Wastegate Actuator Help - Saturn Sky Forums: Saturn Sky Forum
post #1 of 2 (permalink) Old 07-01-2019, 10:23 AM Thread Starter
Quoted: 7 Post(s)
Hey Forum,
I am having one small issue that is becoming very annoying.
My wastegate actuator rod is coming off of my wastegate.
I've had it happen twice and both times I've lost both screws.
Has anyone had this happen to them and what has been your solution?
Thanks in advance!
paakaash is offline
post #2 of 2 (permalink) Old 07-01-2019, 02:20 PM
Quoted: 1707 Post(s)
I would set it up as directed then get another nut that is the same size as the ones that go on that rod and thread that in behind that back nut on the rod and use it like a locking nut. A little thread lock may work on that too but I have had pretty good luck with mine so long as you have it set correctly.
