2007 Sky harness options - Saturn Sky Forums: Saturn Sky Forum
post #1 of 12 (permalink) Old 06-26-2019, 10:46 AM Thread Starter
Quoted: 3 Post(s)
I have a 2007 Sky (base). The passenger side wheel abraded through the plastic wheel compartment and messed up the engine harness which is pinned to the other side of the compartment. Two harnesses have exposed (but still shielded) wires and one of the harness connectors is now melted to itself. I discovered this after hearing a whump-whump-whump on the way home from work which felt like a bearing about to go, but was suddenly onset. At home I jacked the car up discovered the issue and the engine no longer started.
I removed the bracket and teased the wires apart and when twisted just right the car starts, but obviously there is an intermittent connection in the harness.
TL;DR: my question is for a 2007 Sky, are the engine harnesses interchangeable with the Solstice? And if so, for what model years?
thanks,
philip
ID:	105423   Click image for larger version
hahnpv is offline
post #2 of 12 (permalink) Old 06-26-2019, 11:21 AM
Quoted: 983 Post(s)
They probably are....but the wiring colors may be different. Make sure it is for identical years just as a cautionary note. I know the colors may be different from working on both cars.
This does not affect you but the wiring harness for a factory xm radio is different for those cars without...GM was cheap and did not fit their cars with the extras
marlboromike is offline
post #3 of 12 (permalink) Old 06-26-2019, 12:36 PM Thread Starter
Quoted: 3 Post(s)
Thanks. Do you know if an '08/'09 saturn would interchange with an '07?
And if anyone in northern AL / southern TN knows of some in a junkyard let me know, I'll start calling after work...
hahnpv is offline
post #4 of 12 (permalink) Old 06-26-2019, 12:46 PM
Most of the harness is interchangeable between the cars, most of the time, and with some obvious exceptions.
Some lighting is different between Solstice and Sky, so the headlight/taillight harnesses may differ.
The NA (Base) and RL/GXP have different harnesses.
Some years of the RL/GXP had a vacuum pump that other years do not.
Different options will have different harnesses, for eample: OnStar, power windows/locks, radio levels, etc.
Engine harnesses will be the same for Solstice and Sky, but there was a running change in ECM between 2007 and 2008, at which point both harnesses changed.
There may be other exceptions that I have missed, but someone is likely to speak up.
JohnWR is online now
post #5 of 12 (permalink) Old 06-26-2019, 01:03 PM Thread Starter
Quoted: 3 Post(s)
Engine harnesses for all NA should be the same for Solstice and Sky and all years.
Thank you!
hahnpv is offline
post #6 of 12 (permalink) Old 06-26-2019, 03:32 PM
Quoted: 983 Post(s)
I am SPEECHLESS
post #7 of 12 (permalink) Old 06-26-2019, 05:43 PM
Quoted: 1772 Post(s)
I do not believe that's true. The issue isn't so much the engine harness, but the ECU. 2006-7 LE5 2.4 equipped Kappas have a different ECU from 2008+ LE5s. @skersfan is making one good Sky out of two 2.4 automatic Bluestone Skys with tan interiors and tops. One is a 2007 and one is a 2008. The engine harness and ECM are different on the two cars. He is using the 2007 unit and I have some issues on my 2007 harness and was just going to swap it for the 2008 harness but found out we cannot.
post #8 of 12 (permalink) Old 06-26-2019, 05:56 PM
I do not believe that's true. ........
You are correct, and I even knew that. Hence my disclaimer, since my memory is not nearly as good as I want it to be. And I edited my post. Thanks!
post #9 of 12 (permalink) Old 06-26-2019, 06:33 PM
LOL I do it all the time. So much stuff coming in and my aging brain can't sort it all like it use to.
I want to say that the change in the ECM coincided with the Redline's Traction control. I'm not sure if that was it or not but I seem to recall (see above disclaimer) that the earlier ECMs found in the 2006-7 NAs didn't play well with the traction control GM was putting in the car and that the updated ECMs worked with the traction control systems.
But I may have that totally off.
post #10 of 12 (permalink) Old 06-26-2019, 10:02 PM
Quoted: 134 Post(s)
NO!!! Harnesses are specific to NA and GXP. And an '07 will not work on an '08 or '09 and vice versa. Just like the ECM!! You are stuck buying an '07 harness. If I remember correctly the wiring was completely different from '07 to '08 and '09.
The_Ghost is offline
post #11 of 12 (permalink) Old 06-26-2019, 10:30 PM
Quoted: 51 Post(s)
If this is the engine wiring harness then the NA and turbo are different but the harness for a 07 -09 Sky turbo is the same as a 07-09 Solstice turbo if they have a Bosch ECM. This harness will work on a 08 you would just ignore the air pump connectors on the 08 because they don't have the pump. The ECM does come into play if it is a Delco ECM then you will need a harness that will connect to that ECM. Late 07 models and all after had Bosch ECM's in the turbo cars. The same is true for the the 2.4 engine except in the case of the Delco ECM in the early models.
Hoosier GXP is offline
post #12 of 12 (permalink) Old 06-26-2019, 10:57 PM
skersfan's Avatar
Quoted: 835 Post(s)
I have a late production 2007 Redline. Same as the 2008 run. I have an ECM out of a 2009 GXP that fits my 2007 according the ECM experts. Just depends on when the car was made. So your home and safe I see!!!!! Fun trip sir.
skersfan is offline
