convertible top cable end - Saturn Sky Forums: Saturn Sky Forum
 1Likes
  • 1 Post By DaveOC
post #1 of 9 (permalink) Old 03-07-2013, 10:36 AM Thread Starter
The mechanism for the top includes a cable that connects to the rectangular body flaps located behind the headrests. These flaps have to be open for the top to put up and locked in place. There is a little plastic piece that retains the hook end of the flap cable in its hole on the bottom of the flap. I have had three of these break in the 3 years I have owned my Sky. Previously there was a dealer that just fixed it for me, so I had no idea what the part is. Yesterday I went to a Chevy dealer to see if I could get a replacement. Even with the appropriate diagrams, neither of us could figure out a part number. He knew his stuff, though, and recognized the part from the tailgate latch on a Silverado pickup. It is a fit. You can use GM part # 88981030 in that application for a Saturn.
GOCSensei is offline
post #2 of 9 (permalink) Old 03-08-2013, 09:30 AM
08BlueSky's Avatar
Quoted: 17 Post(s)
Though Iíve yet to experience such, good to know.
Thanks for the investigative research!
08BlueSky is offline
post #3 of 9 (permalink) Old 03-08-2013, 09:34 AM
Some of these parts are also in the doors.
2nd American Legends 2013
lllfly is offline
post #4 of 9 (permalink) Old 03-08-2013, 12:29 PM
Quoted: 181 Post(s)
Here you go
Read this
https://www.skyroadster.com/forums/f5...art-top-41091/
The key info is
This was discussed on one of the forums about 18 months ago when I was heavy into collecting parts. There is a thread that has pictures and the part number. The clips cost about $3 each. I have a dozen at home
Best source with pictures is here
https://www.skyroadster.com/forums/507301-post8.html
Clip part# 15290793
Both sides same part in red. One just goes in upside down
top wont close
Convertible Top Issue - Pontiac Solstice Forum
As an alternative, you can also buy the entire cable assembly. They come with the clips already installed. Since most people are not experiencing any failures at all and you are having them repeatedly, I would take a careful look at the entire mechanism to see if you have a cable sticking or a problem with the anchor point on the flap that is causing this problem.
Rob the Elder is offline
post #5 of 9 (permalink) Old 10-12-2014, 01:30 PM
Skyvader's Avatar
Love the Forum
This is great information. The Chevy dealer is clueless and wanted to replace assembles and possible the top, over $1000 estimated. I am going to try these first! When I pull on the cables with friend help while closing, everything works!
Skyvader
2009 Black Sky Turbo
Trifecta Custom Tune
GM CAI & Dejon ICP, Hahn Intercooler
Big Bore Throttle, 3" Magnaflow Quad Tips
Backbone Brace, Blitz Grille, Debadged
Woo Hoo Fun!
Skyvader is offline
post #6 of 9 (permalink) Old 10-12-2014, 05:11 PM
Quoted: 3 Post(s)
Just bough a couple bushings last week. The shipping/handleing is twice as much as the part so you might as well buy several at a time
Ardie is offline
post #7 of 9 (permalink) Old 05-21-2019, 10:43 AM
I had the same problem. Went to AutoZone and they told me the basic design for the clip is very common and lots of car parts are held in place by similar clips. They sold me an assortment made by a company called Doorman. One of the clips fit perfectly. Cost me less than $5.
Mike218 is offline
post #8 of 9 (permalink) Old 05-21-2019, 11:28 AM
DaveOC's Avatar
Quoted: 9 Post(s)
Here is the GM part and also a readily available Dorman part.
ID:	105203   Click image for larger version
SKY Rockin likes this.
Dave -
2006 Solstice NA #000741
DaveOC is offline
post #9 of 9 (permalink) Old 08-18-2019, 02:32 PM
fix that top problem, quick and easy
Let me save you all a lot of trouble. After looking on line at auto parts stores, in amazon, on ebay, and more, I found this simple little part at NAPA locally. It was ON THE SHELF and cost $4.00 for each side and the man was nice enough to clip them on Several of the references above are wrong. Try this, I just did it ONE hour ago. NAPA part # 735-2786. Get the right number, a number of these clips are out there and they are different sizes.
bbbacres is offline
