White smoke at idle with no power loss - Saturn Sky Forums: Saturn Sky Forum
post #1 of 11 (permalink) Old 11-11-2018, 11:34 AM Thread Starter
Gabes Redline's Avatar
Quoted: 12 Post(s)
So as a result of sporadic white exhaust smoke at idle with no power loss, by process of elimination, im looking to first replacing or rebuilding the turbo, hoping that the white smoke is just a matter of worn out seals. Any suggestions on either replacing or rebuilding options? Been out of the Kappa game a while. Don’t want anything too crazy or aggressive. I’m more concerned with reliability and driveability.
2008 Redline, 5-Speed, Silver/Pearl, Red Leather
DDMWorks Brace Bundle/Kappa Shifter/Charge Pipes
Pedders XA Coilovers
Solo Performance Hi-Flow Cat
RPI GT Exhaust/RPI CAI MOD
Hahn Racecraft Intercooler
Gabes Redline is offline
post #2 of 11 (permalink) Old 11-11-2018, 12:40 PM
Gallifreyan's Avatar
Quoted: 32 Post(s)
That white smoke means your car has chosen a new pope, I think.
(I don't have any useful info for you, but hopefully a smile will help.)
Gallifreyan is offline
post #3 of 11 (permalink) Old 11-11-2018, 02:13 PM Thread Starter
Quoted: 12 Post(s)
Lol, I’m just hoping it’s not a new engine!!
post #4 of 11 (permalink) Old 11-11-2018, 04:05 PM
Quoted: 1621 Post(s)
Check oil and coolant levels to see if
1. They are lower than usual. Check regularly.
2. Check for water in the oil or oil in the water.
These will help narrow down what you're seeing. It will also eliminate some more sinister issues.
Next, do a compression check on each cylinder. If a cylinder is low on pressure, you may have some bad rings which are letting oil get by.
IF compression is good and oil is getting lower, chances are it's your turbo. Currently I'd talk to Martin Scott at RPM about getting a stock turbo if that's the route you want to go. If you want a bit more power you can go with his Big Wheel turbo but then you'll need a tune also.
I think only ZZP and RPM currently offer the stock turbo rebuilt but PAW and DDM might too...
post #5 of 11 (permalink) Old 11-12-2018, 09:37 AM
Quoted: 12 Post(s)
A leak down test is also a good idea. Then you can hear if its coming thru exhaust or intake (valves) or the dreaded, thru the oil fill (rings).
Blue Skies ahead is offline
post #6 of 11 (permalink) Old 11-13-2018, 09:07 AM Thread Starter
Quoted: 12 Post(s)
Thanks for the direction guys.
post #7 of 11 (permalink) Old 11-13-2018, 10:06 AM
LAC Sky's Avatar
Quoted: 129 Post(s)
Turbo seals, or bad rings, or the head gasket would be my guess. Compression check should confirm or deny any questions to the white smoke issues.
Loss of oil? Milky or mix of water/oil ? Any signs on the turbo itself? Loss of power?
Turbo first, then maybe the head gasket... with the rings last. IF an engine tear down happens you could upgrade the internals at this point if there is money in your budget?
LAC Sky is offline
post #8 of 11 (permalink) Old 11-15-2018, 08:44 PM
Quoted: 25 Post(s)
When i had white smoke it was the injectors.
NikK is offline
post #9 of 11 (permalink) Old 05-28-2019, 10:45 AM
I had a similar issue with loss of coolant as well. Found it is the turbo seals are bad and it needs rebuilt. Anyone on here have recommendations for a relatively inexpensive rebuilder? Im in the midwest area and would prefer to keep it as local as possible. Thanks in advance!
Tekster96 is offline
post #10 of 11 (permalink) Old 05-29-2019, 09:05 PM
Quoted: 100 Post(s)
Is it steam or smoke? My car always has a bit of "steam" on cooler mornings and days. There's a big difference. Steam disappates rather quickly, where smoke tends to linger.....If it's gone in a half second, it's steam and probably nothing to worry about.
The_Ghost is offline
post #11 of 11 (permalink) Old 05-30-2019, 01:54 AM
Quoted: 4 Post(s)
Check for turbo shaft play, if ok check engine compression if low before rebuilding the engine try RESTORE engine treatment it does wonders according to many people on YouTube
~ssky~
Ssky is offline
