crank position sensor - Saturn Sky Forums: Saturn Sky Forum
post #1 of 26 (permalink) Old 05-31-2013, 03:35 PM Thread Starter
I got a check engine crank position sensor code yesterday for my 2008 RedLine. When the check engine lamp first illuminated, I also received a "reduced engine power" warning for a few minutes. I turned the engine off, waited a few minutes and started up again. The check engine lamp was still on but no "reduced engine power" warning was given. I drove home--45 miles--with no problem. The check engine lamp was on continuously.
This morning the check engine lamp again illuminated but, after a mile of driving, went out and has stayed out. The crank sensor code is still in my OBD system but the car runs fine.
I have 34,000 miles and the engine has never been abused. Has anyone else had this problem?
Thanks in advance.
RagTopHeaven is offline
post #2 of 26 (permalink) Old 06-02-2013, 08:03 AM
Use the. search.
2nd American Legends 2013
lllfly is offline
post #3 of 26 (permalink) Old 06-02-2013, 08:04 AM
Use the. search.
lllfly is offline
post #4 of 26 (permalink) Old 06-02-2013, 02:26 PM
stuck's Avatar
Quoted: 13 Post(s)
A bunch of us have. There's 2 position sensors, 1 for the intake and 1 for the exhaust. They're on the top of the engine and since I was doing it, I just swapped out both. IIRC it was about $50. The code will tell you which one is bad. And, yeah, try searching your P Code and that'll usually point you right to it.
stuck is offline
post #5 of 26 (permalink) Old 06-02-2013, 05:42 PM
Quoted: 476 Post(s)
He said crank position, not camshaft position.
TomatoSoup is offline
post #6 of 26 (permalink) Old 06-02-2013, 08:44 PM
stuck's Avatar
Quoted: 13 Post(s)
He did say crank. Then, nevermind.
RagTop, what's the code you got?
stuck is offline
post #7 of 26 (permalink) Old 06-04-2013, 03:22 PM Thread Starter
Code J4355. Finally took to GM and they confirmed it is indeed a crankshaft position sensor. They want $260 to replace.
They also say my alternator is starting to fail and want $720 for that. As I understand it the voltage regulator is NOT in the alternator anymore but is now part of the power control module which should be covered by my emissions warranty.
Have any of you seen premature (34,000 miles) failure of alternators?
post #8 of 26 (permalink) Old 06-04-2013, 04:33 PM
Quoted: 476 Post(s)
Are you still within the 5yr/100k mile drivetrain warranty? Both should be covered if so.
post #9 of 26 (permalink) Old 06-05-2013, 02:46 PM Thread Starter
My 5 year, 100K warranty is still in effect but the dealer is holding firm that IT DOES NOT APPLY.
Hard to believe since the crankshaft is part of the engine and the engine is part of the powertrain. We're still fighting about it.
post #10 of 26 (permalink) Old 06-05-2013, 02:51 PM
Quoted: 476 Post(s)
That's bogus. Ping the GM Customer service people on the forum.
post #11 of 26 (permalink) Old 06-09-2013, 08:24 PM
Bogie's Avatar
Just because it's part of the engine doesn't mean it's under the powertrain warranty. This is not a "guess" thing. I'm pretty sure GM has coverage defined to the proverbial "T". Looking in my Warranty booklet I see crank position sensor listed under "Ignition Systems".
Nothing wrong with verifying with GM corporate.
2008 Redline Auto
Born 7/20/07
Snagged 8/31/07
Released 8/8/15
Bogie is offline
post #12 of 26 (permalink) Old 06-10-2013, 04:08 PM
Quoted: 55 Post(s)
Tell the dealer to RTFM!!!
GM is quite specific as to what is covered under the powertrain warranty. The crankshaft sensor is covered as per page 23 in your warranty manual. I can't find reference to the alternator so I assume it is not covered. I would get them to change the crankshaft sensor if you need to do that to get it running and go somewhere else for a second opinion on the alternator.
I would replace the battery first as our cars do weird things with a worn battery. If it's the original look for a new one.
