brake lights - Saturn Sky Forums: Saturn Sky Forum
post #1 of 19 (permalink) Old 06-22-2019, 01:11 PM Thread Starter
Quoted: 4 Post(s)
brake lights
Out of the blue today....
Brake lights are on when I start car, when I apply peddle they go off after a few seconds they come back on, running lights won't work in auto position but will in manual.
Any thoughts were to start?
Pat
psmith32 is offline
post #2 of 19 (permalink) Old 06-22-2019, 01:37 PM
Is it all three brake lights? Both sides and the center one? Do the turn signals work?
JohnWR is online now
post #3 of 19 (permalink) Old 06-22-2019, 01:57 PM Thread Starter
Quoted: 4 Post(s)
thanks, yes to all
psmith32 is offline
post #4 of 19 (permalink) Old 06-22-2019, 02:03 PM
What exactly are the running lights doing? Do both front and back do the same thing?
post #5 of 19 (permalink) Old 06-22-2019, 02:40 PM Thread Starter
Quoted: 4 Post(s)
yes. The running lights Key off/on only work when manually turned on OR the photo eye is covered up never in auto.
Turn signals work fine. Brake light is always on, turns off first time pedal is pressed stays off for 5 seconds then turns back on.
If I repeatedly press the brake, The lights work correctly until 5 seconds of no pedal movement then turn on.
psmith32 is offline
post #6 of 19 (permalink) Old 06-22-2019, 03:41 PM
That sounds normal for the running lights. In auto and daylight the DRLs will be on, but the running lights will not. Covering the sensor simulates night so the DRLs will switch to headlights and the running lights will turn on. Manual of course gives you manual control of headlights and running lights, and the DRLs will be off.
The brake lights and rear turn signals use the same filament and the same BCM output, so if the turn signals are working that part is OK. That leaves the brake pedal switch. You can check to see if it is broken or loose.
post #7 of 19 (permalink) Old 06-22-2019, 04:33 PM Thread Starter
Quoted: 4 Post(s)
Thanks john, I'll check tomorrow. I suspect that if I replace the pedal sensor/switch I will have to have it programed?
psmith32 is offline
post #8 of 19 (permalink) Old 06-22-2019, 05:29 PM
If you replace it, yes, it will have to be re-calibrated. But you may just find that it is loose, and then it should be OK.
post #9 of 19 (permalink) Old 06-23-2019, 09:37 PM Thread Starter
Quoted: 4 Post(s)
Now on to the next problem
DTR's now not working. low beam works, covering light sensor turns low beam on. relay 48 {dtr} has power (12 volts) on pin 30 and 85.
but relay never engages. it seams there is a resistor wire to drop voltage to 9 Volts. Anybody have an idea were it is located.
My thought is is blown.
psmith32 is offline
post #10 of 19 (permalink) Old 06-23-2019, 11:55 PM
What about the brake lights?
post #11 of 19 (permalink) Old 06-24-2019, 09:46 AM
Quoted: 511 Post(s)
There is no resistor. The 'dimming' of the DRL headlights is done by the DTR relay simply switching the two lights to series (so they divide the voltage and get ~6V each). If your relay isn't engaging, it may be faulty. To check, switch that relay with another similar one that's not being used for the moment and has the same shape and pins (such as the high beam relay, #72 ). If THAT still doesn't work, then you have an issue in the wiring to the relay (or in the BCM).
TomatoSoup is offline
post #12 of 19 (permalink) Old 06-24-2019, 01:39 PM Thread Starter
Quoted: 4 Post(s)
Tomatosoup
Yes I changed relays no "click". So I grounded one side (pin 86 or 85) and both DTR's comes on. So now It's on to tracing the ground wire.
After doing this I was not thinking the BCM because it was supplying 12 Volts to relay. Could it instead be controlling the ground?
I did a few weeks back do the side turn signal mod (2). the're now flashing with the turn signal. I'm not sure if this circuit is connected with DTR's but it does require cutting a ground wire.
I'll have to snoop around for a wiring diagram.
Johnwr
I took the bulbs out cleaned all the connections and so far there back to normal thanks for advise...on to the DTR's
psmith32 is offline
post #13 of 19 (permalink) Old 06-24-2019, 06:18 PM
Quoted: 123 Post(s)
In general ECM/PCM/etc control grounds, not +12v.
Amorget is offline
post #14 of 19 (permalink) Old 06-24-2019, 06:21 PM
Quoted: 511 Post(s)
Tomatosoup
Yes, the BCM controls most things by switching the ground. I've attached the Solstice headlamp wiring diagram. Should be almost the same as the Sky, apart from the different number of bulbs.
Ahhhhh, now the truth is coming out. That's what we, in the business, call "a clue"!
Yes, I think you need to revisit that mod and verify you did it correctly!
Name:	Lamps Headlamps+DRLs.gif
post #15 of 19 (permalink) Old 06-24-2019, 06:21 PM Thread Starter
Quoted: 4 Post(s)
Thanks i'll have to do some wire tracing
psmith32 is offline
