Intercooler battle! RPM vs WERKS - Saturn Sky Forums: Saturn Sky Forum
post #1 of 15 (permalink) Old 03-03-2019, 06:32 AM Thread Starter
Turner Thompson's Avatar
Quoted: 8 Post(s)
So im looking to replace my intercooler. I had the RPM performance intercooler in now but it's sprung a leak. I'm gonna have it welded but id rather go with a new one. Does anyone have the WERKS intercooler installed and can give me a review? Or anyone have any info on which intercooler would work better for my build? Here's my full car specs
Rpm motorsports upgraded K04 turbo
Rpm intercooler
Rpm charge pipes
Rpm cold air
RPM tune (coming)
RPi exhaust system
High flow Magnaflow CARB legal Cat.
Hankook Ventus S1 Noble 2 tires
I read that the werks is a bit smaller but rated at 675 hp whereas the RPM is rated at 600 hp.
Thanks for reading!
Links for both: http://www.performanceautowerks.com/...rcooler-p-1702
https://www.rpm-motorsports.com/stor...tercooler.html
2008 Saturn Sky Redline Carbon Flash SE
RPI Exhaust
RPI Intercooler
DDMWERKS Intercooler piping
MAGNAFLOW High Flow Catalytic converter
GM SPORT Turbo upgrade and tune
Stigan K04 Turbo
Turner Thompson is offline
post #2 of 15 (permalink) Old 03-03-2019, 08:10 AM
Quoted: 97 Post(s)
2 others you might look at:
DDMWorks used to have an IC good to 600hp...you might have to contact Dave as I couldn't find it in a quick check of their website.
The other is Hahn...although I know last summer someone was having a real issue getting an IC they ordered from him....
The_Ghost is offline
post #3 of 15 (permalink) Old 03-03-2019, 12:29 PM
wspohn's Avatar
Quoted: 308 Post(s)
I use the Werks IC. More than enough cooling for anything you can put out. No issues with installation. Been in there for ten years now. Same/similar turbo to yours.
1957 Jamaican MGA
1958 MGA Twincam
1962 MGA Coupe
1971 Jensen Interceptor
2007 BMW Z4M coupe
departed
1965 Jensen CV8
1969 MGC roadster,
1969 Lamborghini Islero S
1988 Pontiac Fiero GT
Bill in BC
wspohn is offline
post #4 of 15 (permalink) Old 03-03-2019, 01:59 PM Thread Starter
Quoted: 8 Post(s)
Thanks for the info! I've heard good things which is why I even considered them
RPI Exhaust
RPI Intercooler
Stigan K04 Turbo
post #5 of 15 (permalink) Old 03-03-2019, 02:00 PM Thread Starter
Quoted: 8 Post(s)
I love the look of the Hahn one but I hear it takes some cutting to get to fit and that makes me nervous
RPI Exhaust
RPI Intercooler
Stigan K04 Turbo
post #6 of 15 (permalink) Old 03-03-2019, 06:48 PM
Quoted: 1608 Post(s)
Both the WERKS and RPM intercoolers are good units and you really can't go wrong with either. Both will support the power your build currently has with some headroom if you decide to try and make more power. 600whp is more than most LNF/LE5 builds I know. My build I'm shooting for 450-500 and that's full built internals with a fairly good sized turbo.
I have the Hahn intercooler on mine. Last year Hahn was in the middle of trying to get his shop moved to Daytona Beach and hire some new employees. I know he has moved into the new shop but I don't know what his production times look like right now. I love the Hahn intercooler and the only part you do need to cut is the plastic ducting that sits behind the OEM Intercooler. It's some minor cutting (A Dremmel makes it easy...) and isn't too major.
post #7 of 15 (permalink) Old 03-03-2019, 06:49 PM
SaturnSkyRedline2015's Avatar
Quoted: 87 Post(s)
Are any of them 100% drop in, zero cutting/modifying? Other than stock of course.
SaturnSkyRedline2015 is offline
post #8 of 15 (permalink) Old 03-03-2019, 06:57 PM
DDM is I believe and maybe RPM...can't remember on that one.
post #9 of 15 (permalink) Old 03-04-2019, 05:44 PM
Quoted: 8 Post(s)
just installed the RPM on mine. Had to cut the plastic crowl and add spacers to lower under intercooler shield so it didn't fowl.
Alpine ILX-107 with Rearview Camera
Upgraded RPM Turbo
Cat Delete
Dabman is offline
post #10 of 15 (permalink) Old 03-05-2019, 03:57 PM
VinnieRL's Avatar
Quoted: 47 Post(s)
I've had my Werks IC installed for a few years now with no issues. I even bought it used to save a few hundred bucks. It was not completely drop in as it was supposed to be. I remember having issues with IC piping hitting the hood on teh driver's side that I had to mess with and I seem to remember fighting it on the bottom as well. I remember installing and removing it multiple times but with the same results each time. Either way, I'm happy with it in the end.
RKSport Hood
DDM I/C Pipes, OCC, Shifter Kit, Silicone Hoses, T-Bolts, trunk/hood lights
Werks I/C, Rad, Backbone & Swaybars
reBar
K&N CAI
MF Catback
Solo Race Pipe
3bar MAP w/ ZZP Tune
Windrestrictor & Lit Sills
Quaife Diff
VinnieRL is offline
post #11 of 15 (permalink) Old 03-06-2019, 03:09 AM
skersfan's Avatar
Quoted: 751 Post(s)
I have the DDM street intercooler and it was very close to drop in,.. The main problem wa s the rubber connectors being kind 0f a pain.
skersfan is offline
post #12 of 15 (permalink) Old 04-03-2019, 08:23 PM
Quoted: 2 Post(s)
Intercooler
I am looking at replacing the intercooler on my 08 redline (werks). Do I have to take off the bumper to swap this out ? if so , are there any complicated situations ?
Bilyum is offline
post #13 of 15 (permalink) Old 04-04-2019, 10:25 AM
Yes bumper has to come off as does the center lower ductwork...well, that doesn't have to come off but it makes it easier and I believe that ductwork has to be trimmed some for the Werks intercooler.
post #14 of 15 (permalink) Old 04-05-2019, 10:00 AM
Quoted: 2 Post(s)
Thanks . I have watched a few videos , does not look bad . I am also replacing the ic pipes , sensors and installing a cold air intake . Do you think removing the hood would be a good idea , or would it be more trouble than it is worth ?
Bilyum is offline
post #15 of 15 (permalink) Old 04-05-2019, 10:06 AM
No need to remove the hood. Yes it would make the job a bit easier, but the trouble to remove, reattach, and realign the hood would be a far bigger pain in the butt than leaving it in place when changing the pipes and IC. Honestly, the only way the hood interferes with what you are going to do comes when you're trying to disconnect the couplers that connect the pipes to the intercooler. It doesn't so much limit where you can put your tools as it does where you can put your head while using the tools. LOL