Here's reference to the crankshaft sensor on page 23:
Ignition System
Camshaft Position Sensor(s)
Crankshaft Position Sensor(s)
Distributor
Distributor Cap
Distributor Pick Up Coil
Distributor Rotor
Glow Plug(s) (Diesel)
Glow Plug Controller (Diesel)
Glow Plug Relay (Diesel)
Ignition Coil(s)
Ignition Control Module
Ignition Timing Adjustment
Knock Sensor
Spark Plug Wires
Spark Plugs
You can find the manuals for the car here.
Saturn Vehicle Owner?s Manuals | Saturn
Sly Bob is offline
post #13 of 26 (permalink) Old 06-11-2013, 11:55 AM
GM Customer Service's Avatar
Hello all,
Here is a little more clarification on the powertrain warranty. If the part is found to be defective and you are under warranty it includes:
In general, the powertrain warranty covers the engine, transmission, transfer case and axle assemblies on light duty vehicles as indicated below:
Engine Coverage Includes: All internally lubricated parts, the entire pressurized fuel system (in-tank fuel pump, pressure lines, fuel rail(s), regulator, injectors and return line). Also included are all actuators and electrical components internal to the engine (i.e.: Active Fuel Management Valve Lifter Oil Manifold, etc.) as well as the Engine/Powertrain Control Module, module programming, cylinder head, block, timing gears, timing chain, timing cover, oil pump/oil pump housing, OHC carriers, valve covers, oil pan, seals, gaskets, manifolds, flywheel, water pump, harmonic balancer, engine mount, starter motor, turbocharger and supercharger. Timing belts are covered until the first scheduled maintenance interval.
Exclusions: Excluded from the powertrain coverage are sensors, wiring, connectors, engine radiator, coolant hoses, fans, coolant and heater core. Coverage on the engine cooling system begins at the inlet to the water pump and ends with the thermostat housing and/or outlet that attaches to the return hose. Also excluded are engine oil cooling hoses and radiators.
Transmission/Transaxle Coverage Includes: All internally lubricated parts, case, torque converter, mounts, seals and gaskets as well as any electrical components internal to the transmission/transaxle. Also covered are any actuators directly connected to the transmission (Slave cylinder, etc.) as well as any Transmission Control Module and/or module programming.
Exclusions: Excluded from the powertrain coverage are transmission cooling lines, hoses, radiator, sensors, wiring and electrical connectors.
The Transfer Case Coverage Includes: All internally lubricated parts, case, mounts, seals and gaskets as well as any electrical components internal to the transfer case. Also covered are any actuators directly connected to the transfer case (Slave cylinder, etc.) as well as encoder motor, transfer case control modules and/or module programming.
Exclusions: Excluded from the powertrain coverage are transfer case cooling lines, hoses, radiator, sensors, wiring and electrical connectors.
The Drive Systems Coverage Includes: All internally lubricated parts, final drive housings, axle shafts and bearings, constant velocity joints, propeller shafts, universal joints, wheel bearings, front and rear hub bearings, locking hubs, mounts, supports, seals, gaskets as well as any electrical components internal to the drive axle. Also covered are any actuators directly connected to the drive axle (i.e.: front differential actuator, etc.) as well as any transmission control module and/or module programming.
Exclusions: Excluded from the powertrain coverage are drive system cooling, lines, hoses, radiator, sensors, wiring and electrical connectors related to drive systems.
Hope this helps,
Erica Tiffany
GM Customer Service
GM Customer Service is offline
post #14 of 26 (permalink) Old 06-11-2013, 12:13 PM
Quoted: 55 Post(s)
Erica, that may be true today but the warranty was different when this gentleman purchased his 2008 Sky. The warranty book that I posted a link to states that the crankshaft position sensor is covered. I suggest he takes that document to the dealer and pursues it further.
Do you have access to the 2008 document?
Sly Bob is offline
post #15 of 26 (permalink) Old 06-11-2013, 12:29 PM
DaveOC's Avatar
Quoted: 9 Post(s)
I'd hope that GM would have access to that document. After all, you and I and anyone with access to the internet can find it:
http://www.saturn.com/content/dam/sa...nty-manual.pdf
Dave -
2006 Solstice NA #000741
DaveOC is offline
