Stripe decal removal - Saturn Sky Forums: Saturn Sky Forum
post #1 of 6 (permalink) Old 11-20-2019, 12:04 PM Thread Starter
FJOH's Avatar
Quoted: 2 Post(s)
I recently bought a 09 ruby redline SE.
Its stripes on hood (the one on trunk looks just fine) is showing some cracks and would like to remove it.
Whats the best way to do it?
If any of you has actually removed the factory stripe, please chime in!
Thanks!
FJOH is offline
post #2 of 6 (permalink) Old 11-20-2019, 01:05 PM
A heat gun on low or a hair dryer on high will usually make it easier to peel off vinyl stripes.
Be a ware that the paint will probably be darker under the stripe due to fading of the rest of the car, so you will see a "ghost stripe".
JohnWR is offline
post #3 of 6 (permalink) Old 11-20-2019, 03:29 PM
Junior Member
Quoted: 528 Post(s)
Originally Posted by JohnWR View Post
Be aware that the paint will probably be darker under the stripe due to fading of the rest of the car, so you will see a "ghost stripe".
^^ Good point. If the original vinyl stripes are cracked, that indicates the car has been subject to a lot of sun (and hence UV) so the uncovered paint will likely had faded a bit.
TomatoSoup is offline
post #4 of 6 (permalink) Old 11-20-2019, 03:48 PM Thread Starter
FJOH's Avatar
Quoted: 2 Post(s)
Since the stripe on the trunk still looks good, Im considering just to redo the hood with decal from auto trim design which seems to be exact fit. Their charcoal gray metallic seems like the same color as the factory stripe.
https://www.autotrimdesign.net/Rally...Saturn_SKY.asp
Does anyone know if I can still get the factory stripe? If so from who?
FJOH is offline
post #5 of 6 (permalink) Old 11-20-2019, 04:29 PM
DaveOC's Avatar
Quoted: 9 Post(s)
https://www.wholesalegmpartsonline.c...rimLevel=25729
Both parts of the front stripe are shown as "no longer available" from GM.
Dave -
2006 Solstice NA #000741
DaveOC is offline
post #6 of 6 (permalink) Old 11-22-2019, 11:38 PM
skersfan's Avatar
Quoted: 859 Post(s)
google local graphic artist. One that specializes in vehicle wraps. They can make one any color you want. And should not be that expensive. I think you will have to reapply a new one though or as stated above the paint will be different
skersfan is offline
