Camera
Upgraded RPM Turbo
Cat Delete
Dabman is offline
post #4 of 12 (permalink) Old 03-09-2019, 04:15 PM
Quoted: 4 Post(s)
-Upgrade all clamps (charge pipes, throttle body) with t-clamps
-Replace the turbo-exhaust manifold gasket, oil return gasket, all the banjos gaskets
-Make sure all nuts from the exhaust manifold ar tight, if possible replace all studs and nuts
-New coolant
-optional: replace the thermostat and water pump, it would take one more hour of work
~ssky~
Ssky is offline
post #5 of 12 (permalink) Old 03-11-2019, 08:01 AM Thread Starter
KVandenh1's Avatar
Quoted: 5 Post(s)
Added T-clamps, gaskets, coolant, and Intercooler to my list! My car comes out of storage in a few weeks so it is getting close to placing this order!
post #6 of 12 (permalink) Old 03-11-2019, 06:39 PM
Quoted: 4 Post(s)
Also lift the engine as much as possible from the passenger's side it would be so much easier, it only took 3:30 hrs to remove the turbo
~ssky~
Ssky is offline
post #7 of 12 (permalink) Old 03-16-2019, 04:13 PM Thread Starter
KVandenh1's Avatar
Quoted: 5 Post(s)
Everything I know of or have been told to get has been ordered! I debated water pump or not since the car only has about 35k on it but since everything is already going to be apart and it's only $60 I ordered it. Car comes out of storage next weekend! Then will go into my garage until this project is completed!
post #8 of 12 (permalink) Old 03-18-2019, 04:11 PM
Quoted: 5 Post(s)
I'm doing the Stage 3 kit right now.
As others have said, replace all rubber/silicone hose connectors with new ones and stainless T-Clamps. Upgrade your intercooler... it's under $600 and maybe 2 hours of labor.
slsmag is offline
post #9 of 12 (permalink) Old 03-27-2019, 08:31 AM Thread Starter
KVandenh1's Avatar
Quoted: 5 Post(s)
Everything is ordered and either delivered or has been shipped!! Here is everything I ended up ordering
  • RPM Intercooler
  • Upgraded Intercooler silicones
  • Upgraded T-clamps
  • Water pump, thermostat, temp sensor, bleeder valve
  • K&N Performance filter
  • G2 Red Caliper Paint
  • Lots of random little parts, gaskets, etc
I am super excited to start this project now that I have gotten the car out of storage!
post #10 of 12 (permalink) Old 04-01-2019, 04:40 PM Thread Starter
KVandenh1's Avatar
Quoted: 5 Post(s)
Thought my project was going to start today since I had packages being delivered. Only got half my order from GM parts direct and didn't get the turbo from RPM. More waiting..
post #11 of 12 (permalink) Old 04-07-2019, 04:54 PM Thread Starter
KVandenh1's Avatar
Quoted: 5 Post(s)
Everything is installed and maiden voyage complete! Now to get the tune!
Robotech and CoopSky like this.
post #12 of 12 (permalink) Old 04-20-2019, 02:31 PM
Quoted: 5 Post(s)
If you haven't already started pulling things apart, you might want to go to a local tuning/performance shop and get a baseline dyno done so that you can compare your before and after numbers.
slsmag is offline
