Door Lock Issues on BOTH Sides - Page 2 - Saturn Sky Forums: Saturn Sky Forum
 3Likes
post #16 of 33 (permalink) Old 08-11-2010, 07:20 PM Thread Starter
Originally Posted by JRinKY View Post
Pull the carpet back, and there should be a piece of heavy corrugated plastic velcroed to the footwell. Pull it off to expose the BCM. About all you can do at that point is re-seat all of the fuses and connectors that live on the top of the BCM.
I do not think any are involved, but it wouldn't hurt to reseat all of the fuses and relays in the Underhood Fuse Block as well.
The auto-locking behavior when you are manually unlocking the door suggests a hardware failure in the BCM, rather than a simple loose connection.
I just tried it again (locking / unlocking doors) and it still hasn't worked. I tried it while moving and while at a stop. I found a couple BCM's on Ebay, it seems they are about $75 OBO for the part.
Here is what I am finding:
Body Cont (BCM) BCM/ECU BCM ECU,25848392: eBay Motors (item 290458068643 end time Aug-25-10 10:30:55 PDT)
Body Cont (BCM) BCM/ECU BCM ECU,15906911: eBay Motors (item 290455880545 end time Aug-18-10 12:13:04 PDT)
This weekend I'll dig into the passenger side and see what I find out. Hopefully they are both the same part (they look the same to me!!)
TY all again for the help.
2008 Infiniti G37S Coupe 6MT - 58k - Megan Axle Back
2007 Sky Red Line 5-Speed - 79k - Light mods
2006 Saturn Vue 5-Speed - 103.4k
Koobie is offline
post #17 of 33 (permalink) Old 09-13-2010, 03:33 PM Thread Starter
Heyyyyyyyy everyone,
It has been a bit, but I pulled up the carpet and checked the BCM. Fuse #26 looked okay and I did reseat it. The door locks still did not work. So I will just replace the unit. Looks pretty easy to swap, and the part isn't too expensive and is of the same design on other GM cars so that is a plus.
I'll get a DIY up with photos when I do the swap.
Thanks again for the great help all.
Koobie is offline
post #18 of 33 (permalink) Old 09-15-2010, 04:10 PM
Quoted: 68 Post(s)
Hope that this fixes it for ya, John!
Good luck!
"Black Bart"
5 Speed Stick
Single Disk Monsoon Sound
Yogi is offline
post #19 of 33 (permalink) Old 09-17-2010, 05:07 PM Thread Starter
Thanks man, I got the part in last night. It looks like only about 5 or 6 screws, so this should be a pretty straight forward DIY.
I'll start a separate thread with pics and what not later.
Koobie is offline
post #20 of 33 (permalink) Old 07-13-2017, 06:49 PM
Bryan Hilliard's Avatar
Resurrecting a dead thread. I had this problem, and found this thread. Pulled #26 , and it was fine. Put it back in, and viola! Locks work again. Not real happy with the Velcro securing system for the BCM cover. Has anyone found a more robust solution?
Bryan Hilliard is offline
post #21 of 33 (permalink) Old 07-13-2017, 06:51 PM
To me that would be a solution in search of a problem. Mine has never shifted so I don't see any reason to change it.
JohnWR is online now
post #22 of 33 (permalink) Old 07-14-2017, 01:34 PM
The Velcro attachment on the left side came loose from the panel when I was removing it. Thinking about just getting a self-tapping screw, and replacing the Velcro with that. Using 3M double sided tape on the left side at the moment. I know I can't see it with the carpet in place, but it tasks me. LOL
post #23 of 33 (permalink) Old 07-15-2017, 08:19 AM
I think that if the Velcro on mine came loose I would re-install Velcro.
post #24 of 33 (permalink) Old 07-15-2017, 08:23 PM
That's certainly an option.
post #25 of 33 (permalink) Old 03-24-2019, 04:20 PM
Kjelle69's Avatar
Quoted: 43 Post(s)
Hey @Koobie, if you are still active in this forum, did the new BCM solve your problem?
//Kjelle
Kjelle69 is offline
post #26 of 33 (permalink) Old 03-24-2019, 04:28 PM
//Kjelle
The last time he was on the forum was October '15.
post #27 of 33 (permalink) Old 03-24-2019, 04:35 PM
Junior Member
Emmett's Avatar
Quoted: 94 Post(s)
I didn't know this until 6 months after having purchased my car...
You have to click twice to open the passenger door with the FOB.
Emmett is offline
post #28 of 33 (permalink) Old 03-24-2019, 05:46 PM
Kjelle69's Avatar
Quoted: 43 Post(s)
Oh. Well Time flies...
When I press once the lights turn on but nothing unlocks.
When I press the second time the passenger door unlocks.
There is something wrong with the power from the BCM to the drivers side unlock actuator. (I think...)
Kjelle69 is offline
post #29 of 33 (permalink) Old 03-25-2019, 05:04 PM
Rusty Boltz's Avatar
Quoted: 161 Post(s)
Standard procedure for any car I've ever owned.
44thSKY likes this.
07 Sky
2.4L NA
5 speed
Limited slip differential
Chrome wheels
Premium trim package
Monsoon audio
AM/FM/XM/CD changer
Rusty Boltz is offline
post #30 of 33 (permalink) Old 03-25-2019, 06:03 PM
More recent models (like my '13 Equinox) are programmable. I have it set to unlock everything with the first click.
