LE5 GT2871R Turbo kit - Saturn Sky Forums: Saturn Sky Forum
Saturn SKY vehicles/parts For Sale/Wanted Place for MEMBERS to post want to buy or vehicles for sale. NO COMMERCIAL POSTING, no PROMOTION OF VEHICLES OR ITEMS YOU DO NOT PERSONALLY OWN.
 1Likes
  • 1 Post By idkfa
post #1 of 15 (permalink) Old 12-07-2016, 04:41 PM Thread Starter
idkfa's Avatar
Quoted: 2 Post(s)
This initially started life as BoostedSOL's watercooled setup that went to Yamatr3 before his V8 build. Most of my notes have been gleaned from his build threads which you can read here:
Custom Turbo Pics! - Pontiac Solstice Forum
Turbo Solstice Dyno plots - Pontiac Solstice Forum
Custom Solstice Turbo Pictures! - Pontiac Solstice Forum
His pictures are missing but I salvaged a number of them from various places to try and build from: BoostedSOL's turbo - Album on Imgur (includes everything I initially received as well)
This was my first ever turbo project and decided to make it was simple as possible for my daily driver so I picked up a cheapo GXP intercooler and converted it. The album in my signature somewhat detailed the process: '06 Solstice Turbo - Album on Imgur
I ended up replacing the turbo so it's ~30k miles with no shaft play. Please let me know and I can take any specific pictures for you. In addition to my close-up build pics, here's a group photo of everything today:
album with everything
Main Details
Everything else:
I'm asking $1500 which includes everything I have or PM me and we can talk about what might work for you.
Also have a sky RPi GT for $600
idkfa is offline
post #2 of 15 (permalink) Old 12-07-2016, 04:41 PM Thread Starter
idkfa's Avatar
Quoted: 2 Post(s)
My notes that I pulled from Boosted's threads and some conversations with him:
System specs:
Garrett Gt2871r turbo T25
Divorced wastegate downpipe
.020 over race engine featuring forged rods, forged 8.8/1 compression pistons
Modified GM laminova intercooler and front mount heat exchanger
Cast turbo header Saab 9-3 2003+ TD04
LS2edit tuned with auxiliary rail of fuel injectors for boost fueling with 2.5 bar speed density programming
Turbosmart Eboost boost controller
AEM wideband 02 sensor
Turbo:
The Gt2871r with a 53/71 compressor wheel(450hp)and 86a/r turbine.
on this exact turbo(compressor side) you can switch to a T3 flange and/or larger turbine wheel(GT 30) and/or also run the larger compressor cover with a 2.75 or 4 inch inlet and up the power potential to high 400's. for my goals and knowing the boost I want to run to meet this goal as well as packaging, "THIS" internally gated 2871r was the best choice, where i can max out the turbine section with a very broad and flat torque powerband(you need this with the whacky gearing in the Solstice)If I find Im pushing the turbo and need a little more I can simply switch to the larger compressor cover(effectively making it a hybrid 3071WGr turbo and squeeze some more power out of it with very little if any fabrication changes. These 2871's are a very interesting turbo with lots of support from Garrett in respect to new combinations and changes.
Manifold:
I made an adaptor plate to allow the use of the factory Saab turbo header to mount a Garrett 2871 turbo. TDO4 to
By using a factory cast header I am gaining piece of mind that a fabricated piece won't crack. I did some extensive porting and port matching on the header and turbine to match everything up.
Intercooler:
-The intercooling system holds nearly 1.5 gallons of fluid with over 85% of it in the heatexchanger at all times!
-I modified a Cobalt SS intake manifold/intercooler to work on the solstice. I also utilized a second rail of fuel injectors for supplementary fuel injection under boost. Using the LS2 edit I will retain 100% factory driveability and have total control of the tuning. I also modified an intercooler to act as the air to water heat exchanger for the Laminova intercooler in the intake manifold.
-Did you do the dual pass mod on the intercooler cores? Also, are you using a LSJ circulation pump and heat exchanger? Oh, and how did you deal w/ the bypass air passage used on the M62? [for the bypass I welded in a fitting and used that for the brake booster line, the end plate i modified into dual pass, and i am using a jabsco pump for circulation with a front mount heat exchanger that holds over a gallon of fluid.]
