Finally The Skpel is running - Saturn Sky Forums: Saturn Sky Forum
 11Likes
post #1 of 72 (permalink) Old 10-06-2018, 08:08 PM Thread Starter
skersfan's Avatar
Quoted: 772 Post(s)
As most know I started a project in middle January to upgrade the performance of my Sky. I ordered a turbo upgrade and it took months and months months for it to finnaly arrive. Then after several/many calls to the vendor we got information on it and instructions on what to do to make it run. Near the middle of June we finally got the car to run, but Robotech was afraid of the car blowing up with too much knock. It was terrible. At the National I met Dave of Performance Auto Works, who was actually able to tune the car so it would run, but continued to throw codes, but was at least able to drive it at the National one day. Brought it home and put it away. Too much drama for too many months. Was tired of it.
Towards the end of August got it back out and worked with Dave and Robotech to get the car to run properly. Several small changes were made, but not really any improvement in what I would call regular performance. Car was running too rich in one area, too lean in another. Car popped and backfired continously, idle would change from 2000 to 800 to 1400. Engine light would come on after it had been driven and hour or so. It was terrible. This went on for a few weeks with different tunes being supplied by Dave. I am sure it was frustrating for him as well as Robo and myself.
But Thursday we replaced one of the MAP sensors and the car started to run much better. Still throwing a code, P1106 I think it is. But the car was driveable, seemed to have a vibration and was extremely loud. Idle was close to 1000. It was worlds better, but not right.
This morning Robo drove up to my place and we down loaded another tune from Dave at PAW. The car instantly started running smoother, no backfires, and very little if any vibration. It was truly what I had expected when I started this. There is still a code, but Robo feels that Dave can fix that.
I want to thank Dave and Robo for all their efforts on this. I am not sure it is what I want from my car, and there is a very good chance I will return it to stock with a Trifecta tune. I will make that decision after the next tune, and then driving it on 243 to see how it performs in the twisties. It does have more lag than the stock turbo, not a lot, but not sure how that will translate under pressure.
It has been a long drawn out process. If you are considering doing some thing similar, I welcome you to PM me for complete details and things I have learned thru this process.
Again Thanks to Performance Auto Werks, and of course Robotech.
mstrjon32, 44thSKY, Emmett and 1 others like this.
skersfan is offline
post #2 of 72 (permalink) Old 10-07-2018, 02:54 PM
ChopTop's Avatar
Quoted: 143 Post(s)
So all of this was due to wanting to go with with the big wheel turbo it that a couple of vendor's sell? I have thought about it, but that's as far as I've gone. Kudos to Dave & Robo for helping you.
ChopTop is offline
post #3 of 72 (permalink) Old 10-10-2018, 08:33 PM
Quoted: 1641 Post(s)
This is not a big wheel K04. This is a different setup all together.
The error code is P0106 which is the upper MAP sensor. I believe this is the sensor the ECM uses to control boost level. I believe Skersfan had a problem with the car again this morning but I have a feeling this upper O2 needs to be replaced. He went to the new 3 bar sensors but we had some problems with the install (harness adapter wired wrong and Dave at PAW took care of that for us then we had some sealing issues...) but thought we had it resolved. The P0106 error though had me wondering. I have a feeling we have a bad sensor.
post #4 of 72 (permalink) Old 10-11-2018, 11:32 AM Thread Starter
skersfan's Avatar
Quoted: 772 Post(s)
I truly thought I was buying the big wheel set up. But turned out I wasn't. My mistake in ordering the wrong thing, but not my fault on what has happened since that date. I would never recommend this to any one. Over my ability, my mechanics ability, and no real way of telling exactly what is wrong. I have a hard time believing the third set of sensors are bad. Feel the wrong plug and play wiring may have caused the orginal problem, but it should be corrected by now. Car runs great for about 100 miles then goes in the crapper. Idle all over the place, popping and backfiring. It develops a droning sound that is absolutely unbearable.
This was not purchased from Performance Auto Werks, but Dave has bent over backwards trying to make it work. When it is running, it develops a little more performance than the base trifecta tune I think, but certainly not worth the amount of money I spent on it or the frustration it has caused. I am more worried about it blowing my car up than anything else. I am sure it has burnt the exhaust system up on the car, most likely the cat will start throwing codes soon. We have one more shot at it this week. If it doesn't run right, it is all coming off and going to the junk pile. I would never sell it to anyone as I would not want to stick anyone with this mess. I have been messing with it for 9 months, and nothing seems to fix it. I had a perfect running car, never any codes, and then I did this to it. I am hoping we get it figured out. But I highly doubt it.
skersfan is offline
post #5 of 72 (permalink) Old 10-11-2018, 12:49 PM
wspohn's Avatar
Quoted: 312 Post(s)
Remind me which turbo you ended up with.
1957 Jamaican MGA
1958 MGA Twincam
1962 MGA Coupe
1971 Jensen Interceptor
2007 BMW Z4M coupe
departed
1965 Jensen CV8
1969 MGC roadster,
1969 Lamborghini Islero S
1988 Pontiac Fiero GT
Bill in BC
wspohn is offline
post #6 of 72 (permalink) Old 10-11-2018, 03:04 PM
Rusty Boltz's Avatar
Quoted: 147 Post(s)
Sorry to see that, Bob. It's one of the reasons mine is not modified.
07 Sky
2.4L NA
5 speed
Limited slip differential
Chrome wheels
Premium trim package
Monsoon audio
AM/FM/XM/CD changer
Rusty Boltz is offline
post #7 of 72 (permalink) Old 10-11-2018, 07:46 PM
Elff's Avatar
Quoted: 255 Post(s)
How about some information.
We have a freaking book of vagueness.
