Help! Stuck trying to download Trifecta tune! - Page 3 - Saturn Sky Forums: Saturn Sky Forum
 5Likes
post #31 of 47 (permalink) Old 11-03-2018, 08:52 PM
bigballsofpaint's Avatar
Quoted: 11 Post(s)
Make sure you put it in competition mode
2008 Sky Redline - Charge Pipes, Intake, Trifecta, DDM Short shifter, Solo Exhaust, Solo HF Downpipe, DDM braces, Slotted Rotors w/ Hawk pads and PAW SS lines.
2016 Sierra 1500 - Daily/ Tow vehicle
2011 Ninja 1000
bigballsofpaint is offline
post #32 of 47 (permalink) Old 11-03-2018, 09:42 PM Thread Starter
Need4Speed2's Avatar
Quoted: 38 Post(s)
Let us know how it goes.
I'm still not sure the tune is loaded........
I followed everything to a "T", but my max psi was briefly 17psi, usually its at 14-15 psi.
When am I supposed to see 22-23 psi, at WOT in 4th or 5th gear? Or do I have to be in the 5300 RPM range?
I dont know these cars so I really cannot feel any significant improvement, and nothing to compare it with.
Could I have a boost leak (loose clamp, etc) but that means it would have been below 14psi when it was stock, no?
Need4Speed2
SF Bay Area, CA
2008 Redline, 49k miles
Need4Speed2 is offline
post #33 of 47 (permalink) Old 11-03-2018, 10:19 PM
davhamm's Avatar
Quoted: 445 Post(s)
You said you bought it with the ability to turn it off with cruise control. Find a long straight deserted street. Stop SMASH THE GAS (FIRST HOLD WHEEL TIGHT) then stop. turn on cruise control SMASH THE GAS. Where your 0 - 30 or 40 times different? did you feel a difference. With my **** tires they will squeek a bit on the 1 - 2 shift with the tune on. I still don't believe it but have done it a few times.
I am a GM Engineer.
2009 HYDRO REDLINE AUTO
davhamm is offline
post #34 of 47 (permalink) Old 11-04-2018, 08:25 AM
Quoted: 11 Post(s)
I told them i wanted the tune on all the time, yet..........i have to put it in competition mode. Try that and cruise control like you asked. (to put the car in competition mode hit the traction control button twice within 5 seconds)
2011 Ninja 1000
post #35 of 47 (permalink) Old 11-04-2018, 09:50 AM
davhamm's Avatar
Quoted: 445 Post(s)
You should contact Trifecta if you asked for an always on tune and they gave you a competition switch controlled tune. That is one of the options they offer, but if they gave you the wrong one I am sure they will fix it.
I am a GM Engineer.
davhamm is offline
post #36 of 47 (permalink) Old 11-04-2018, 12:35 PM Thread Starter
Quoted: 38 Post(s)
Good point guys, they did forget to send the calibration file when I got the the email notice, maybe they did not put the on/off tune control in the c/control.
Need4Speed2
SF Bay Area, CA
post #37 of 47 (permalink) Old 11-04-2018, 03:34 PM
44thSKY's Avatar
Quoted: 392 Post(s)
Great discussion on the Trifecta tune and what to watch for from Trifecta. (probably doubtful that it needs two parallel threads to discuss the same thing) ....... just saying.
44thSKY is offline
post #38 of 47 (permalink) Old 11-04-2018, 06:51 PM Thread Starter
Quoted: 38 Post(s)
You called it!
They put the tune access in the Competition mode setting, not Cruise Control. I just hit 23 psi on the highway! Wooooooooo!!
Does that mean I lose Competition Mode when the tune is engaged, or, do I have BOTH Competition Mode AND the tune when CM is engaged?
Need4Speed2
SF Bay Area, CA
post #39 of 47 (permalink) Old 11-04-2018, 09:06 PM
DaveOC's Avatar
Quoted: 9 Post(s)
You called it!
You have both the tune and competition mode.
Have fun.
Dave -
2006 Solstice NA #000741
DaveOC is offline
post #40 of 47 (permalink) Old 11-05-2018, 06:27 AM Thread Starter
Quoted: 38 Post(s)
Thanks!!!!
Need4Speed2
SF Bay Area, CA
post #41 of 47 (permalink) Old 11-05-2018, 08:56 PM Thread Starter
Quoted: 38 Post(s)
Trifecta has gone ahead and posted all versions to my account for me to choose from. They will be visible to me once I reach the last page where you actually download the file (after agreeing to the terms etc).
They posted tune active all the time, CC active, and Comp mode active.
I have all 3 options, 3 separate downloads
Need4Speed2
SF Bay Area, CA
post #42 of 47 (permalink) Old 11-06-2018, 12:22 PM
jgassor's Avatar
Quoted: 63 Post(s)
That's great that they provided you all three methods! You can try out each and every one and find the configuration you like the most. Puts you in a better position than the rest of us who never requested the configuration each and every way. Now you are special
Jim
Techo Gray 2008 Sky RL with Trifecta and DDM bracing
jgassor is offline
post #43 of 47 (permalink) Old 11-06-2018, 12:38 PM
wspohn's Avatar
Quoted: 307 Post(s)
I had mine set so it is on when the cruise is on, but that was to conceal the fact that the car was tuned when I took it in to the dealer for warranty work.
Today I see no reason at all to have the tune switchable - just have it on all the time. When would you ever want to turn it off?
1957 Jamaican MGA
1958 MGA Twincam
1962 MGA Coupe
1971 Jensen Interceptor
2007 BMW Z4M coupe
departed
1965 Jensen CV8
1969 MGC roadster,
1969 Lamborghini Islero S
1988 Pontiac Fiero GT
Bill in BC
wspohn is offline
post #44 of 47 (permalink) Old 11-06-2018, 02:56 PM Thread Starter
Quoted: 38 Post(s)
He! He!
Need4Speed2
SF Bay Area, CA
post #45 of 47 (permalink) Old 11-06-2018, 03:07 PM Thread Starter
Quoted: 38 Post(s)
That's just it, I have an extended warranty.
Question-"set so it is on when the cruise is on", meaning the CC button is pressed and light is on....
Would the dealership not get wise to that eventually....?....
Need4Speed2
SF Bay Area, CA