-Modified to work on the solstice the factory cobalt SS intercooler/intake manifold features a 4 core laminova air to water intercooler. also the unit comes with a 2.5 bar map sensor to provide a load reference for the supplementary fuel injection.
tuning:
im using LS2 edit with an auxiliary injection system...basically i am using the factory ecm map under non boost conditions then I use the LSJ 2.5 bar map sensor for a load reference under boost.
as far as tuning for boost both tuning methods I used LS2-edit and the SMT-6 auxiliary fuel computer
idkfa is offline
post #3 of 15 (permalink) Old 12-13-2016, 08:30 PM Thread Starter
idkfa's Avatar
Quoted: 2 Post(s)
edit: RPi GT being sold separately.
idkfa is offline
post #4 of 15 (permalink) Old 01-11-2017, 03:39 PM Thread Starter
idkfa's Avatar
Quoted: 2 Post(s)
TTT
Might be splitting RPi GT out of the package soon due to interest.
stungjoe likes this.
idkfa is offline
post #5 of 15 (permalink) Old 01-12-2017, 01:56 PM
Trying to pm you but for some reason cannot
Johnny_gxp is offline
post #6 of 15 (permalink) Old 01-12-2017, 02:32 PM
Quoted: 1621 Post(s)
Johnny, it may be due to how new your user account is. You're a brand new user (welcome) and brand new users have limited abilities especially when it comes to PMs...If you have one PM in your in box you are at your current limit (1 message total is the limit...so you have to have 0 messages in order to send one then have to delete that one to receive a response). I think after 5 or 10 posts you are allowed more than one message in your in or sent box.
post #7 of 15 (permalink) Old 01-13-2017, 03:07 AM
Awesome, thanks Robo
post #8 of 15 (permalink) Old 01-25-2017, 09:57 PM Thread Starter
idkfa's Avatar
Quoted: 2 Post(s)
let's say $1000 shipped for the GT2871R .86A/R that has maybe 30k on it, the strong OEM Saab manifold and the downpipe that's ready to bolt onto any 2.4.
idkfa is offline
post #9 of 15 (permalink) Old 02-28-2017, 09:45 AM Thread Starter
idkfa's Avatar
Quoted: 2 Post(s)
idkfa is offline
post #10 of 15 (permalink) Old 05-12-2018, 05:52 PM
Quoted: 2 Post(s)
Curious, this still available?
solstice06174 is offline
post #11 of 15 (permalink) Old 05-25-2018, 02:54 PM Thread Starter
idkfa's Avatar
Quoted: 2 Post(s)
Hi! The core pieces of both setups are still wrapped up neatly in the garage.
hp tuners and the valve cover have both been sold.
I also still have the RPi GT Exhaust
idkfa is offline
post #12 of 15 (permalink) Old 05-28-2018, 12:23 PM
Quoted: 2 Post(s)
Yo, for starters, do you have turbo manifold available? If so can you send me picture of that. Thanks looking forward to seeing it.
post #13 of 15 (permalink) Old 02-22-2019, 11:24 AM Thread Starter
idkfa's Avatar
Quoted: 2 Post(s)
know it's been a while but i fixed the album in OP
Pictures of the turbo/manifold/etc https://imgur.com/a/7R5gH
idkfa is offline
post #14 of 15 (permalink) Old 02-22-2019, 12:30 PM
You have good timing. Just had someone post one of these turbos for sale and someone else responded if it was for the NA car. It wasn't since it was just the turbo.
post #15 of 15 (permalink) Old 02-22-2019, 01:30 PM Thread Starter
idkfa's Avatar
Quoted: 2 Post(s)
That's great! I'll have to go look!
idkfa is offline
  Saturn Sky Forums: Saturn Sky Forum > Other KAPPA, Sky and Small Roadster/RWD Cars > Saturn SKY vehicles/parts For Sale/Wanted
Currently Active Users Viewing This Thread: 2 (0 members and 2 guests)