LUSIFER is Sold!
say hello to
RYUK
Elff is offline
post #8 of 72 (permalink) Old 10-11-2018, 09:14 PM Thread Starter
skersfan's Avatar
Quoted: 772 Post(s)
Life is a learning adventure. Unfortunately I learned this 50 years ago, blowing apart 427's and Hemi's. Should have known better.
Today we think we have figured out some of the problem. Vaccuum in the engine is too high, possibly being caused by the oil catch can, I think is what Curtis said. I drove it this evening up 243 and it ran fine. Will drive it tomorrow and see if the magical code throwing bug is still with me. When it was running right tonight, it was impressive, but have seen this before, so want to wait a couple of days before celebrating anything. Did notice that the blow off valve sounded completely different tonight. Wasn't constantly wobblingy is the best I can describe it.
In honesty Elf I really don't know what I have. I don't think anyone does. It certainly does not look stock in any aspect.
Bill, not sure, but I think it is a 2871? I can send some pictures, but there wasn't a single thing at the National that looked like it.
skersfan is offline
post #9 of 72 (permalink) Old 10-11-2018, 09:21 PM Thread Starter
skersfan's Avatar
Quoted: 772 Post(s)
Thanks Bill, I promise I will learn this time. I don't have the ability to work on this newer age stuff. Never really wanted to. And still don't. Just want to turn the key and drive the car, and not have a check engine light come on. I know some of you guys live for the modding and messing with the performance of these things. Just knowing that I had a great car, that was near perfect in every aspect, and did this to it makes me sick. I know I have done damage to it, and that was not my intention. No your limits has been driven home with this escapade for certain.
skersfan is offline
post #10 of 72 (permalink) Old 10-12-2018, 09:15 AM
Elff's Avatar
Quoted: 255 Post(s)
Can you post some pictures of your engine bay?
One the main differences between a BorgWarner turbo and a Garret Turbo is how they vent.
BW uses an internal bypass valve whereas Garret turbos require an external blow of valve.
Depending on what you have will help identify at least the brand of turbo
I hear ya loud and clear on just enjoying the car.
I have only done 2 mods on my Alfa. Wheel spacers and tinted turn signals.
The engine trans tuning suspension brakes and tires are perfect. No need for me to fawk it up
LUSIFER is Sold!
say hello to
RYUK
Elff is offline
post #11 of 72 (permalink) Old 10-12-2018, 06:18 PM
Don't think it's a Garret but he's got a Synaps BOV on it. It was the Turbo DDM was selling for a while that was an upgrade from the K04 I believe.
One main issue the car has is a P0106 error code and assorted airflow codes. I don't know what skersfan changed in the vacuum routing but he hasn't mentioned any issues since that. I keep coming back to a sensor issue since all the symptoms and the codes would lead me to believe something in the airflow would lead me to believe either there is a vac leak or the ECM is getting values from the sensors which are causing the problems with the way it's running.
We did a scan and everything looked great except about 3* of KR at the top of third which would decay off like it should. Then the car goes possessed which tells me something is changing between when I scan it and when it goes bonkers.
post #12 of 72 (permalink) Old 10-12-2018, 07:19 PM Thread Starter
skersfan's Avatar
Quoted: 772 Post(s)
Yea it gets driven 60 miles and chucks up a code.
skersfan is offline
post #13 of 72 (permalink) Old 10-12-2018, 07:21 PM
Elff's Avatar
Quoted: 255 Post(s)
That's the Garret Hybrid 2871 Turbo.
It's actually a pretty awesome turbo for our cars. It's the stock exhaust side of the stock turbo, which is machined so that it can be coupled with the compressor side of a Garrett 2871 turbo.
It maintains the dual scroll and stock manifold, but adds some serious top end potential and can push some serious air.
I was pushing 44lb/min of air through that bad boy when I was running it with E47. I could also do a sub 4 second 60-100 pull.
It's equivalent to an EFR 6258 and is a nice combination of added power without introducing a lot of additional lag.
If you can get it ironed out, I will say, it was my favorite setup on my sky.
I attached a screen shot of HP Tuners during one of my hellish pulls. This was a split second before I shifted from 3rd to 4th.
LUSIFER is Sold!
say hello to
RYUK
Elff is offline
post #14 of 72 (permalink) Old 10-12-2018, 07:33 PM
Elff's Avatar
Quoted: 255 Post(s)
I did have issues with the DDM Catch Can and finally scraped it. It just did not do anything and I had a ton of oil in my intercooler pipes. I finally went with a Powell PCV Oil Separator which is paper based like an oil filter. They are the guys that raced the Cobalt. I found out about them from the Cobalt forum. Once I installed it, I finally had dry IC Pipes.
I'd say, eliminate the catch can for now to take 1 thing out of the equation. You also might want to do a boost test to see if there are any leaks
ChopTop likes this.
LUSIFER is Sold!
say hello to
RYUK
Elff is offline
post #15 of 72 (permalink) Old 10-12-2018, 10:14 PM Thread Starter
skersfan's Avatar
Quoted: 772 Post(s)
Unfortunately I did not get by the shop today, so the car did not get driven the required 60-80 miles. We did clear all the codes again last night, so will check to see if there are pending codes before we drive it or install the new tune. I was impressed with it yesterday on 243, but if it is going to run like that, it will take time to learn to drive it again. It does make a dramatic difference. But driving it several times it runs good, then runs bad, or prior to the codes going you can't really know what is going to happen. Scream or fall on its face kinda deal. I hope we have found the problem. Thanks Elf for your comments and ideas/information.
I need to have it running this weekend, as we have our Palm Springs run next weekend. I don't want to deal with problems for 250 miles.
skersfan is offline
