2.4l turbo PCV mod for a oil catch can that actually works. - Saturn Sky Forums: Saturn Sky Forum
post #1 of 19 (permalink) Old 04-06-2011, 03:12 PM Thread Starter
Would anyone be interested in me doing a write up on removing stock PCV system and implementing one that works with a catch can?
slvrsky07 is offline
post #2 of 19 (permalink) Old 04-06-2011, 03:19 PM
Quoted: 975 Post(s)
NO....
marlboromike is online now
post #3 of 19 (permalink) Old 04-06-2011, 03:25 PM Thread Starter
ok suite yourself. Gather oil in your intake manifold, Maybe it will help lubricate your valve seats... LOL
post #4 of 19 (permalink) Old 04-08-2011, 11:09 AM
08BlueSky's Avatar
Quoted: 17 Post(s)
Ah come-on, donít let the MM ogre thwart you
please share...........
And photos are always a plus
08BlueSky is offline
post #5 of 19 (permalink) Old 04-10-2011, 01:34 AM Thread Starter
The 2.4l pcv system is flawed. it uses a port in the intake manifold and a passage in the head to pull the crankcase vapors out. The biggest reason this is not a good system is due to the fact there isnt a pcv valave, only a vacuum plate as seen in these first couple pictures. When boosting or hard cornering oil can make its way down port in the head and building up in the intake manifold. Here is how I fixed this issue.
You will have to first remove your intake manifold. You will see something like the pictures above.
post #6 of 19 (permalink) Old 04-10-2011, 01:47 AM Thread Starter
next take the small metal "pcv" plate and attach a screw to block the hole. I put some sealer around it to make sure oil will not make its way back to the intake. Here is what mine looked like. Make sure you use a screw with a flat head to keep it as close to the pcv plate as possible. Also make sure you install the gasket and plate back into the intake manifold with the screw head facing the cylinder head. You may want to clean out your intake manifold if there is oil in it before re installing. Next take your catch can and add 2 Pcv valves in it. One should allow air or vacuum to pass and the other will only allow boost to pass. I modified my ebay catch can and installed a breather filter on the "boost" pcv valve ( or PCV 2 in the picture). Pcv 1 will allow the vac to pull crankcase vapor out and into the catch can, it will shut once the car produces boost. Pcv2 will open up allowing venting for crankcase pressure after the catch can. Hope this drawing helps explain. The PCV system will now pull vapors out of the vent tube on the valve cover and place oil residue in the catch can rather than in the intake manifold. Also the valve cover is baffled before the vent tube to prevent oil splashing. Here is a picture of mine. This works too, it stopped oil pooling in the intake and burning oil while boosting. Let me know if you have any questions. Thanks
post #7 of 19 (permalink) Old 10-12-2013, 12:55 AM
Helios's Avatar
SLVRSKY07, I'm getting oil throughout my charge tubes, intercooler, and intake manifold. Here's a couple shots of the setup. I understand the part that I need to block off the pressure plate in the intake manifold and install a PCV valve (PCV valve 2) on the OCC. What I don't understand with my current setup is the hose leaving my OCC to the intake tube, aft of my air filter. Am I to remove that hose and relocate it to the intake manifold? If so, I'll need to block off the nipple on the charge tube the hose currently attaches to. Then, I'll have to drill a hole in the intake manifold, attach a fitting to it, then reattach the hose I disconnected and add an in-line PCV valve (PCV valve 1). Am I correct in this?
ID:	47777   Click image for larger version
"Gwyneth"
V8 swap in progress
RPi GT/SOLO Exhaust
Helios is offline
post #8 of 19 (permalink) Old 10-12-2013, 08:01 AM Thread Starter
You will need to relocate it after the TB, This is so you have full VAC. This may correct your issues.
post #9 of 19 (permalink) Old 10-12-2013, 03:03 PM
Yes,yes and yes.
2nd American Legends 2013
lllfly is offline
post #10 of 19 (permalink) Old 10-17-2013, 11:34 AM Thread Starter
I agree! Make it the same as I posted and it will work.
Originally Posted by lllfly View Post
Yes,yes and yes.
post #11 of 19 (permalink) Old 04-01-2014, 02:57 PM
Helios's Avatar
I did this mod a while back and at first it seemed to work great. I made a few changes to the setup because I am using DDM's OCC. I also added a 90* plastic barb fitting to the intake manifold to run the return line to. I'll have to take pictures of the setup and how it is currently configured. However, I am going to have to change it. The system started blowing the oil dipstick and a considerable amount of oil out probably because there wasn't enough pressure relief. I did notice that I think I have the OCC too far from the vacuum source which may be part of my problem. The OCC is currently mounted near the battery on the passenger side. I will end up relocating it to the driver's side and with subsequent shorter hose lengths.
"Gwyneth"
V8 swap in progress
RPi GT/SOLO Exhaust
Helios is offline
post #12 of 19 (permalink) Old 04-04-2014, 09:59 AM Thread Starter
You need a 1/2" line or larger for relief. I ran 1/2" for the relief side and 5/16" for the vac side.
post #13 of 19 (permalink) Old 04-04-2014, 01:15 PM
Razz's Avatar
Why do this when all you have to do is put a rubber plug on the intake tube.
Then put an air filter on the hose to the intake.
Boom! no catch can and crank case can vent through your filter.
a oh... Smog time. Remove air filter and put tube back on intake.
Think simple.
Razz is offline
post #14 of 19 (permalink) Old 04-04-2014, 01:39 PM Thread Starter
Sounds like a great way not to suck out those engine vapors while off boost driving and have oil vapors not go into a catch can. What ever works for you man.
post #15 of 19 (permalink) Old 04-04-2014, 01:41 PM Thread Starter
Also that doesn't fix how oil gets sucked into your intake from high boost or heavy cornering.
